Question about HP Pavilion dv9715nr
HP DV9715NR laptop starts up and shuts down as fast as it starts up
When I turn on my computer it powers up and then powers down it will not boot up and stay up. What would be the cause. I need help...I have tried everything that HP suggested to troubleshoot.
    Problem Solver:
  • 6 Answers
These older HP laptops are notorious for overheating. Heat is the #1 enemy for computers.
If it turns off right away, you could try opening the laptop up, cleaning the dust and lint out and replacing the thermal pads. OR even using good thermal past instead of pads. And use a laptop cooling pad. That should work.
If it turns on but no video then the Video chip needs to be reflowed. The heat has caused the Solder to melt and not make full contact with the motherboard. But this fix usually lasts a couple of months. It's just a bad cooling design, these older computers with two chips, one processor and one Graphics are the problem. The graphics chip especially produces way too much heat for the tiny heat-sink HP decided to put in the DV Laptops.
I've had both a DV9000 and DV6000 and both had the same issue with the graphics chip producing way too much heat. The newer laptops with Intel i3, i5, i7 and AMD A4, A6, A8 chips and the like, have the graphics integrated with the processor and heating is no longer an issue.
In my opinion they are not worth fixing. I would take out the Hard Drive and put it in an external enclosure to pull all your data out. You can then reformat it and use it as extra external drive. I would just invest in a new or used computer that uses the processors that combine both the processor and graphics in one chip.
You can still find the old type like Pentium and Celeron computers but they are slow and still use two separate chips. My 2 cents, and then some lol. Good luck.
Posted on May 18, 2014
    Guru:
  • 219 Answers
I'll help YOU to fix problem REMOTELY Please feel free to contact me anytime via e-mail at besubmitbe@gmail.com, or on Skype at bpshbp
Posted on May 24, 2014
SOURCE: Laptop will not even boot up, won't turn on
Reseat the battery and connect power directly to laptop. Avoiod a docking station.
This should resolve the issue
Shimagoza
Posted on Feb 18, 2008
  • 64 Answers
SOURCE: hp laptop keeps restarting
If the laptop is not popping up any windows before it shuts down it could be the built in heat protection, you can see if your fan has a lot of dust by turning off the laptop off and then blowing into the area where it pulls in air. If it is popping up a window before it shuts down disconnect it from the internet and see if it does the same thing, if it stays on while discod from the internet then run your antivirus if possibl.
Posted on Mar 07, 2009
pontelemon
  • 531 Answers
SOURCE: laptop wont boot and the battery and power lights flash
"......no beeps and it is a 3rd party charger for this model of laptop."
That 3rd party adapter could be the problem. Also, try to take out the battery and power it up from AC adapter only.
Ideally, try to find original AC adapter just for testing.
Posted on Apr 16, 2009
  • 54 Answers
SOURCE: HP 6910p will not boot upon restart. If the
seems like there is some s/w glitch in it. try to create a new admin a/c. hopefully it will fix the problem.
Posted on Apr 29, 2010
  • 54 Answers
SOURCE: HP Pavilion dv9000 laptop computer will not stay
Restart the notebook, press F10 and check if you see the BIOS screen or not.
If you see the BIOS screen and if the notebook does not restart in BIOS then this could not be a hardware issue.
But if you do not see the BIOS screen, then perform the steps below :
1. Disconnect the ac adapter and remove the battery from the notebook.
2. press and hold the power button for 30 seconds
3. replace the battery and connect the ac adapter
4. turn On the notebook and check
If the issue persists then remove and replace the memory modules of the notebook and check it.
If the issue still persists then it could be a hardware issue and your notebook needs to be serviced.
Posted on Jun 13, 2010
Open hp pavilion dv9715nr laptop
Uninstall them. Go to control panel, uninstall a program. Better yet, use the free version of revo unintsaller. Search for it at Google, you can't miss it.
Oct 08, 2013 | Computers & Internet
MY COMPUTER SAYS WHEN TURNED ON "THE FILE IS POSSIBLE CORRUPT. THE FILE HEADER CHECKSUM DOES NOT MATCH THE COMPUTED CHECKSUM" WHAT DOES THAT MEAN?
Check to see if the following helps.
Method 1: Unplug any external device connected to the computer except for keyboard and mouse and check if the issue persists.
Method 2: Try performing a startup repair and check for the problem.
Method 3: Try booting in safe mode and check for the issue. If booting fine then you may try the clean boot procedure to find the cause of the problem.
Jan 13, 2011 | HP Pavilion dv9715nr Notebook
Cant turn on computer starts up but then immediatley shuts down
Try F8 at boot to make it boot into Safe Mode. If it runs okay in Safe Mode and the device manager shows no issues, then Windows may need a repair/restore run on it. If it still shuts in safe mode, it may be a power supply/battery issue.
Sep 02, 2010 | HP Pavilion dv6000z Notebook
My hp ez4400 starts up but quickly shuts down ,
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
If this did not work, try also disassembling the laptop & make sure that all main components are seated properly. Also make sure that all ribbon cables interconnecting the various components of the laptop are tightly connected.
Dec 28, 2009 | HP Computers & Internet
Laptop won't boot up
That shouldn't affect the laptop booting, hold down the power button for 10 seconds, it shoul boot up., if not then remove the battery and replace it. then try it again, good luck, Gym
Dec 18, 2008 | HP Compaq nc6000 Notebook
RE HP Pavillion ZE4800 Laptop When I switch on I here the fan start, the lights come on then it appears to shut down and re attempt to start again This occurs over and over and the PC never boots fully....
I have same notebook and similiar problem. Mine runs for 30 min then shuts off completely in like 20 seconds. I added a $10 usb powered laptop cooler pad and bingo, runs now for hours no problem. On all computers I know the cpu heat temperature has a threshold, if it goes too high it will shut off. I think my fan doesn't kick on fast enough to lower the temperature and cool the processor. On yours it may be a fan that doesn't work or is working at the wrong time and the circuit shuts off the system. Shouldn't be terribly expensive maybe $60 to repair from a good technician..good luck
Aug 15, 2008 | HP Computers & Internet
HP Pavilion dv9715nr Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
