Question about Russell Hobbs Kitchen Appliances - Others
Russell hobbs 18456 element blown
Replace element
Falling Down
  • 67 Answers
SOURCE: Russell Hobbs 10617 led bar
may have screws on the bottom and the loader knob usually has to be pried off. Place soft wood like a ruler against the housing and pry carefully from side to side with a large screwdriver. After working on it, plug it in outside to a ground-fault ac plug on a fireproof surface to test.
Posted on Nov 30, 2007
SOURCE: USER MANUAL FOR RUSSELL HOBBS CJS28 MICROWAVE WITH CONVECTION
Their customer service # is 0845-658-9700, their business # is 0161-947-3000, and you can e-mail them service@saltoneurope.com. I could not find a manual on their website so I guess you will have to the above #'s wurstdude
Posted on Nov 07, 2008
  • 10865 Answers
SOURCE: Need replacement blade for Russell Hobbs hand mixer
go to this page http://www.russell-hobbs.com/parts.shtml and order what you need directly from Russel Hobbs.
Please mark this answer as a fixya! thanks
Posted on Mar 18, 2009
  • 3 Answers
SOURCE: Russell Hobbs 9209 Classic toaster
I had the same problem which I managed to solve. The electro magnet that holds the toast lever down takes its power from a poor joint.
Remove the bottom of the toaster. You will see 2 wires encased in a heat proof sleeving going from the small circuit board. One of these wires dissapears up inside the heating element board about mid way along the board. You will now have to remove the metal covering by twisting 6 tabs. This is best done by taking off the black knobs you use to push the toast down - if you can - I couldnt, so I had to use long nosed pliers to bend the tabs and then with difficulty, remove the metal cover. YOu should now see the terminal that the wire is connected to. It is this connection that fails either between the wire and coonnector or connector and heatin element on the reverse side. I put a small bolt through the hole and used a nut to tighten the pressed fitting. I didnt use solder because I thought that it would just melt!
Anyway, my toaster worked after that. Russell Hobbs failed to give me any advice at all.
I hope that has helped.
Neville
Welwyn Herts
Posted on Mar 28, 2009
cactus bob
  • 267 Answers
SOURCE: Upper Heating Elements for Russell Hobbs Digital Convection oven
sorry to say its dead .this is the fate of all todays small appliances the only part i have in the book is a rack .no inside parts are made...hope this helped some ..........if this answer has helped and you plan to rate it please rate it a 3 or 4 star this high rateing will help me keep my spot in the paid answer department thank you
Posted on Apr 02, 2009
My Russell Hobbs electric kettle 14943 has stopped working? Fuse changed to No avail what could be wrong
The heating element has probably failed. You can check the continuity of the element with a multimeter.
Apr 29, 2015 | Russell Hobbs Kitchen Appliances - Others
New elements for Russell Hobbs Toaster 9276
go to an appliance repair shop and see it parts are available. go on the web--google-- russel hobbs toaster ---parts department and give your model number.
May 26, 2013 | Russell Hobbs 9276 Toaster
Russell-Hobbs 18140 4 slice compact toaster
See the diagram attached:
You will see the fuse you will problema 1) Ground 2) Live wire touching the chassis 3) Heating elements in short 4) Control Relais in short. 5) Test Diodes,You must test every components.God bless you
May 17, 2012 | Russell Hobbs 18140 4-Slice Compact...
Kettle will not heat. Russell Hobbs corded
Check mains fuse, if ok check for voltage at kettle , with multi meter, not phase tester as these can be faulty, if you have power and no heat then it has to be the switch or the element, check and replace same. if your unsure have an electrician do it for you
May 01, 2009 | Russell Hobbs Kitchen Appliances - Others
Apr 01, 2009 | Russell Hobbs Toaster Ovens
Mar 18, 2009 | Russell Hobbs RH-HB3 Handheld Blender
Heater Element Replacement
Yes I think they do but these may also be unavailable. You could try sourcing 'after market' replacement elements, these are universal fit elements often from the original suppliers and cheaper too. Try searching the web for Russell Hobbs replacement kettle elements.
Oct 14, 2008 | Russell Hobbs Kitchen Appliances - Others
Russell Hobbs kettle element model 10413
The only way to get hard to find Russell Hobbs electric kettle parts is from Russsell Hobbs. They will not sell any parts that are in short supply or becoming obsolete. Please visit their website, follow the instructions for repair and send the unit to them.
Aug 19, 2008 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
Top Russell Hobbs Kitchen Appliances - Others Experts
Jerry Greenberg
Jerry Greenberg
ashburton
Are you a Russell Hobbs Kitchen Appliances - Other Expert? Answer questions, earn points and help others
