Question about Dishwashers
Ls12 dea601 Machine fills and heats but no water through wash jets
Rotu
  • 175 Answers
SOURCE: washer
If I'm not mistaken, these dishwashers are built by Asko for Viking. If thats the case then you probably have a bad circulation pump. Under Asko's warranty (not sure if Viking is the same) these pumps are covered parts and labor for 3 years from installation date, and 5 years for the part only. The pump is accesed from the back of the machine,so you have to pull out the dishwasher. Then you remove the lower plate in the rear and the motor at the very back center is the pump. You remove it by turning it about a 1/4 turn either clockwise or counter clockwise, depending on the style, then place the new one in and turn it to lock it in place, being careful that the sealing oring stays in place or youll get a leak. The part will probably cost you around $150 unless viking marks theirs up more than Asko. Good Luck!
Posted on Nov 23, 2006
SOURCE: indesit w93 washing machine fills with water but doesn't start washing
Hi there. I have an old model, the indesit WM12. Never counted the flashing light (yours was 10) but my dial started clicking constantly at the drain part. I called Idesit and they told me it was a blockage in the filter.
The filter they speak of it located, on mine, at the front of the machine at the very bottom on the right. It is a black dial about 3 - 4 inches in diameter. Unscrew that anti-clockwise (a real pain because so much water comes out. My wife and I unscrewed it, filled a baking tray with water, screwed it back up, emptied / substituted tray then same all over again - until empty. Though putting it on drain again and again helped at same time). When I pulled out the filter found a 'colour catcher' sheet in it. We used them first time ever the other day. Removed that, gave filter a wee clean and, hey presto, all is working again. Hope that helps. Jim
Posted on Feb 27, 2008
yalmer
  • 552 Answers
SOURCE: Filling With Water
This is probably a control board failure, which should be replaced by someone familiar with them.
If you are handy, you can do it yourself.
If you need assistance, let me know.
Posted on Mar 04, 2008
  • 86 Answers
SOURCE: Washing machine won't fill up with water
Hi can you tell me the make and model of the machine and if it makes any noise when it is trying to fill?
Then we can fix it!!
Posted on Feb 15, 2009
SOURCE: washing machine zanussi jet wash
unplug machine turn water off then take water pipe off machine,take machine outside and lay on its back,there is two moters up in the top right off machine looking in the bottom of machine, undo the three pipes and two/three srews take both pumps out undo three screws on the top pump split it and unblock then pup it all back.remember to right down wot you have done to pup it back right,it took me approx half hour to fix mine
Posted on Feb 28, 2009
I have a Whirlpool dishwasher Type 583-1 Model WDT720PADM2. It is suddenly not washing or drying well. Leaving bits of food and layer of film on dishes/glasses. Soap is sometimes not dissolved.Help!
Assuming the machine fills and drains water ok, and is heating the water too, and you can hear the circulation pump running during the wash, the most likely problem is blocked jets in the spray arms. You have to remember that a dishwasher is NOT a garbage disposal unit, and plates must be scraped clean before they are put into the machine for a wash. Bits of uneaten food in the machine will clog the filters, coat the walls of the machine and work their way into the spray arm jets especially at the very ends. These end jets are the only reason the jets rotate, and if blocked the arm just sits still and poor washing results. Remove and / or examine the ends of the spray arms carefully - often fruit pips or pasta can be seen blocking the jets. Remove this with a pin and running water. Also then run a dishwasher cleaner through the machine, with No load in - do this regularly to reduce blockages and smells.
spray arms can be taken to pieces in most cases to clear blockages. Always use a top quality detergent in the wash for best results.
