Question about LG Heating & Cooling
I have an Everstar air conditioner model R51I9/BGCE. the air conditioner stopped and the LCD indicates "P1". please help. also the water indicator light is on, where is the water tank?
Hi, the air conditioner stopped and the LCD indicator has a "P1". What should I do?
  • Anonymous Mar 16, 2014
    What is this code about
  • 3 Answers
Usually means that you need to empty the water reservoir, or that the bucket is not seated properly.
Posted on May 23, 2009
My Everstar mpm-08cr-bb4 stopped working and dislays P1
The P1 code means the lower water bowl is full.
Put a pan under it an pull the lower plug (some 10" below the upper drain plug that I hope you have a hose attached to.
Jul 07, 2009 | Heating & Cooling
Need owners manual for Everstar Portable AC MPM1-10CR-BB6
Needed the manual to clarify a P1 error message. Figured how to fix the error P1 on my own. there are two drains on the unit, one is always open as an overflow drip, the other at bottom of unit has a plug. I opened the plug at the bottom of the unit, drained the water, and the P1 error code cleared.
Jun 25, 2009 | Danby DPAC8020 Air Conditioner
My unit has a P1 error and has stopped
Pull out the water container. Make sure the black floater switch is not stuck or impedes from working properly. If this doesn't work, need to look at replacing this
Jun 25, 2009 | Heating & Cooling
Need manual for EVERSTAR model MPM1-10CR-BB6 air conditioner
This site has the manual. It doesn't state the same model, but it's the same manual.
http://www.supportuscenter.com/product.asp?specific=90
May 17, 2009 | Heating & Cooling
Everstar portable ac unit displaying error message P1. The unit turned itself off and will not come back on. It had no symptoms of not working well before turning off.
According to my Everstar manual, P-1 is a drainage problem.
EverStar owners manual pg. 16 -
1. Release the drain hose from the ruber clip and pull out the rubber plug, let the drain hose slant down to a water container.
2. Press the TURBO button on the unit control panel for more than 3 seconds and the WATER INDICATOR light begins flashing. It indicates the forced water drainage feature is activated.
3. Waiting until the WATER INDICATOR light stops flashing and there is no water flow.
4. After the water has drained, remember to secure the drain hose and plug in the upright position and clip it to the unit.
The unit will return to normal operation.
....I had to do this and it worked - Good luck!
Mar 25, 2009 | Heating & Cooling
Everstar Air Conditioner
probably, the p1 signals that the water pan is either full or not sitting properly. There is a small lever that it pushes when the tray is pushed in. It is a switch that might have pushed out of its housing. Mine had and I had to dissasemble the unit to get the switch back in place, then it worked fine. Good luck. Dean
Aug 06, 2008 | Office Equipment & Supplies
Everstar MPM1-10CR-BB6
Press and hold the turbo button while plugging in the unit. The AC will cycle through a few tests and mine showed that it had excess water. I have long vinyl tubing so the unit could drain outside the window but it thought whenever it would start or stop there was excess water (thus stopping the flow). I drained the excess water out of the line and voila
Jul 08, 2008 | Danby DPAC8020 Air Conditioner
PORTABLE AIR CONDITIONER (EVERSTAR BRAND)MODEL MPA08CR NEED HELP TO OPERATE THIS ITEM
IF ANYONE NEED TO SEE THE OWNERS MANUAL FOR THE
EVERSTAR PORTABLE AIR CONDITIONER MPM2 , MPM210CEBB6
MODELS # MPM2 - 10CE - BB6
MODELS # MPM2 - 10EE - BB6
MODELS # MPM2 - 10CR - BB6
MODELS # MPM2 - 12CE - BB4
MODELS # MPM2 - 12EE - BB4
MODELS # MPM2 - 12CR - BB4
YOU CAN E-MAIL ME AT - RICHCPZ@YAHOO.COM
I'LL SEND IT TO YOU IN A PDF FILE
(AS LONG AS I DON'T LOOSE IT IN MY COMPUTER )
Jun 21, 2008 | DeLonghi PAC85 Portable Air Conditioner
The directions have the steps to take when a "P1" error is flashing.
1) Remove the plug (the upper black plug not the lower) and attach the included drain hose.
2) Put a bucket under the hose.
3) Press the TURBO button for MORE THAN THREE SECONDS. The WATER INDICATOR will begin flashing telling the user that the FORCED WATER DRAINAGE feature is activated. You will even hear a little whirring noise.
4) Wait until the WATER INDICATOR stops flashing and no more water is flowing out of the drainage tube.
5) After the water is finished flowing, make sure that you FASTEN the DRAIN PLUG. Of course, failure to do this will flood the area.
6) The unit should now work.
You can also move the unit somewhere that you can remove the plug and let the water flow freely (you do not need to have it plugged in for this method) and once the water is finished, replace the plug and fire it up. It should then work correctly. It's also mentioned that the water should be drained quite often to prevent corrosion. I do it every few months and of course when winter approaches.
I like this air conditioner and have had really nice luck with it. A little loud but who cares. That's why there are SUBTITLES on the television.
Hope this helped.
RoC
Jun 17, 2008 | Danby DPAC8020 Air Conditioner
Heating & Cooling Logo
797 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
