Question about Black & Decker Pivot Plus Cordless Drill/Screwdriver
I need a drive roller rubber for a belt sander FMTC750 BS
Drive rubber has broken
  • 384 Answers
SOURCE: broken drive belt
Take the broken belt to an industrial supply house or Ball Bearing supply house for a replacement.
Posted on Jul 10, 2009
rowdy45176
  • 2176 Answers
SOURCE: My DS321 belt sander had the large drive
I would recommend going to Dewaltservicenet.com and typing in your model number and on the next page find the type number for the tool. I took a guess and found 2 thrust washers for the DS321. Let me know if you need more assistance and I will try and help
Posted on Jul 20, 2009
SOURCE: broken drive belt on belt sander
My answer comes almost a year after the original question, but I'll post it anyway for those who end up here after a search.
Black & Decker no longer supplies drive belts for the BR400 sander, but you can get a replacement elsewhere if you know what to ask for.
The belt is a synchronous, single-sided "XL" series belt, and mine had 120XL031 printed on it. The belt width is 0.31in or 5/16in or 7.9mm. Its pitch (distance from tooth to tooth) is 0.20in or 1/5in or 5mm. Its total height is 0.09in, and tooth height is 0.045in. It has 60 teeth, making the total length 12in.
I found a replacement at sdp-si.com, part number A 6R 3-060031.
Look here for timing belts (inch), then narrow the search for single-sided, .200 (XL) pitch, 60 grooves, 5/16 width.
Posted on Jun 16, 2010
rowdy45176
  • 2176 Answers
SOURCE: Black & Decker DS321 - ripped the rubber off
looked at a schematic and the drive roller screws onto the drive shaft, I don't see where is a locknut on the outside but the shaft is threaded, it moght be left hand thread. If there are 2 holes in the gear see if you can find a spanner wrench from a grinder and secure the roller and loosen the gear.
Posted on Sep 12, 2010
SOURCE: need belt for black and decker sander 110 xl 031
The belt from Jason 110XL031 is Identical in size and apperance.
Posted on May 12, 2011
I have a Makita belt sander,just replaced belt tensioner system including springs and roller but belt drive roller still keeps stopping on relatively light load even though the motor is running
very good trade tool
how quickly is it getting hot
slowing motor could be the cause
motor bushes and bearings can be replaced
did the motor drive belt under the cover get replaced
Jun 02, 2016 | Makita 9911 Compact Lightweight 3" X 18"...
How to stop the sand paper coming off my bosch psb75a belt sander?
The rubber compound on the drive roller is missing and is smooth hard plastic ??? replace the drive roller or your bushings are worn is the front rol not bent by a fall?
Nov 07, 2015 | Bosch Tools & Hardware - Others
How to install drive roller on my makita 9401 belt sander
DONT forget to order and replace also allways the sinter bearingbus on the machine because to protect you from a dissapointment because otherwise the belt will turns off and cant be (good) controlled again , replace the drive roller allways and clean the front roller axle if its only dirt on the front roller use a little sillicon grease film on the front behind can use a little bit more sillicon grease between the axle rings and new bearing bus. remove the dry grease in the driving gear space and renew the lubricant in it with a multipurpose grease .
Sep 04, 2014 | Makita 9404 4'' x 24'' Belt Sander
Black & Decker DS321 - ripped the rubber off the drive roller. Now got it in pieces, all cleaned up, but I dont see how to remove the driver roller from the Drive Shaft and belt guide assembley.
Sep 12, 2010 | Black & Decker 3 x 21 In. Dragster Belt...
I have a 3x21 inch craftsman belt sander. It's about 12 years old. With the sand paper belt is mounted and tightened and I start to sand something the belt will slip and not sand. I checked the tightening...
The drive and guide rollers are probably drying out and won't grab the paper. Take the drive roller of and treat it with a rubber restoring compund. The roller should not come off easily.
Jul 29, 2010 | Garden
Broken drive belt
Jul 10, 2009 | Black & Decker BR300 3''x18'' Belt Sander
How do you replace the drive belt on a Porter Cable Belt Sander
There is a lever on the side at the front right near the roller that you can use to release the spring tension on that roller (moving it slightly to the rear).  Once the tension is released you can slip the sanding belt onto both rollers from the side.  Release the lever and the spring will put tension on the belt to hold it in place.  Use the knob on the left side to center the belt on the roller if it starts to slip sideways when in use.
May 28, 2009 | Porter Cable 361 3" X 24" Sander
BROKEN RUBBER BELT FOR BELT SANDER
Maybe you can use a linked belt to replace it. Check the width of the old drive belt, and give these folks a call: Lee Valley
Nov 14, 2008 | Tools & Hardware - Others
Black & Decker Pivot Plus Cordless Drill/Screwdriver Logo
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