Feb 03, 2018 | Whirlpool Dishwashers
I have SE showing on my Samsung washer/dryer please respond with any suggestions
Samsung washing machine no workeing ? dL
The door was unlocked while the washer was running
dS
The door was opened while the washer was running
d5
FL
The washer failed to lock the door
Hr
Washer temperature control problem
Heater Relay Failure (on main PCB)
LO
The door will not unlock
5E
Washing machine has failed to drain the water
4E
Water fill time out
ND
Water Does Not Drain From Washer
NF
Water fill time out = No Fill
dE
Washing machine door detected as being open
UE
Washing machine has detected an imbalanced load
DC
Washing machine has imbalanced load and will not spin
3E
Motor fault detected
bE
Motor short error
OE
Washing machine has detected an overfill situation
LE
Water leak - Excessive SUDS - Bad water level switch
HE
Water heating error detected
tE
Water heating sensor (thermistor) error detected
IE
Water level sensor fault
CE
Abnormal water temperature detected
E1
Not filling in allocated time
E2
Pump won't empty - not draining
E3
Overflow - overfilling with water
E4
Out Of Balance (OOB) detected
E5
Water temp rising or falling too quickly
E6
E7
Pressure switch
E8
Temp too high on low temp washes
E9
Water leak, Water level has reduced
EA
Motor generator error
EB
Motor error
Sep 30, 2016 | Samsung Washing Machines
Hi my machine will fill with water then doesn't do anything for the whole wash cycle then will dran and spin but will not wash in the wash cycle
Hi, it could be your heater element is not kicking in and so its not heating up the water and not moving on to the next stage of washing. Best get the unit checked out.
May 03, 2016 | Washing Machines
My washing machine is incredibly loud when filling.The water coming in sounds like a jet engine.
Try closing the water valves a little at a time until it is quite enough for you. Do not close it completely.
Feb 23, 2016 | Washing Machines
Machine filling up with water but not starting hoover 750la
Did you try with temperature setting to the minimum?
Normally the machine needs to heat the water at programmed temperature before starts, it fails to do it because some issue on the heating system it would not start....
Nov 30, 2015 | Hoover Washing Machines
Cold Fill Washing Machine Does Not Get Hot
Do y7ou have 2 hoses at the back of the machine one for cold water and one connected to the hot water tap of the house. If not then you have a cold water in only. If you have 2 hoses have you connected the hoses into the machine correctly Have you checked to see if your machine has a heating element under the bowl for heating the water. As an appliance shop to verify if you have by the model number of the machine. otherwise you have a cold washing machine and unless you can plumb hot water to it that is all you will have.
May 29, 2013 | Siemens Washing Machines
Electrolux-Arthur Martin ASF 64013 My dishwasher shows a red light under the sign ->[. It does not wash properly, soap is not completely disolved and stays on the bottom. I haven't got the user...
do the basics first - check the spray arm jets are completely clear at the very ends, and machine filters are clean. Remember dishwashers are not garbage disposal units - ensure all food is scraped from plates before putting in the machine, or it will work its way to the spray arm jets.
Does machine fill with water, does the circulation pump run on wash, does the water heat up?
Does the machine finish the program in a couple of minutes before that symbol displays? it could be the program has aborted due to not draining well. But check the spray arms first as they very often become blocked and no longer turn.
Feb 03, 2018 | Dishwashers
Cold water fill does it heat to temputure requied?
If your washing machine has inlets for both hot and cold water, you should connect both if possible. If you can only connect cold water, the washing machine will still work and heat to the required temperature, but it will need to heat the water in the machine, so the wash cycles will take longer and it will use more energy.
If connecting a hot and cold fill washing machine with cold water only, you will need to connect a Y-Piece for it to work:
The tail of the "Y" attaches to the cold water valve on your pipework. You then attach both hot and cold water hoses to the branches of the "Y" and connect both hot and cold water hoses to your washing machine.
Please post back if you need further assistance.
Regards,
BElectric
Nov 25, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Zanussi jet stream iz16s tripping ouy rcd once filled up with
It would seem to me that the heating element needs replacing from the information you have supplied especially as it performs most of the other functions like filling and spin and drain.
Good luck
Mar 17, 2010 | Washing Machines
Dishwashers Logo
21 people viewed this question
Top Dishwashers Experts
