Question about GE JVM1340AW/BW/WW Microwave Oven
Broken handle Need replacement handle and installation instructions
2 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: spacemaker xl microwave oven jvm1630
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
You'll need to remove the oven from the wall.
This is safer with two people and the installation instructions will be of great help.
You can download GE owner's manuals and installation instructions here.
Posted on Dec 13, 2008
The door doesn't open
please follow the instruction and fix it. God bless you
  1. Open leverCheck your microwave lever to determine if it is damaged. If it is broken, simply replace the lever to get your microwave door fully functional again.
  2. Door springResponsible for keeping downward pressure on the door hook, the microwave door spring can begin to malfunction. If this part is broken and prevents you from opening your microwave door, replacement is necessary.
  3. Door latchOne reason your microwave door may not open properly is a broken door latch. Located inside the microwave, the door latch manipulates the door hook to keep the door closed for safety and top performance. If broken, the door could become stuck in the locked position.
  4. Door hookIf your microwave door will not release properly, the door hook could be damaged. Located inside the door, the door hook is made of plastic and prone to breakage with extended use or age. As this part is unable to be repaired, the only option is to replace it.
  5. Button or button springIf the microwave door will not open, it could be an internal failure of the button or button spring. If it is determined that either of these parts is the source, both are replaceable and it is recommended that they be installed at the same time.
  6. Handle actuatorIf the microwave door will not open the plastic handle actuator could be broken. Connected between the door button and the door latch assembly, this plastic part could become damaged and brittle over time, which makes breaking inevitable. If this occurs, replace the handle actuator to get your microwave fully functional again.
May 28, 2013 | Cuisinart Microwave Ovens
Need to Replace Door Handle for KitchenAid Over Range Microwave Hood Combo KHMS147KSS
can u send me the pic of door and the handle of ur oven at khader_abu@yahoo.com........
Jun 01, 2008 | GE Advantium SCA1000H Convection /...
How do I replace a broken door handle on a GE Microwave JVM1631WB004?
First determine if you can get a replacement handle will you be able to remove the broken handle on your own and install the replacement or will you need the assitance of an experienced repair person.
if you have the tools and know-how to do thihs on your own determine ifyou can get a replacement door handle. Information on contacting GE for parts in Canada can be found here:
http://www.geappliances.ca/parts/index.jsp#3
You could also try their call center: 1.888.261.3055
Make sure you have your complete model number and description of your unit. Was not able to locate information for the model number you provided.
GE Global website can be found here. You may be able to find your model if you check on the website for the country of purchase.
Jan 30, 2011 | GE Microwave Ovens
Handle on Frigidaire Microwave broken, probably because of heat from gas burner below - this is a defect becaquse the microwave oven was manufactured to be built-in above range. Frigidaire has finally...
im kinda confussed as to why Frig would do that,,,
but if you send the model number im sure we can help
most times repacing the door is really just a matter of lifting it off the pin hinges after you have removed the vent
but i can be more clear with the exact model
Oct 28, 2009 | Electrolux Microwave Ovens
Need to replace broken door handle. Cannot get to screws inside door to release broken handle and replace with new handle.
Look for a removable insert around the inside window. If not there may be screws along the outside edges to separate the door sections. Eric
Aug 02, 2009 | GE JVM1650 1000 Watts Microwave Oven
My door handle is broken. Is it posssible to
You should be able to buy only the door handle and avoid having to replace the entire door. Appliancepartspros.com carries the handle. Just type in the model number you provided and look for item #3 under the parts listing. The part number and price varies based on the color you need. Make sure you order the correct color. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions, please let me know. I hope you find this information helpful.
Jul 06, 2009 | GE JVM1640 Microwave Oven
Jvm1350ww 002 Handle broken
The handle part number is WB15X335 and is available from a number of sources online. You can replace the handle alone, but you need to take the inside door panel off to get at the screws. It's been too long since I've worked on a GE to remember if you need any special tools (some ovens have security screws holding things together).
Apr 01, 2009 | GE JVM1350BW/WW/AW/SY Microwave Oven
Broken door handle. I need instructions
You have to separate the door panels (as shown in the attached photo)and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Dec 25, 2008 | Frigidaire FMV157GM Microwave Oven
Spacemaker xl microwave oven jvm1630
Dec 09, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Instructions for replacing door handle on JVM1350BW02 Microwave
You may have to rotate and pull the handle once the top screw is removed.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Sep 04, 2008 | GE JVM1350BW/WW/AW/SY Microwave Oven
GE JVM1340AW/BW/WW Microwave Oven Logo
32 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
