Question about Kenmore Elite 45986 Front Load Washer
Kenmore elite washer error dp - Kenmore Elite 45986 Front Load Washer
jgwhomeequip
  • 1902 Answers
SOURCE: Iget a f-11 trouble code on my kenmore elite he4t washer.
REplace your MCU. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem. Go onto kenmore.com and find your right washing machine and replace the part yourself. First try and take the wiring harness off and then reconnect it and see if the error code goes away if it doesnt then replace the part. Please Rate. Thank you
Posted on Feb 12, 2009
  • 949 Answers
SOURCE: Kenmore Elite error message F 02
Here is what the manufacture says about F02 - Below this are my comments
If the drain time exceeds eight minutes, the water valves are
turned off and “F/02” is flashed.
Press PAUSE/CANCEL two times to clear the display.
NOTE: After four minutes the “Sud” error will be displayed,
then four minutes later the “F/02” error code will be
displayed.
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make
sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in2_bing.gif washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Phil's comments---->
If you washed a rug with a rubber backing or small articles like baby socks you may have a plugged up pump. To access the pump lay on the floor and remove the 3 screws holding the lower panel of washer on. Pull down and out on the panel to remove. Lay out a lot of towels under the unit, I mean a lot... Look in the center for a white cap about the diameter of a large cup, it will have a handle on it to turn, turn this left(counter clockwise) to unscrew. This will unscrew and pull out, but be careful when it comes out so does all the water. Clean out the trap that is in your hand and anything you see or feel in the sump area the trap came from. Reassemble and test. If this does not work you will more than likely need a new drain pump, that is the component on the right of that trap you just cleaned out.
Posted on Apr 20, 2010
Testimonial: "You are a Guru! Thank you so much for informing us about the "hidden" trap which housed an ankle sock, .90 & lint! works like a charm now!!"
kapishtech
  • 2272 Answers
SOURCE: Kenmore Oasis Elite Top Loading Washer with an F2 error
The F02 error code indicates keypad/user interface failure. Most of the time, this is caused by a problem in the keypad/user interface. It can sometimes be caused by a failed control board.You could have an intermittent problem such as a stuck key or contact. As long as the F02 is not displayed, the washer should work normally. You can continue to use it when the F02 is not displayed. It is still safe to use the washer.
Sometimes this problem is caused by a loose wiring harness connection between the keypad/user interface control board and the machine control board.
The F2 error code on this washer indicates a stuck button on the user interface control board. The procedure for accessing the control boards on this washer is shown in the image below. I recommend unplugging the washerand checking the wire harness connection from the user interface control board to the machine control board. Try unplugging the connections and then plugging them back in a few times. Make sure that they are plugged in correctly and then reassemble and test the washer. If the F2 is still displayed, then the user interface control board will need to be replaced.
CLICK ON THIS LINK TO GET THE INSTRUCTIONS HOW TO REMOVE CONTROL BOARD:--
http://media.fotki.com/1_p,wfbgkftgqtgssggxgtqsskgwtqkq,vi/gdqwksfbdxggskbksbb/1/1303472/5961857/image8028img-or.gif
You can order a new user interface control board from the Sears PartsDirect website or from----------
www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Jul 26, 2010
blueextc3221
  • 15935 Answers
SOURCE: kenmore elite he5t steam washer has a suds error
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
The "SUDS" or "SUD" error can be caused by too much detergent, improper detergent, drain pump/drain line problem, or pressure switch malfunction.
1. If you are not using HE detergent, you need to be. These washers are designed to use HE detergent which is formulated for wash tubs that use 5 to 7 gallons of water. If you use regular detergent, you are, in affect, placing a higher concentration of detergent in the washer that is normally formulated for wash tubs that have a 35 gallon capacity. The manufacturer should have a disclaimer in the owner's manual explaining this. In most cases this will also void your warranty. NOTE: Prolonged use of the wrong detergent can damage the drain pump components and or wash tub seals.
If you are using the correct detergent, double check the label to make sure it is not double (2X) or triple (3X) concentrated. You could still be placing too much soap in your wash.
