Question about HP LaserJet 2200dn Printer
HP Laserjet 2200dn print spooler unable to connect
This HP Laserjet 2200dn (a 2200 with 610n network card) generates this error message from Windows XP Pro when I attempt to print. When I re-cycle power to the printer, printing eventually resumes normally. I just want the printer to run like this the first time without this error message:
"The print spooler was unable to connect to your printer. This can be caused by your printer being turned off, the cable being unplugged, or being connected to a VPN, which will block your access to a local network."
  • 7 more comments
  • Tom Bl May 22, 2009
    This is the only printer on the system. (I have a Nitro .pdf creator shown among the list of printers, and printing to it works normally.) The HP 2200 printer is connected with a CAT cable, from a router. The router has connections to 2 XP Pro computers and 1 XP-Home laptop computer via the wireless connection of the router.
    Yes, all 3 workstations. 2 are desktops with XP-Pro.
    I was able to get a "Windows XP Printer Test Page" to print but it does not include an IP address.
    Both "Location" and "Comment" are blank. This is not labeled as a "network configuration page" I got this by selecting the Windows control for "Print Test Page"
    In Win XP-Pro, the ports tab for the printer installation does show an IP address, but there is nothing to compare it to.
    As you know I have an HP LJ 2200 not a "Deskjet"
    The IP address shown on the JetDirect Page (HP JetDirect J4169A) is the same as the number shown for port settings.
    I'll also try checking "Always print to this device.. even if its IP address changes."
    However I note this instruction:
    "If the IP address fits the one showed in the network configuration page, the steps included in this document will not help to solve the Windows error message. Then, the cause for any printing issues may be related to the communication between the unit, the PC, and the software. "
  • Tom Bl Jun 24, 2009
    The IP address on the network configuration page from the HP printer is now verified to be the same as shown on the port setting.
    The instructions on the web page titled "Resolving the 'Print Spooler Unable to Connect to Your Printer' in Windows (Network Environment)" say:
    • "If the IP address fits the one showed in the network configuration page, the steps included in this document will not help to solve the Windows error message. Then, the cause for any printing issues may be related to the communication between the unit, the PC, and the software.
    The problem remains. When printing is started, the same error message appears instead. When the printer power is cycled off then on, the printing proceeds.
    Have you checked your workstations services app to check if your print spooler is running? No - although I presume it has to be working when power to the printer is restarted and the pages then print OK.
    A different driver? No, just the one provided with Windows XP-Pro and the HP LJ. It does work when power to the printer is cycled off and then on.
  • angelus316
    angelus316 May 11, 2010
    Do you get the error message from all 3 workstations?
  • n8ddy May 11, 2010
    Is it only thhis one particular printer tht gives you thei error message? Can you print to othr printers? Is it a PC or desktop?
  • angelus316
    Are you connecting via usb or cat cable?
  • 41 Answers
Have you tried a different driver eg. rpcs or another version of pcl?Have you checked your workstations services app to check if your print spooler is running?Also when you print a config page from the hp it will give you your network details.To eliminate your network grap a crossover cable and connect directly to the printer and test.Let me know.
Posted on May 28, 2009
    President:
  • HP Master
  • 1,996 Answers
Even though yours is a Laserjet, try working through this solution and see if it gives any satisfaction...good luck, as it's been a common problem...click here
Posted on May 22, 2009
  • efs_perpends
    efs_perpends May 22, 2009
    http://h20000.www2.hp.com/bizsupport/Tec...
  • efs_perpends
    possibly relevant and helpful conversation here
    And a link with some hopeful folks who seem to have licked the problem...here.
Unable to print and make photocopies
when you try to print does it come up with any error message?
or does it get sent to the print spooler and then lost in cyberspace?
or does it get to the printer and then the printer says no?
for the error message follow what it says so if the error is no connection check that the wires are attached. if it comes up with an error code look it up on the HP website.
if it gets lost in cyberspace try reinstalling the printer with an updated driver.
and finally if it says no go to run and type services.msc and scroll down the list till you see print spooler if it says it is stopped start it and try again, if it still doesn't work try updating the firmware
Jan 03, 2014 | HP LASERJET PRO M1132 MFP
I had to reinstall the software for an HP 3390 on a Windows XP workstion. The device can print and fax. However, when I try to scan a document I get the following message: The HP imaging device could...
The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
Oct 26, 2010 | HP LaserJet 3390 All-In-One Printer
Print spooler error
reinstal the driver with print spooler running, good luck
Apr 06, 2010 | HP LaserJet 1020 Printer
Print spooler unable to connect tp printer,cable
Print internal configuration page and check for IP address in printed sheet and try to compare with the driver information
Check for LED at network card if it’s on
Try to send ping command to IP address to verify connection and if reply is confirm
Uninstall driver and reload and try to search the printer with IP or hardware address while loading driver
If still any problem it could be network card have problem need to be replaced
Nov 07, 2009 | HP Color LaserJet 2600n Printer
My HP laserJet 2200DN doesnt feed paper when printing.
it could be hardwre problem.. you need printer technician to replace some broken parts
Aug 25, 2009 | HP LaserJet 2200dn Printer
Network printer will not print
Hi Savo,
Is printer being recognized by network? What does device manager indicate? If there is a Yellow exclamation point, you need an updated driver. Try uninstalling software, removing access cable to printer and reinstalling software then re-connecting printer cable.
Jan 17, 2009 | HP LaserJet 4200tn Printer
Cannot print on shared printer
I had the same problem with HP 1018 printer, when I had two computers connected to a domain and had Windows XP SP3 on them and when I shared the printer on one of them - I could only print from the network if the user belonged to the Local Administrators group on the host/server computer. Once the network user is removed from Administrators - the print jobs are stuck in print queue. I used the "HP LaserJet Host Based Print Driver Package" that is on HP web site for HP laserjet 1018 printer.
Then I tried to use a different driver for that printer and was successful with driver for HP LaserJet 1020. After forcing that printer to use the 1020 drivers, the regular users were able to print to that printer.
Oct 26, 2008 | HP LaserJet 1018 Printer
Hp 4250n, 49.4c06 service error message
Hey guys
same error
start
run
cmd
net stop spooler
goto windows explorer
C:\Windows\System32\spool\PRINTERS
delete all print jobs
back to cmd window
net start spooler
hard power reset printer
error gone all working again
Jul 31, 2008 | Konica Minolta magicolor 2400 Laser...
HP LaserJet 2200dn Printer Logo
1,209 people viewed this question
Seeker5211
Seeker5211
