Got a ls320em1 emerson tv volume goes up n down by its self bt has good pic wat do i do
2 Suggested Answers
danbusa
  • 185 Answers
SOURCE: I own an Emerson 37inch
Hello! Your tv controls the volume if it jumps up to 60 after moving down it may be interference with the TV's remote sensor. Has anything changed i.e. new lighting ? Try calling Emerson at: 8002562487
Daniel Busa
DISH Network Customer Service
Posted on Jan 18, 2011
Volume keeps going down to zero
Emerson volume keeps going down Questions & Answers ...
www.fixya.com > Forum > Tags > volume keeps going down
Emerson volume keeps going down related problems. Ask your Emerson ... myEmerson TV. It turned itself down to zero and stayed on the screen and wouldn.
Emerson Flat Screen TV volume trouble? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Aug 10, 2011 - My Emerson 32 inch does similar things, volume just goes to 0-100 and stays there. ... Why is the volume on my Emerson flat screen TV not working and how could i fix it? Whats wrong with my Emerson Flat screen tv? Why is the volume on my Emerson flat screen TV not working ...
Jul 13, 2013
My son has an Emerson tv it keeps turning down by itself. Anyone ...
Aug 24, 2006
More results from answers.yahoo.com
Emerson TV problem ' Techlore
Dec 15, 2015 | Emerson Televison & Video
How can I fix volume control
How do I stabilize volume on a television? : hometheater
https://www.reddit.com/.../how_do_i_stabilize_volume_on_a_tele...
RedditAug 31, 2014 - We have a Samsung Smart TV - 52". My mom is a hardcore movie watcher, and I have very sensitive hearing. It's a constant battle because I'm ...Missing: lc320slx
Funai Emerson LE220EM3 Owner's Manual - ManualsLib
www.manualslib.com > ... > LCD TV > Emerson LE220EM3
Emerson LE220EM3 LCD TV pdf manual download. ... LCD TV FUNAI LC320SLXService Manual ... Model # Screw dimension •. ... Tv, Switching On Your Tv And Putting It In Standby Mode, Adjusting Volume, Switching Channels ... Clock setting tostabilize the PC screen and Phase Canadian French rating, then press OK.
Nov 26, 2015 | Sylvania Televison & Video
The volume onmy Emerson TV turned down to zero. I turned it up with the buttons on the TV it turned back down to zero. The zero volume stayed on the screen.I turned the volume up withremotenoresponse.
The main system control memory IC to this TV is damaged. Replace it. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 27, 2015 | Emerson Televison & Video
My emerson ls320em1 has good pic bt the volume goes up n down by it self
Does this happen while watching a program or just when changing channels? Most cable companies are notorious for not balancing their sound levels form channel to channel. Same applies to off air programs too Make sure the connecting cables have a good connection and are of high quality. Anything else is in the tv itself.
Jan 03, 2014 | Televison & Video
Emerson tv
OPEN THE remote control, and clean the keypads from dirty, corrosion , bad contacts. Please do the same with the contacts batteries, and replace by new ones.
God bless you
Jul 08, 2013 | Televison & Video
My emerson tv keeps turning the volume up and down by itself
There is an IC inside the set that is suppose to control the volume and maintain the level it is set to and not let it get to high on commercials or to low in love scenes.this IC has gone bad, common problem in Emerson. IC isn't very expensive, although sometimes it's in with other things on a 64 pin IC. Little tiring desoldering and soldering it back in.
Gillight
Jun 22, 2012 | Emerson Televison & Video
I have a emerson LC320EMXF 32 in tv and the volume goes up and down on its own. Will someone help me with problem.
If it only goes up or only down that is fairly easy to find.
if goes up and down both what is hooked to it for signal and how--cable etc and via rear jacks or coax fitting from (are you using a box?)
A simple test is to connect a DVD etc. to one of the rear inputs and see if same problem that way.
Apr 17, 2012 | Emerson Televison & Video
My 19in lcd hdtv emerson wont stop turning the volume down by its self.And then i took my batteries out of the remote and it is still doing the same thing. i cant even press buttons on the remote. Also...
See if the minus volume button on the TV is stuck. With the TV off press the various buttons while keeping your ears close to them. Each will produce a distinct click when you press them, confirm if the volume - key also produces the same sound - if not the key is defective or stuck.
Jun 02, 2011 | Emerson LC320EM8 32 in. LCD TV
I own an Emerson 37inch tv modelnumber EWL3706 AND SERIAL NUMBER J33615468 LAST NITE THE VOLUME WAS AT 26 AND ALL BY ITS SELF WENT TO 60 IT WONT GO DOWN NOT WITH REMOTE OR ON TV ITSELF I UNPLUGED IT AND...
Daniel Busa
Jan 14, 2011 | Emerson LC320EM9 32 in. LCD HDTV
Volume up then pic gone
Good Day;
The TV's front panel may be bad, manual buttons. TEMPT FIX; remove speaker, cloth covered, cover, disconnect cables. TV will work but only with remote.
Good Luck!
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
