Question about Microwave Ovens
Panasonic dimension 4
How do I change the light bulb please
4 Suggested Answers
SOURCE: Panasonic Dimension 4 the Genius
i had to take the entire cover off the microwave (it is held in pace by screws at back as well as the bottom). Take the busted bulb to hardware store (bunnings) or panasonic spares and replace. Note I have a slightly different models (nn9853, nn9807).
AH
Posted on May 26, 2008
SOURCE: Replacement light bulb for Panasonic NN-9853 Microwave
Hello, I also have a Panasonic Microwave ( model NN-S 564 or 574 ?) They are very similar.
I have just removed the outer cover 5 screws ( unplug of course ) and have located the bulb holder which is a white plastic component with two clips holding the globe, pull it out and remove the two spade clips connected to the globe. The globe will come away attached to a black plastic mount. Next........do the run around to find someone who sells it.
Perth has an authorized distributer/repairer in Myaree whose details I got from Panasonic. He may sell them. otherwise I will try a couple of specialist light globe suppliers I know....PROLAMPS in Belmont and one in BALCATTA whose name escapes me but I have been there before...Hope this helps others.
Martin
Posted on Aug 27, 2009
Testimonial: "Hi - and thanks Martin for an excellent description of the process. Perfect assistance for a handyman-challenged guy like me. Thanks Grant"
Cuisinexpert
  • 61 Answers
SOURCE: Panasonic Dimension 4 microwave switches off
Try resetting it--aka, unplug for about an hour, then plug back in and try again. If that doesn't work, make sure you try a different outlet, and if all else fails, contact Panasonic. They should be able to help you out with a repair/replacement (and if you're still under warranty, usually it'll be free!).
Their phone number (acccording to their website, www.panasonic.com ) is 1-800-211-PANA (7262)
Good luck! :)
Testimonial: "Very quick and clear, thanks."
TYPE BULB FOR PANASONIC NNP295 COOKTOP LIGHT
Halogen Cooktop/Night Light Replacement
Be careful as the Cooktop Light Cover and the bulb may be
hot.
1. Unplug microwave oven or disconnect power.
2. Loosen the screw to open the Cooktop Light Cover.
(Be careful not to lose the screw.)
3. Replace the old bulb with a new one.
(use Max. 125 V, 30 W, Wide Pin Capsule Type/GY8.0~9.0
recommended)
do not touch a new Halogen bulb with bare hands.
Fingerprints may result in shorter life. Remove fingerprints
with alcohol.
If this bulb is not available locally, contact your local
Panasonic dealer. Part number is F612E6Z00AP.
4. Reinstall the Cooktop Light Cover with a screw
Dec 02, 2014 | Panasonic Microwave Ovens
Change light bulb panasonic inverter nn-h965bf
We recommend you have an authorized service center location replace the light bulb. Authorized service centers can be found in the below link.
www.panasonic.com/repair
Welcome to Panasonic Online Repair
Mar 23, 2014 | Panasonic NNH965BF Microwave Oven
Panasonic Dimension 4 Genius problem
An internal fuse may have blown or the magnetron may have failed
Apr 09, 2013 | Panasonic Genius Prestige Nnsd997s -...
How to replace a panasonic dimension 4 light bulb
Microwaves are dangerous things to be playing around with, they contain very high voltages even when they are unplugged...to change the bulb, you will probably have to remove the cover...you should then see the bulb.
But be warned, messing with microwaves can kill you - be careful!
Sep 20, 2009 | Microwave Ovens
Dimension 4 microwave stuck on demo mode
Here are is the manual:
http://service.us.panasonic.com/OPERMANPDF/NNT888S.PDF
Page 13 tells how to shut off Demo mode. (Press FUNCTION-0-2.)
Aug 12, 2009 | Panasonic NN-T888S Convection/Microwave...
Martin
May 10, 2009 | Panasonic NN-S540 Microwave Oven
Replace the bulb in Panasonic microvave Model nn s 768ba
Hi all,
I have just replaced the bulb in my Panasonic NNA873 Dimension 4.
Please be careful,although it was an easy job, there is a capacitor inside which stores heavy loads of power and will release the electricity into you if you touch it!
YOU CANNOT REPLACE THE BULB FROM INSIDE THE MICROWAVE....... DO NOT REMOVE THE CARDBOARD-STYLE COVERING WHICH IS ATTACHED WITH ONE SCREW INSIDE THE MICROWAVE ON THE RIGHT.
To replace bulb will take 5 minutes.
UNPLUG microwave. Remove the outer cover by unscrewing about 6 screws (ordinary phillips) don't lose them into the workings.......
Bulb is located on the right side, nearer to the front. You cannot see the glass of the bulb, only the black plastic end piece, as the bulb sits upside down and vertically. Best if you check out what a T170 looks like on the internet, then you will know what you are looking for. For my Panasonic I needed a T170 (but be careful, they have different ends, some are straight, some right angled - mine was right angled - check before you buy and no, I don't think you can get them from any ordinary supermarket etc!!). Do not touch the bulb when replacing as the oil on your fingers will shorten its life.
Old bulb can be removed by taking out one screw and then pulling off the connectors - there is a little tab to push down to ease them off.
Then simply replace bulb!
When putting cover back on make sure all the tabs on top and sides go inside not outside casing.
Good luck. This is an easy job, just don't poke around anywhere else.
Oct 30, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Panasonic Dimension 4 the Genius Microwave/Convection NN-C888W I cannot seem to get into this to replace the electric light bulb. Please can you help me.
AH
Apr 30, 2008 | Microwave Ovens
Panasonic Microwave Dimension 4 convection (11 yrs old)
You need to press clock 3 times, then start 3 times and then clear/reset 3 times. Then you can reset the clock by pressing clock 1 change the time and press clock again.
Mar 11, 2007 | Panasonic NN-T888S Convection/Microwave...
Microwave Ovens Logo
66 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
