Question about Samsung Dishwashers
Salt indicator flashing
After I add salt
3 Suggested Answers
SOURCE: Salt Indicator Light Flashes Permanently On Indesit IDE 750 dishwasher
I've had the same problem on my Indesit (IDL-730, IDL730) and after pouring in salt until full for ages, without the light going out, I finally decided to do the reverse.
I left it to run down the salt over a couple of months, until well empty (not ideal, but I was getting desperate!), and then finally refilled it.
Problem solved - salt error light was no longer on
All I can figure is that a blockage had set in and casued the issue. Leaving it to clear over time sorted it.
Hope this helps in your situation.
Posted on Nov 18, 2007
  • 25 Answers
I think I have the answer.
On Yahoo Answers Blue Rizla Girl put up the idea that the sensor is some form of hydrometer. (i.e. floats in salty water sinks if not salty enough)
Based on this thought I postulated that the sensor is some form of hydrometer float in a tube with perhaps an optical sensor.
If this is correct why is it not working?
Is it because the float is stuck at the bottom of the tube, perhaps by some food debris? If so how can we fix it?
This is what I did on my Hotpoint FWD60:-
I took the salt filler cap off. There was no salt in the reservoir as it has been a problem for months, and I was only refilling it when dishes were not coming clean.
I poured 2 litres of hot water into the salt reservoir.
I then put the empty machine on the intensive 65 degree wash, half load and with the reservoir cap still OFF.
When finished I filled up with salt and HEY PRESTO the salt light is OFF!!!!
Just hope it stays that way until the reservoir really needs refilling.
While I was down on my hands and knees I took the opportunity to clean the filters in the sump. They do get full of bits!
I also flushed the sump by dashing a couple of cups of hot water into it and then bailing it out with a small yoghurt pot. I repeated this until the water in the yoghurt pot and the sump no longer had any signs of bits in them. (Dashing = vigorously pour)
I was amazed at how many bits I got out, especially considering I had given the machine a good clean in the past 6 weeks.
I even got part of a paper label!
So there we have it, try it out and report back.
Posted on Dec 05, 2009
Hi my kleenmaid silent system think it's a dw2 the salt button is flashing you turn it on it goes to start then stops we cleaned it all out and fix the problem once before but this time nothing works. I'm...
If water is soft in your area you can ignore the salt indicator light and operate the dishwasher without adding regenerating salt. However, you need to ensure the salt reservoir is filled with water to the brim. So add water into the reservoir and then put the cap back on.
Dec 26, 2014 | Dishwashers
My generator first indicated low salt. I've added plenty of salt, and it still indicated low salt. I turned it off for 24 hours, and tried it again, now it has the service indicator light on,what next ?
We've found with our saltwater system (which doesn't have a service light, so not the same model as yours) that we have to add far more salt than we expect before the 'low salt' indicator goes off. It also seems to be very tempramental whenever it's been off for a while (such as over winter) & needs to run for very short bursts at first before working up to normal operating times.
Aug 02, 2013 | Intex Automatic Salt Water System for ...
How to stop it frfom beeping/flashing 91 low salt.
1st... Check electrolytic cell and clean with vinegar...If white scalley stuff inside, cap one end and soak for 6 to 12 hrs and rinse until clean
2nd...check salt level, see manual for PPM, if low, add salt.. If you have a big pool 12000 to 15000 gallons, you will have to add up to 100 lbs of salt..
3rd... Run only pump for 24 hrs to dissolve salt..
4th... Set you cycle and should be fine
Hope this helps and rate if it does
Jul 16, 2011 | Intex Automatic Salt Water System for ...
My low salt light on my Hurlcon vx7t salt chlorinator keeps comming on.How do i adjust it?
A low salt level warning is indicated on your VX Chlorinator if the salt level drops. If Low Salt is indicated, check again in 24 hours and then if it is still indicated, add two 25kg bags of salt to the shallow end of your pool. Run the filtration system for approx. 6 hours to help mix the salt in the pool. It can take up to a day for the salt to fully dissolve.
If the low salt light is still on, then you should get your pool water tested. If the Salinity is above 4000ppm then you may need to have your Chlorinator checked.
Warning: Some people recommend that you put salt directly in the skimmer box. This is a very bad practice as it allows very high concentrations of salt to be passed through your filtration and other pool equipment.
Hope this helps.
Jul 06, 2011 | Grilling
My dishwasher says that it needs salt what sort of salt and how much?
HOW MUCH SALT DO I NEED TO ADD?
shim.gifYour machine may have a float indicator or a warning light to tell you when salt needs adding to the water softener. Often float indicators are difficult to see, and there is no accurate guide as to how much salt you need to add. Quite simply, just add granular salt to the reservoir until it won't take any more!
The softener will use the salt to replenish itself each time you wash. As an approximate guide, you should do a full top up about once a month. If your machine doesn't have a warning light, a good way to remember to check and / or top up is to do it on a regular day of the month (e.g. the first Saturday or the 15th)
CAN I USE ORDINARY TABLE SALT?
No. Table, cooking, rock and sea salts may contain additives that can actually increase water hardness. Also, the fine consistency of some of these salts mean they are likely to clog when wet. Always use granular dishwasher salt because it is very pure and is the right consistency for use in your machine.
Granular salt is the ONLY type of salt that should be used to regenerate the softener. Be aware that some varieties of 'dishwasher salt' use Dead Sea salt. This variety may contain minute insoluble organic matter that may adversely affect the resin within your softener over time. If you are in doubt about the origins of the salt, ask the retailer or manufacturer.
Sep 30, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
Low salt indicator
Thank you for posting your question here on Fixya.com.
Is this a new unit? 200 might be off a little if this is the first dose of salt the pool has seen. If you are using 40# bags I'd add one more. At only 7,000 or so gallons you will go from low to ideal in a hurry so do not add more than about 10 - 20 pounds at a time.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Jun 02, 2010 | Intex Automatic Salt Water System for ...
Cda cw494 dishwasher it runs for about 20 mins
is the light indicator flashing because you need to add salt or rinse aid.i have a bosch and my lights only flash to give me information on addig salt and,or rinse aid. so i can stop this by setting my dishwasher to take all in one detergent ,then the lights will not flash.
Nov 10, 2009 | Dishwashers
Salt System for Swimming Pool
http://www.inyopools.com/HowToPage/how-to-know-when-a-salt-cell-is-bad.aspx?CommentPage=1
Try this link. http://www.inyopools.com/HowToPage/how-to-know-when-a-salt-cell-is-bad.aspx?CommentPage=1
step 2 may be a clue that all that needs to be done (to turn out the light) is to depress the diagnostic button for about 3 seconds. Of course, some inspection or cleaning might still need to be done to preserve its life.
Thank you for your service. I haven't seen the name Blankenship since I left home in 58 to join the Navy.
May 17, 2017 | Water Heaters
Dishwashers Logo
10 people viewed this question
Top Samsung Dishwashers Experts
Dale Copeland
Dale Copeland
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
