Technika tv faults
Picture quality poor
  • 173 Answers
SOURCE: Poor Picture Quality on Philips 42PFL7962D
Get the professional, although this won't be an expensive fix... You likely have one or more caps in the vertical circuit that are going bad... A cap acts like a battery in a circuit taking on voltage and releasing it at an even rate. When they go bad their ESR (equivilent series resistance) rises and the cap takes longer to reach it's op temp and work properly...
A tech with an ESR meter will easily find and repair this one...
no other issues only a minor problem..
Posted on Dec 05, 2007
circuitworld
  • 335 Answers
SOURCE: Poor picture quality & audio reception
If the input to a HD tv is not in HD format the tv won't display an image very well. Be sure your input to the tv is compatible with the tv's technology for optimum performance quality Also re-check the input source (such as converter box, dvd player, etc..) and be sure you have the correct input/output ports connected properly. Try to reset all yout tv settings back to manufacturers defult specs. When an input signal is sent to the tv most modern tv's have software built in to select the proper format to display the input image. There may have been a mismatch communication error when your tv software tried to "handshake" with your converter box input signals from its firmware. So try a reset solution and re-connect the tv without the converter and see if that helps. If not e-mail me and I'll determine if the tv needs technical servicing.
Posted on Jan 03, 2009
jerryg50
  • 1689 Answers
Try another cable box on the TV. I have seen these fail and cause problems. If the TV is okay with a DVD player, and not good on the cable service, most likely the fault is with the cable box, or the HDMI input circuit in the TV.
With the process if elimination it is possible to functionally work out where the defect is.
It is possible to have any TV fail. Both new and old sets can fail. Naturally, the older the set the greater the chance of failure, and reliability decreases with age and or use.
Jerry G.
Posted on Jan 31, 2009
  • 909 Answers
SOURCE: Poor picture quality on cable input
Try swapping some cables around, like the skart lead from the dvd(if scart) for the cable one, if the picture problem swaps with the lead then thats the problem. If it doesn't try settings on the cable and tv, if the cable is sending nvbs signals and the tv is set to pal then this can also occur.
Posted on Jun 30, 2009
budmrtn
  • 11361 Answers
SOURCE: my tv shows poor picture
Are you using cable box or off the air antenna? More details please.
Same when use DVD?
Posted on Dec 04, 2010
Can radio frequencies cause tv reception problems? Our kitchen 15 tv has very good picture quality and sporactically and sometimes for long durations it has jumpy lines & poor picture quality.
yes if there is a cb with a power booster on it, it can cause problems check ground fault for house.. If you know the person with radio have him check his ground this can blow the TV up.
Dec 31, 2017 | Televison & Video
Cello tv picture set up
Contact the manufacturer if it is a new tv as there may be a fault.
Jan 02, 2015 | Televison & Video
Poor picture on 2nd tv
Check the antenna connection. Check its orientation.
Dec 27, 2012 | Televison & Video
Picture quality poor on certain channels,get all of bbc channels ok rest loss of sound and hick ups in picture
if all channels poor quality TV problem
if just one or tow channels bad quality not tv problem....
Oct 28, 2009 | LG 42LC2D 42 in. LCD HDTV
Jerry G.
Jan 31, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Jan 03, 2009 | Proscan 26LA30Q 26 in. LCD Television
Poor quality picture
Is the TV set on Ch 3 or 4 or are you using Line in/aux?
Feb 19, 2008 | Televison & Video
Poor picture
How old your tv? Sometime weak or poor picture depend to the old of tv, or maybe some parts inside need to replace.
Jan 12, 2008 | Sharp 25L-M100 25" TV
Diagonal lines and ghost images
You may have a bad flyback transformer (high voltage trans former). The lines you're seeing are retrace lines caused by the picture tube screen set too high. This is often caused by the screen control opening up. This control is part of the flyback.
Stargazer
Dec 02, 2007 | Proscan PS32500 32" TV
Televison & Video Logo
Top Televison & Video Experts
