Question about Sony HVR Video Cameras
Camera lens focus repair
Camera is in focus but when i zoom out it looses focus
  • 76 Answers
SOURCE: zoom lens won't retract
Usually down to the lens block assy being faulty.Is the lens retracting and opening properly?.It usually turns out to be worn gears in the lens drive assy or the result of a fall.Either way will be expensive repair!My advise is check and see whether camera is covered by insurance for accidental knocks.,
Posted on May 11, 2007
SOURCE: Loose Focus ring assembly
IF YOU TAKE A LOOK AROUND THE FRONT OF YOUR CAMERA THERE ARE SEVERAL SCREWS, ABOUT 4 I THINK,
1) 1 ON BASE
2) 1 ON THE LEFT LOOKING AT FROM THE FRONT
3) AND 2 INSIDE THE FLASH CASE
REMOVE THESE SCREWS AND THEN YOUR FOCUS RING AND SOME OF THE CASE SHOULD COME OFF
INSIDE THE FOCUS RING YOU SHOULD SEE 3 SREWS IF NOT CHECK THE CAMERA TO SEE IF THEY HAVE FALLEN INSIDE,
IF NO JOY YOU CAN REPLACE THE 3 MISSING SCREWS AND PUT IT ALL BACK TOGETHER
SWEET
DAVOS69
HOPE YOU DONT MIND BAD SPELLLLLING.........
Posted on Nov 08, 2007
djproaudio
  • 515 Answers
SOURCE: lens failing to function properly
Yes, this is a strange issue. Have you dropped the unit, or maybe 'bumped' it or anything similar. I know alot of times, people like to 'hit' their unit, to get it to do things (like eject tape). What people don't realize, is that these machines are prone to damage when hit hard enough (just like anything else).
In any event, this is not an misconfiguration issue, and you won't be able to fix it. You would need to bring it in to a qualified service center for an estimate. Be sure to shop around to find the best price and service. Since parts for these are not cheap, and they are labor intensive.
Good luck.
Hope this helps some.
TWEAK A/V LAB
Posted on Nov 09, 2007
mediarich
  • 188 Answers
SOURCE: repair lens PDX10
It sounds like the optics in the lens are no longer calibrated. It needs to be looked at by a professional.
Posted on Oct 19, 2008
mistersony
  • 320 Answers
SOURCE: Loose Manual Focusing Lens Device
There is a bulletin (E31529192) that describes your exact problem and recommends replacing the screws with new different screws to prevent this from happening again. The front section around the lens assembly is only held by 3 screws so access isn't a big deal, just be careful if you try this because there is a cable connected to the microphone that is easy to damage. The new screws are part number 3-056-559-01. Be sure to rate this solution. Thanks!
Posted on Nov 01, 2008
How to repair or unstick Sigma K zoom 100-200mm macro - tele focus stuck at infinity
Remove the lens from the camera, set MF on the lens, try gently to free it by hand. If this works, clean the contacts on the lens and camera body - if not, it needs repair.
Jun 05, 2017 | Canon Cameras
Long lens won't focus when zoomed out
I trust you are looking at something with sharp contrast, like a light pole. Lens can't focus without something crisp to see. If other lens work fine, than this lens need a trip to a lens repair shop. I use KEH Photo. Honest, reliable and cheaper and faster than Nikon. A visit to your local camera store might be in order, but if they send it in for repair for you, it will cost more.
Apr 08, 2014 | Nikon Cameras
Why does my lens only zoom to 200
Could be, because most camera's only can auto focus till f/1:5.6. And if 5.6 is reached at the focal length of 200 mm, the camera stops it from going to a part it can't be focused.
Perhaps you try the lens in manual focus, and manual zoom.
Jan 28, 2014 | Sigma Zoom Telephoto 170-500mm f/5-6.3 APO...
Getting an zoom error on my fuji film finepix z90, what can i do?
Lens errors (zoom errors on Fuji's) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 25, 2011 | Fuji FinePix S304 Digital Camera
My DSLR slipped and landed on my feet. Now I can take pictures but i couldn't rotate my lens.What could be done?
The lens's zoom ring has been knocked out of alignment. This causes sticking at certain points along the zoom and focusing range, and may even influence whether the lens can auto-focus. In order to have this fixed, you should take it to a camera shop to have it repaired, or send it to the manufacturer. They should provide you a quote at which point you can decide if it is worth repairing or replacing.
For example, if it is a $100 lens new, and they want $100 to repair it, it makes more sense to simply buy a new one.
The other alternative is to simply treat your lens like a prime lens, that is one that has no zoom, and move the camera into the correct position for a shot instead of zooming.
Whatever you decide to do, thank you for choosing FixYa!
Feb 04, 2011 | Canon Rebel XT / EOS 350D Digital Camera
Focus error? The camera won't focus. Focus Error is displayed in the viewing screen. Zoom action & everything else seems to work fine. Won't focus, won't take pictures.
This is a known issue with Fuji S3000 cameras caused by dust and dirt that get in through the loosely mounted lens mechanism, there are only three solutions.
  1. If under warranty you can send the camera in for repair.
  2. Saturate around the lens with WD40 and wiggle the lens until it becomes responsive again every month or so.
  3. Dismantle the camera and clean out around the internal gear-box and lens components about once a year.
May 03, 2010 | Fuji FinePix S3000 Digital Camera
My 18-70mm DX has a shaky front portion that the shade fits on
My lens did the same for most of the past year or so. Finally it started catching as I zoomed in and out and would not go wider than ~24mm. The problem is one or more of the screws holding the zoom mechanism comes loose and jams. Follow this link for the fix; took me ~20 min to repair (I went very slowly)!
http://photo.net/nikon-camera-forum/00Pegi
Good luck...
-David
Mar 20, 2009 | Nikon 18-70mm f/3.5-4.5G ED-IF AF-S DX...
Canon A630 lens will not zoom
The Gears for zooming are damaged i suppose ...... its complicated to open the lens as there are many components attached ..... Get it repaired from a repair man
Oct 17, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Repair lens PDX10
Oct 10, 2008 | Sony Dvcam DSR-PDX10 DV Digital Camcorder
Lens
Sorry, the mounts of Minolta manual focus lenses are different than their auto focus series. Sigma, Tokina and Tamron all make compatible zoom lenses to fit the Maxxum series cameras
Dec 30, 2007 | Minolta Maxxum 400si 35mm SLR Camera
Video Cameras Logo
12 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
