Clean pump
Whirlpool AWO/D 4505
  • 61 Answers
SOURCE: whirlpool washer
ok unplug the washer remove the three screws across the bottom front of machine if you have a pedistal willbe between the pedistal and the machine. remove the access panell you will see the drain pump it has a threaded cap faceing the front remove this cap and clean out the lint trap attached clean out and debree in the pump housing you can see. reinstall cap, front cover, plug in and test.
Posted on Jan 20, 2009
danromarris
  • 101 Answers
SOURCE: clean pump light is flashing where is the pump so i can clean it
The pump is located in that bottom compartment under the door. There are two screws that you need to take out located in that tiny little opening and the panel will come right off. The pump is right there in front. Let me know if you have any other questions and let me know if this was helpful for you. Good luck and I am glad I could help.
Posted on Jan 22, 2009
SOURCE: Whirlpool AWO/D 4505 Washing Machine
Unplug your machine and unclip the plastic trim panel across the bottom of the machine (front) to reveal the circular pump filter cover. Unscrew this cover with your fingers and remove any debris inside. Put the cover back on, clip the panel back on and try your machine again. Should be fine.
Posted on Feb 05, 2009
reddyanantha
  • 205 Answers
SOURCE: i need to clen the pump on a whirlpool washing
hello mam you cant clean the pump but you can clean the filter of the drain line. and if you want to clean it you should use a descaling powder this will be available with the washing machine service centers.
Posted on Sep 22, 2009
Testimonial: "cheers man , great help prob solved. "
  • 69 Answers
SOURCE: Whirlpool AWO/D 4605 Clean Pump light on, how do I
Remove bottom plastic panel across the front of machine- it just clips off (use a small screwdriver or bread knife to prise off). You will now see a round filter behind this panel- unscrew anticlockwise to remove- this is the filter. Sometimes filter can be hard to remove if you have things jammed in it- give it bit of a jiggle and it should come out without forcing it. Remember- if there is still water in the machine, this water will come out on the floor once you remove the filter- put down some towels!! Happy fixing!!
Posted on May 11, 2010
Where do I clean the pump filter? Light keeps lighting to clean pump. Whirlpool front loader. A+A 5kg / 1200 AWO/D 4505
You have a code telling you to clean the pump now thats a first are you sure it says clean the pump filter? more info as to why you are needing to clean the pump filter its not really easy trust me, unless you have done it before which i am guessing you havent.
Mar 07, 2016 | Whirlpool Washing Machines
AWO/D 4505 not spinning
does it pump out all the water when it spins the first time? when they spin slow sometimes the pump is not pumping out all the water causing it to spin slow.
May 15, 2014 | Whirlpool Washing Machines
I need to clen the pump on a whirlpool washing machine awo/d 4505
Sep 22, 2009 | Washing Machines
Cant locate ''pump'' on whirlpool awo/d 5556
Hi, Whirlpool manuals do say that but they only mean the filter not the pump as this is self cleaning!
Hope this helps.....
Feb 27, 2009 | Whirlpool Washing Machines
I have a whirlpool washing machine and I need to check the filter, please can you tell me where it is. It is a AWO/D 4505 model Thanks
Your filter/screens are where your washer hot and cold hoses connect to you washer. You will have to turn the water off on your washer, and unscrew the hoses at the washer. You will see them at the end of the hose or in the washer itself. Take them out and clean them.
Jan 15, 2009 | Home
Aug 06, 2008 | Washing Machines
Washing machine
whilpool awo/d 4305 light onclean pump can i do this myself
Jul 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