To get rid of excessive detergent, place the washer on a RINSE & SPIN cycle, then run it through a normal wash cycle with NO detergent added. You may have to repeat these steps depending on the amount of detergent used.
2. If you do not have a detergent issue, double check the drain pump and drain lines to ensure they are not obstructed in any way. Click on the following link for step-by-step instructions:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
Obstructions in the drain pump and/or drain lines can attribute to air getting trapped in the drain pump and cause the error code. Double check all electrical connections to the drain pump and Central Control Unit (CCU). You will need to remove the top panel of the washer to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top panel in place. With the screws removed, slide the panel back, then off. The CCU is located directly behind the wash tub in the center of the washer. The Drain Pump connector will be the 6th connector (facing from the front L to R) in the center of the CCU.
3. Check the Pressure Switch to ensure it is good. The Pressure Switch is located to the right of the CCU as you are looking from the front. It is a small cylindrical shaped device with a connector plug and an air hose attached. The switch can be checked at several water levels by removing the plug and taking resistance readings at the connector pins. Readings are as follows:
(Pins are numbered R to L facing the from the REAR)
Pins 1 to 2 (SUDS Detect) - 0 ohms
Pins 3 to 4 (Overflow) - 0 ohms
Pins 4 to 5 (L1) - 0 ohms
Pins 4 to 6 (Empty) - 0 ohms
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 23, 2010
blueextc3221
  • 15935 Answers
SOURCE: What does a F12 error mean for a Kenmore Elite Frontload Washer
F12 isnt an easy code to diagnose. It means the mcu isnt communicating with the ccu.
The problem could be the door lock or either board. I would recommend calling a tech out.
It is similar to the F11 error - see the following.....
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    Keeps Stopping and saying UE
    uE error code 79631512210 Kenmore Elite Washer - Sears ...
    www.searspartsdirect.com > Ask an Expert
    Jan 10, 2014 - uE error code 79631512210 Kenmore Elite Washer ' SearsPartsDirect. ... After unloading the washer completely, the machine attempts to rebalance the .... to ensure proper fit and to keep appliances running for years to come.
    UE Error code on my front loading Kenmore washing machine
    www.shopyourway.com > Manage My Life > Questions
    Jun 13, 2011 - I have a Kenmore 3.5 cu. ft. front loading washing machine (model #4027) and it is 1 year old. ... what does the F35 error code on my kenmore elite front loading washing machine mean? F13 code on Kenmore Elite HE3 front loadingwashing machine.
    Jan 21, 2016 | Kenmore Washing Machines
    F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
    what's f24 code? - Kenmore Elite HE3 Washing Machine ...
    https://www.ifixit.com/Answers/View/85549/what's+f24+code
    iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
    F24 Error Code on My Kenmore Washer ' eHow
    www.ehow.com > Home
    F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
    Kenmore HE2 Plus Front Load Washer F24 error code ...
    www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
    ...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
    I have a Kenmore HE2T error code F24 - Fixya
    www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
    Dec 9, 2009 - Posted on Dec 09, 2009.
    Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
    What is an F7 error code for a Kenmore Elite front Load washer
    Here is a real good list of error codes.
    https://www.facebook.com/permalink.php?story_fbid=335666283212204&id=232446733534160
    Washer Error CodesBelow is list of Elite Appliance Service LLC Facebook
    Jul 11, 2014 | Kenmore Elite 45986 Front Load Washer
    In mid wash the Kenmore Elite Oasis HE flashes F51 and
    check if basket turns freely. if it does replace the main board
    Jan 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
    Error F51 for Kenmore Elite Oasis Toploading washer??
    bad main board or motor possitioner sensor.. most likely motor sensor.
    China made junk parts with a million problems
    Nov 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
    Kenmore Elite Catalyst washing machine getting error F4
    See if this helps.
    http://www.askmehelpdesk.com/appliances/washer-kenmore-elite-catalyst-110-20092993-f3-f4-error-codes-191730.html
    Aug 01, 2009 | Kenmore Washing Machines
    Kenmore Elite 45986 Front Load Washer Logo
    23 people viewed this question
    Sal DeAngelo
    fordexpert
    Ed Mac
