Question about AMD eMachines Desktop System w/ 17'' CRT Display, 2.0 GHz Athlon 64 3000+ (W3400)
After factory recovery sytem wont boot
Emachines t5242 keeps going to start up repair after a full factory recovery hellllllp
  • joe lANGSTON May 22, 2009
    did chk dsk the restore was done by using the recovery partition or pc angel chk dsk reported that the hdd was fine no bad sectors or anything of the sort i have two emachines machines and when i put the drive in the other emachines it works great when i put it in the machine that it came from then it has problems
  • Randy Hough
    Randy Hough May 11, 2010
    Was the restore done from the hard drive or from a restore cd?
  • 94 Answers
Try replacing the RAM in the machine having a problem. The drive works well in a different machine. Use the RAM out of that machine, if possible, in the machine having the problem.
Posted on May 23, 2009
    Problem Solver:
  • 3 Answers
Hi, there is a good possibility your hard drive has some bad sectors, I recommend downloading a utility that will check the state of the hard drive. http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=SeaTools&vgnextoid=720bd20cacdec010VgnVCM100000dd04090aRCRD
You will need to burn the ISO on a working computer, then boot from cd and run the long test. If there is bad sectors the hard dive test will fail, then hard drive would need to be replaced. Good luck!
Posted on May 22, 2009
I never got a disc with my laptop when i brought it and i need to reboot it i was led to believe there was a way without the disc, like a built in way to do it but i have no idea, please help.
During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart also click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to or if you want a full factory restore Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
Hope this helps you
Sep 07, 2011 | E-Machines emachines (emachinees) CD-ROM...
I did an update for my sylvania smartbook and now it wont do anything. i want to restore it back to its original settings.
During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to or if you want a full factory restore or Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer
hope this helps
Mar 22, 2011 | Computers & Internet
How do I factory restore my HP Pavilion dv4-2112TU with the recovery menu, safely.
Here are a few things you can do or try
Restart the computer. If you are already in Windows, you can do this from the Windows Start menu, go to Turn off computer and click Restart. As the computer restarts, watch for a progress bar at the bottom of the screen. press F8 about once every second. Immediately press F8 before the progress bar reaches the right side of the screen. From the Windows Start-up menu, highlight Safe Mode and press Enter. Wait for your desktop to appear, and then make the necessary repairs (for example, uninstall programs or devices). When the repairs are done, restart the computer, and allow it to boot normally.
Alternate:
From the Windows Start menu, click Run. In the Open field, type MSCONFIG and click Ok. On the BOOT.INI tab, check /SAFEBOOT.
Click Restart when prompted.
or
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
helps don't forget to vote
Feb 28, 2011 | HP 419320-001 - HP Pavilion dv4000 Series...
When i start the laptop, i want to go in to the setup. however when i press F2, it ask you to insert password.
Alternate:
From the Windows Start menu, click Run. In the Open field, type MSCONFIG and click Ok. On the BOOT.INI tab, check /SAFEBOOT. Click Restart when prompted. Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to or if you want a full factory restore or Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
Hope this helps don
Feb 26, 2011 | Computers & Internet
How do i get back to factory setings keep geting
Alternate:
or
Hope this helps don't forget to vote
Feb 21, 2011 | Gateway Computers & Internet
My HP mini 2010 needs to do a system recovery or restore. But it says i will lose all add programs and files. The back up file option in the recovery manager does let me select it, as i tried to do it...
Alternate:
or
Feb 19, 2011 | Computers & Internet
SATELLITE U305-S7448. Vista is badly corrupted and I have no factory restore disk. How can I obtain a factory restore disk? Boot up restore option doesn't work. There appears to be no restore...
Alternate:
or
Feb 15, 2011 | Toshiba Computers & Internet
How do i restore back to factory settings with out the cd ?
The only way to restore back to factory settings without the CD is by booting into your Recovery Partition, IF YOU HAVE A RECOVERY PARTITION. If you do have a recovery partition, then you should see an option for booting from that when you first start up your computer. It should be listed with Setup and Boot Menu options. Press the key that is displayed for entering recovery. From there you can choose what type of recovery you are wanting to do. If you know that you have a recovery partition, but don't see it listed when your computer first starts up, then start tapping F8 when you first boot your computer. You should see a black screen with white text. From there you can choose Safe Mode or whatever. You should see something labeled Recovery or Utilities in that area if you really have a Recovery partition. If you don't see this, then you will have to go to emachine.com and request a recovery disc from them. They will likely ask you alot of questions in order to get the disc. Usually it costs between $20 - $50 for the recovery disc. The only other option you have is to go to Staples or some other store and buy the Operating System you want.
Mar 22, 2010 | E-Machines eMachines Desktop PC
Restore emachine
Your machine has two ways of repair: SYSTEM RESTORE and SYSTEM RECOVERY. System restore is a Windows utility that rolls the machine back to a point where the machine worked before the problem. System recovery is an eMachines tool that puts the machine back the way it was when you first got it. Restore wont delete your data, recovery will and can. If the problem is catastrophic, and youve backed up your data off of the machine, use the recovery option. Your recovery partition (or a recovery disk) is needed to do this, and it involves pressing a key while the computer boots up. Check your documentation for your model of machine.
Mar 24, 2009 | E-Machines (T2824) PC Desktop
Emachine T5224
Repeteadly Press F1 during boot. Then at the menu press F8 to go to advanced options. Then select System Recovery, and you can get into the recovery manager to restore the original factory system.
Jul 07, 2008 | E-Machines T2742 PC Desktop
AMD eMachines Desktop System w/ 17'' CRT Display, 2.0 GHz Athlon 64 3000+ (W3400) Logo
186 people viewed this question
Top AMD Computers & Internet Experts
David
David
rafnix
rafnix
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
