Question about Sharp Office Equipment & Supplies
2301n ptc mx 2301n ptc
3 Suggested Answers
Ranglo
  • 1194 Answers
SOURCE: sharp printer MX-2301N Code TA
Thanks for choosing FIXYA.
Maintenance TA is indicating the machine has reached its 100K scheduled service interval. It requires Transfer Belt Unit, Usually Black Drum & Developer, any feed rollers wornout replaced, any old firmware updated to latest version, and a general clean & check. It is reset in service mode once these parts are replaced.
Have a nice day.
Posted on Jan 18, 2012
andrew_ha135
  • 14 Answers
SOURCE: Unable to print from my MacBook Pro using my printer Sharp MX-2301N
Does your unit have a PS3 expansion kit. if not you can only print using s PC, not a Mac. A work around is to use the Generic PCL driver available on later model Macs
Posted on May 13, 2012
Can i use corona wire in place of the PTC heater
Corona wire is very fine gold paled wire that carries a HV during the copy process. not used for heating
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Nov 30, 2015 | Sharp Mx-2600n MFP Copier
What is the full meaning of ptc, mfp, scu, pwb,LSU,LCC,SRAM,SUM,CPT
LSU - Print Head which houses the (LASER)
LCC - Large Capacity Cabinet (Holds a Lot of Paper, more than a normal tray)
SRAM - Static Random-Access Memory
CPT - Toner Cartridge Code
PTC - Primary Transfer Belt Cleaning Unit
MFP - Multi- Function Printer Control Board
SCU - Scanner Unit
PWB - Printed Wire Board (Circuit Board)
Hope that helps
Oct 16, 2015 | SHARP MX-3100N
Sharp copier mx-2301n code L4-30 i need help
The fan blades are normally the problem, check the fans below the black toner there are 2 small fans. Make sure they are operational.
http://www.manualsprinter.com/manuals/sharp/Sharp_MX-2301N.pdf
the link should help you step by step trouble shoot.
Aug 28, 2015 | Sharp Office Equipment & Supplies
Sharp mx 2301n error code c4 - 10
http://www.sharp.co.uk/cps/rde/xbcr/documents/documents/om/34_ppc/MX2301N_OM_Quick-Start-Guide_GB.pdf
Feb 13, 2015 | Sharp Office Equipment & Supplies
May 13, 2012 | Sharp MX-3501N All-In-One Printer
Sharp printer MX-2301N Code TA
Have a nice day.
Jan 18, 2012 | Office Equipment & Supplies
I have a sharp MX-3100N copier and need to fix the error C4-02
Your PTC unit needs to be replaced. Which is the Primary Transfer Charge unit.
Oct 31, 2011 | Sharp MX-3501N All-In-One Printer
MX-3100N ERREURE C4:00
Your PTC- Primary Transfer Corona has gone out. This is an electrode on a stick located underneath the transfer belt on the right side. These are supposed to have a life rating of 300,000 but I have known some to go out prematurely. You can order the PTC seperately or with the 1st Transfer rebuild kit. Meanwhile, you can bypass the error by changing a soft switch.
From Copy mode type # * C * this will put your machine in service sim mode.
Type 55 - start then 1 - start
Set the engine soft switch 8-3 in SIM55-1 to "1".
This setting disables the PTC output, the heater
control, and the error detection.
After completion of repair, set the engine soft switch 8-3
in SIM55-1 to "0".
Oct 23, 2010 | Sharp MX-3501N All-In-One Printer
Code c4-02 keeps coming up and not letting me do anything but turn it off
I am assuming your copier is an MX series. c4-02 is related to the pre-transfer cleaner unit. It is not making good contact with the copier
This fix is from Sharps website "In order to prevent possible C4-02 errors, the shape of the PTC Heater Spring and the PTC Case Cover R are changed to improve contact."
These parts are only available through your Sharp dealer.
Any possible long term fixes for this issue would require a service tech ... sorry
Jan 13, 2010 | Sharp Office Equipment & Supplies
50 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
