I have a C43SC printer and a C41 and they both now have a message that the sponge is full. Can I restart them without having to throw them away and add to landfill? Thanks - Frances
  • 4 more comments
  • septiccare May 22, 2009
    Hi guru - I am only using the C43SX printer. The message on screen says that the sponge is full. That is what happened on my previous C41 and it just stopped also. As I still have plenty of ink cartridges left - if I can fix the C43SX somehow, then I can do the same with the other one and keep it as a spare - at least until I have used all my inks up.
    I m sure it is nothing to do with the cable connection.
    Frances
    Hi I know the problem with my Epsom C43SX printer is that the ink sponge is full. How can I bypass the counter to get my computer to work again. It was printing perfectly when it just stopped and the error message said the ink sponge was full. Frances
    Hi Benimue - I have downloaded the SSC utility, but being non techno don't know where to go from there. Can you spell it out a bit more for me please - treat me like a dummy! Thanks - Frances
    Hi Benimur - I followed your instructions, but still have the red and green lights flashing. Any more ideas? Thanks - Frances
  • septiccare May 23, 2009
    Hi Benimur - I had to race out and buy another printer (HP Deskjet) as I had invoices to get out. Have just installed that and used it to print out the illustrated instructions to clean the ink pads for my other two printers. With luck I can get those two old ones going and at least use up all my stocks of inks. Thanks for your assist. Will let you know how I get on with the cleaning process. Regards Frances
    Hi Hotratchet - I tried to reset the counter and it didn't work. I'll try to clean up the sponge from the illustrated instructions and let everyone know if it works. As we live in a rural area it costs too much to get repairs done because of the mileage so I guess I'll have to learn to help myself.
    Thanks for your assist. Frances
    President:
  • 2,187 Answers
It depends on how much the sponge have soaked up but you may still reuse it.  I found the link below very useful when I had the same issue.  The english text are just towards the lower part of the page.
Printer Sponge
Another solution is to divert the waste in to a container but this may have implication to your printer's warranty.
Posted on Jun 15, 2009
  • 749 Answers
Hi, just look in your manual, you will need to empty the ink sponge.
Posted on May 23, 2009
  • 952 Answers
Hi Frances... Your problem is simple... all you need to do is to reset the printer's print counter... your printer is programed to be serviced after a certain number of print count. You probably have reached the limit. All you need to do to get rid of the Sponge is full message is to reset the printer's print counter. pls visit http://www.ssclg.com/epsone.shtml and download the couter reset tool. (you need to reset the waste ink counter)
Take note, you may need to change the sponge that absorbs waste ink so that your printer's waste ink storage will not overflow. You can have a technician do this for you or you can just probably search the forums from the link that I gave you.
I've had the same problem before but this tool helped me, i do hppe that it helps you too. have a great day
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
To address your concern and reset all counters, download and install Epson SSC Utility. Of course the reset / bypass must be done at your discretion and it would not matter whether the ink waste pads have been replaced or not.
Good luck and thank you for using FixYa.
Posted on May 22, 2009
  • 1 more comment
  • Louie  Role
    Louie Role May 22, 2009
    Soon as you have downloaded sscserve.exe, double click on it to initiate the installation:
    • a security warning question may appear asking permission to run the software, answer "Yes" or click on "Run";
    • a confirmation dialog box will appear"This will install SSC Service Utility. Do you wish to continue?" click on "Yes" button;
    • on the Setup box/window, click on "Next" button;
    • tick "I accept the agreement";
    • click on "Next" button;
    • click on 2nd "Next" button;
    • click on 3rd "Next" button;
    • click on "Install" button;
    • click on "Finish" button;
    • once the software/utility is running, in the Configuration tab, check "Disable Epson Status Agent";
    • select "Installed Printers";
    • select "Printer mode:";
    • right click on the SSc Service Utility icon bottom right side in the Systems Tray;
    • click on "Reset Counters" and then "Reset all counters";
    • click on "Protection Counter" and then "Reset Protection counters";
    • all others, please follow on screen instructions.
    Cheers.
  • Louie  Role
    Power off the printer. Shutdown the computer. Restart /reboot both printer and computer.
  • Louie  Role
    This illustrated instruction "how to" on the use of the Epson SSC Utility and addressing the waste ink pad might be of better help.
  • 3,230 Answers
First of all tell me that -
are you using both of tham in a single computer?
if yes than you need to reinstall the driver.
also do some basic check licke printer port (or usb where you connect that printer). and check the printer cable.
THanks
  • Mukesh Kumar May 22, 2009
    Ok..
    You try unstalling the printer driver and than restrt your computer after that again install the driver of your printer.
    post comments for more help..
    Thanks
Evolis dualys 3 out of papper
a) Clean the printer
b) Print
Persistence: Probably sensor of the feeder has a problem.
Always good to restart everything, in case Windows plays tricks on you. ;)
Jan 31, 2013 | Evolis DUALYS 3 ID CARD PRINTER
Every time I turn on my printer I get the message: The waste ink absorber is almost full.Press the printers start button to restart printing. This is not a big deal to do but I'd rather not fuss with...
