Question about Datamax DMX-I-4208 Label Printer
Problem with old datamax printer.
Hi I had 2 datamax printer. One is quite old and another is recently bought. My old printer is used for testing purpose and I currently testing a 3.5 inch label.
My problem is my old printer always display top of form error when I change into a 3.5inch label. However, its works well with label of bigger size. I tried all kind of calibration and adjustment but the problem persist.
However, if i change to my new printer and use it to test the 3.5 inch label. It works fine without any adjustment.
Can any one help to solve this problem
It sounds like you may not have the latest firmware. You should go to the Datamax website and download the latest firmware revision for your printer. http://www.datamaxcorp.com/software/ If it's not available on the website, you can call Datamax with your CID# and serial number and ask them to send you the latest firmware for that printer. This should hopefully clear up your problem.
Thermal Printer Repair @ Worldwide Ticketcraft
http://www.worldwideticketcraft.com/printers
Posted on May 28, 2009
Um Ha ha It's very simplely Please use the new one! not the old! http://www.20ok.com
Posted on Jun 12, 2009
Barcode scanner won't read printed labels
1. The printhead in your printer might be scratched (evidenced by thin white streaks through your print). This is common, and the most likely cause. Printhead must be replaced.
2. Material might be stuck on your printhead (usually evidenced by wide white streak vertically through print). Printing surface of printhead can be cleaned with rubbing alcohol and cotton ball.
3. The ribbon might be wrinkling due to uneven tension, producing intermittent diagonal streaks in your print. This is somewhat common, but doesn't fit your description as well as 1 & 2 above. Mechanical adjustment and/or proper media loading solves ribbon wrinkles.
4. Poor pressure and/or printhead alignment. Evidenced by grainy, light or no print on one side or the other of the media. This is somewhat common, but doesn't fit your description as well as 1 & 2 above. Mechanical adjustment solves printhead pressure and alignment issues.
Dec 11, 2012 | Datamax E-Class E-4203 Label Printer
I can't read a code bar printed with datamax a4212
try adjusting your darkness settings. if too dark wont read and also if too light wont read. also try a printhead test to make sure no elements are burnt out.
Aug 13, 2017 | Computers & Internet
Why wont my datamax 4208 printer read the same label format as the 4212
It will read and print the label format, but you need to download and choose a different driver for the other printer. Seagull Scientific makes the drivers for Datamax, so visit their site for the most recent versions. you will need to open your label format in your software, duplicate the label format and choose the new driver for the I-4212.
Sep 10, 2010 | Datamax DMX-I-4212 Label Printer
Vb6 code to print barcode using datamax e4203
Puedes utilizar comandos DPL e instalar una impresora generica, o generar un archivo PDF y utilizar un controlador de windows para DATAMAX. DPL commands you can use and install a generic printer or generate a PDF file and use a Windows driver for Datamax. buscar
Apr 10, 2009 | Epson Printer
Visual Basic 6.0 Code for Datamax ST3210
In www.datamaxcorp.com can find the programming manual of printers and you'll find examples of label design.
Jan 21, 2009 | Datamax M-4208 Thermal Label Printer
Datamax Allegro 2
Hi - You can download the manual by clicking the link underlined in blue below:
Datamax Allegro 2
You will need to contact their customer support for the software, the details are here.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 05, 2008 | Epson Printer
Datamax M-4206 printing too slow
The way you can do this is to use Datamax fonts in your LabelMatrix program instead of truetype fonts like arial or times new roman. After making this change, do a test print and see if print improves. Another possible solution is use USB instead of Parallel cable (if you're not using it already).
Aug 25, 2008 | Datamax M-Class Thermal Printer
DATAMAX PRINTER
Hi
Its worth checking that you are using the latest drivers. You should be able to get these from the Datamax website. Also check the printer set up, gap sensor etc. Also check the media is loaded correctly. Hope this helps. Regards Stu www.labelzone.co.uk
Jun 19, 2008 | Datamax DMX E4203 Printer
Datamax problem
You probably need to adjust the leveling cam if you have not done so already. This is the green thumbscrew near the print mechanism.
Dec 18, 2007 | Datamax M-4208 Thermal Label Printer
Datamax E class
Go to Control Panel > Pritners and Faxes. You should be able to see your printer there. You can check and ask it to print a test page.
Jun 05, 2007 | Datamax 1/PK EXTERNAL LAN INTERFACE METO...
Datamax DMX-I-4208 Label Printer Logo
641 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
pkwc
Kevin Brown
Level 1 Expert
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
