Question about E-Machines T2341 PC Desktop
Power switch got unpluged from motherboard. Tried to plug back in. But unable to see which one it goes on to?
Power switch got unpluged from motherboard. Tried to plug it back in. Unable to see which one it goes on?
    Problem Solver:
  • 14 Answers
If im not mistaken look at mother board and there should be a bunch of pins or jumpers towards the front of the case mine all line up in a row
Posted on May 22, 2009
No power when turned on - light green on back - no lights on motherboard - no fans
sunny,try with a other powersupply if possible.
faulty PSU are often the cause.
Jul 13, 2013 | HP Media Center m7250n (ED842AA) PC...
TV keeps knocking off all the time,now i can't switch it back on
Power supply should be looked at first--with model number visit shopjimmy.com who will have a list of all the boards used in this set.
Jun 26, 2012 | Samsung Televison & Video
I've got a Dell Studio 1735 that started to tell me the battery was on the way out after 18 months (maybe a bit more). One day the battery stopped charging and when it ran down completely it...
There is a short circuit on your motherboard. This is why the power adapter switched off (thermal cutout) and resets after you remove the adapter from the wall power outlet.
You need a new motherboard.
Aug 19, 2011 | Dell STUDIO 1735 Motherboard - H274K
I ran out of wild coins ani fergot my password so now I cant get eney
I am assuming by your description above is that you are unable to enter the system setup and bios because you have a password for the motherboard. If it is a motherboard password the easiest way to get back to the setup screen is to take the cover off look at the motherboard, you will or should see a round quarter size battery possibly two carefully take it or them out for ten minutes, unplug the PC then push the power switch on to make sure all stored power is expelled. Now put the battery or batteries back in, plug the pc in and turn it on you should be able to get back into the motherboard setup screen. Of course you will have to redo the password.
Mar 20, 2011 | Computers & Internet
My dell GX260 had a problem. I had taken the cover off and removed the slave switch and also removed the main cable running to the motherboard but forgot to remove the power cord. Once I plugged the cord...
Try to go back and place everything the way it was But always and foremost alwyas unplug the power supply first. once everything is back to it original state U plug it back . But always the Power plug should be the last part u connect. What is it that U were trying to do
Aug 12, 2010 | Dell Computers & Internet
Powers up but screen is black, so I am unable to see what is happening as far as window, or bios. Tried to connect vga connected monitor no picture either.
Try to drain the static in your motherboard. Please follow this procedure:
take out the battery
unplugged the power adapter
press and hold the power button for 30 secs
put the battery back in
plugged in the power adapter
turn on the computer
This procedure will darin the static of the motherboard. If same issue will happen then you need to contact your coputer's manufacturer for repair service.
May 29, 2010 | Computers & Internet
I have a dell optiplex sx280 computer and monitor that has lapsed into ''power save mode'' and I have been unable to ''awaken'' it (I'm not sure which is ''asleep'': the monitor or computer!) from sleep. I...
How's the status light of your computer monitor? is it blinking amber? and the status light of your computer tower's power button? blinking amber as well or solid green or no light at all?
1. Disconnect all the connection at the back of your computer tower
2. Press the power button of the computer tower for 15 seconds
3. Reconnect the power button and the monitor cable at the back of your computer tower and turn on the computer (if it turned on that means that one of the device plugged at the back of your computer tower is faulty)
4. If still the same problem, open up your computer tower.
5. Reseat the video card, Reseat Hard drive, Reseat Memory, Reseat CPU, Reseat power cord coming from the CPU to your computer (doing all things one-by-one to pin-point the root cause of the issue)
If none of the troubleshooting steps fixed the problem, possible that the power supply is faulty and if the power supply is faulty sometimes it goes with the motherboard.
Jan 08, 2010 | Dell OptiPlex SX280 PC Desktop
Hp Pavilion a350n shutdown and will only boot up to a blankscreen, (no Windows logo) there is not beep, no indication of any problem, power is good, video card is good (tried three cards), switch monitors,...
I assume by power is good you mean when you press the power button on the pc it spins up.
1) unplug all the components such as hard drive, floppy and USB from the motherboard.
(so you should only have the VGA, monitor and motherboard with RAM and CPU.) turn it on and see if you get a screen. if you don't there is possibly a problem with the motherboard.
if you do get some display on the screen 2) switch off and plug in one component at a time and then switch back on. if it works turn it off and plug in the next component and turn it back on. repeat until you find the faulty component that cause it to not turn on.
Dec 16, 2009 | HP Pavilion a350n PC Desktop
PC won't power on. Compaq SR5410F
IF you have another power supply you can use, try it and see if the computer will power up.
Oct 29, 2009 | HP Compaq Motherboard
My tower has power but won't come on
first guess is the motherboard is bad
a few things you can try:
unhook the monitor from the computer and test it on another computer. If the monitor works then its most likely the motherboard.
leave the computer unplugged for a few hours then plug it back up and give it another try just in case it overheated.
have the computers power supply tested as a bad power supply can cause all sorts of issues.
other than that you are down to a new motherboard and or a new computer.
Sep 09, 2009 | Compaq Computers & Internet
E-Machines T2341 PC Desktop Logo
37 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