The waste ink absorber is the place where the head rests to the side of the printer (under where the heads are when you change the ink). There is a way to empty them.
Call a print job. When the heads move away, gently stop them with your hand. They should stop, and an error will come up. Soak up the sponge in the original location with a paper towel. Then reset the printer, and the heads should return to normal, hopefully without the error message.
Mar 10, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Message coming on saying waste tank full contact supplier
HI!
Honestly?You can throw the printer away and buy a new one as it will be cheaper and easier on the pocket!!!
Good Luck!!
Jan 22, 2011 | Canon i350 InkJet Printer
C41
call service c41 - message;
time for maintenance -message
to continue
press the number 8 and 0 at the same time and turn on the copier, the put the number 400 and press enter, change the value to 0 and press enter, turn off and wait 30 seconds then turn on
Nov 29, 2010 | Toshiba e-Studio 205 Copier
Unable to clean cartrigde
The problem is due to the fact that Brother machines excessively self-clean. Each time they self-clean a small amount of ink is dumped in to a holding tank/sponge. When a predefined number of self-clean operations have been performed, the machine refuses to print and gives the error message you have stated. Brother state that the tank/sponge must be replaced before the counter is reset, again by a Brother agent.
However, there is a way of reseting the self-clean counter yourself - if you Google your model number and the error code somewhere in the results you'll find how to do it. The only risk of doing this without changing the tank/sponge is that it will eventually overflow and leak out the bottom, but I did my Brother all in one some time ago and have had no problems yet.
Jul 13, 2010 | Brother MFC-5440CN All-In-One InkJet...
Brother MFC-465CN printer. Need a fix for error 46.
Jul 09, 2010 | Brother MFC-465CN InkJet Printer
What does Waste Ink nearly full mean? Canon MP370
If you peel enough apples, and throw the "waste" apple-peel into the basket, eventually the basket gets nearly full, and must be emptied.
Similarly, if you print enough pages, some of the ink becomes "waste",
and that "waste-ink" goes into a small sponge-and-bucket apparatus.
So, take the printer to a qualified technician, and get the printer serviced.
Nov 23, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
The waste absorber is almost full. Where is it? Where do I get one? How do I change it?
The waste ink absorber is a small sponge located right underneath where the print head parks when the printer is at rest. Difficult to get at!
However, Open the printer lid as if you are going to replace a cartridge. You have to be very quick now. As the print head moves over to the left hand side of the carriage pull the power cord out . The carriage will now stop well away from the parking area and you will have enough room to work. You will get ink all aover your hands so be propared.
Get some heavy duty kitchen towel (the kind Costco sells) and a bright lamp. Use the lamp to illuminate the parking area (it's normally under the cover so it's always a bit dark) and yu should see the sponge all black and yukki. Use the paper towel and press it into the sponge. Do it over and over again with a clean bit until the towel is coming off fairly dry (it can take a while).
When you think you have it clean, power the printer up again and see what happens. You may still get the error message but the printer should work. If it doesn't, you'll need to reset the message. Do a google search on resetting the message as I can't remember what it is.
Sometimes, you can get the piece of sponge out of the printer with tweezers or watchmaker's pliers. Wash it under running water until it is clean then dry it as best you can. You will still have to mop dead ink out of the sponge's home and you may have to use damp paper towel initially. Once you think it's all clean wriggle the sponge back into place and carry on as aove.
Good luck
Nov 11, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Error 6a00
I found numerous suggestions on FIXYA for other Canon printer models with the same 6A00 error message. The isuggestions mainly zero in on the purge station where the printer head parks and possible cause being bits of jammed paper at the two pieces of sponge material. There were several reports of cleaning the two sponges at the purge station and the problem going away after. I checked my printer but did not finad any jammed bits of paper. But I found the purge station was a bit up and could be pressed down - probably a bit sticky due to the soaked sponges and not returning to its original position. After that I didn't get the error message anymore. The two sponges on my printer purge station were black and possibly soaked with ink and I am thinking of cleaning these the next time.
ur flashing lights also seem to be a cnsequence of this....
hope it helps.... good luck
have a nice day
Jul 08, 2009 | Canon iP4500 Photo Printer
Help with absorber
Someone else asked same question on this site and got answer:
http://www.fixya.com/support/t198707-ink_waste
I also had that message. This seemed to work to clear the message and let you carry on printing.
Also, I may be wrong, but the actual ink absorber is the sponge part by the rollers underneath when it prints. I dont know if it has sorted the actual problem, but I took the sponge part out (I have an MP130 and the sponge part lifts straight out if you carefully put your finger underneath it on the left hand side) and let it soak in water, sqeezing it to get the ink out (It was full of ink so careful not to get it everywhere as it can be a little messy). When it had dried, I carefully put it back in (make sure you put it in the right way around).
Hopefully that now means the ink absorber is again empty AND the error message has gone.
Not sure about the whole cleaning the sponge idea, but I did it and according to the manual that sponge is labelled as the ink absorber so technically I have emptied it?
I haven't seen any posts about actually cleaning the sponge so take that part as you will.
Dec 18, 2007 | Canon PIXMA MP130 All-In-One InkJet...
202 people viewed this question
k24674
jasbo
jasbo
