Question about Samsung HT-X200 Theater System
Sometimes plays discs and then says disc error
4 Suggested Answers
  • 5 Answers
SOURCE: doesn't seem to see disc. reporst disc error.
It is possible that you have a disc with a format that is not supported by your player. This can happen for many reasons. If your player will play a new standard DVD it is most likely the other disc that is the problem. Every player is different. Some new less expensive players will play almost any thing. A newer better quality player may not play as many formats. Besides the issue of format you can find security issues with either old discs or more likely an older player. Discs that are a problem more often are discs that have been burned copied or down loaded or produced by a company that uses a format that is not as widely used. The last problem is common with work out videos and generic movies / kids programs . You may also check to see if your player can except a software update.
Posted on Aug 21, 2009
technical114
  • 1851 Answers
SOURCE: dvd sometimes reads error
If this problem occurs only at this dvd it's a disk problem. If it occurs on various disks try using a cd/dvd cleaner set, a wet one is better. Follow the instructions on the set. The main idea is to put one drip of the included liquid at the set (usually isopropyl alchohol) at a specific place (like small brush) on the disk surface and play this disk. That way the "brush" will clean up the laser lens and after that the cd/dvd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush".
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on May 11, 2010
electricdime
  • 434 Answers
SOURCE: will not play disc.keeps saying
Check for fingerprints or dirt on your DVD. Wipe it clean and try again. Also check for scratches. Try another DVD and see if your system reads it. If it does not try cleaning the drive laser lens with a CD lens cleaner available at places such as KMart or WalMart in the electronic section. If that still does not work chances are you laser on your drive is bad and needs replaced. It will need servicing.
Posted on Dec 03, 2010
How do I fix a No Disc error given by my VIZIO Blu-Ray player?
Have you checked to see if the software is current on your player? If so do other discs function properly? Go to menu, chek to see current software, if current you can contact mfg. To see if it in fact current. Sometimes they have to be uptaded via cd. Retun disc to store get new one, try it to make sure. I have two 3d bl ray players and neither will play them. Software is not updated for these discs.
Feb 27, 2015 | Vizio VBR220 Blu-Ray Player
Vauxhall insignia dvd800
Laser is offline. Needs to be serviced or junked.
Mar 10, 2014 | Car Audio & Video
Device will not play previously recorded discs or record new info,but will play shop bought discs.on occasions it will display disc error. i am using new discs.
I Have had this same problem with DVD recorders. They sometimes will not play disc that were recorded on another player, you have to play these on the recorder that you used to make the recording. When recording you must finalize the discs to get them to play in other recorders, if they aren't finalized then the dvd wont recognize them as being recorded, there is no starting point set on the disc for the laser to pick up on. I have also ran into discs bought at the store that were not any good and I couldn't record on them, or when I did I would get the disc error message also. Try another brand of disc,say Memorex or Soney amd see if these will work, make sure they are compatible with the player, and they are the correct format for your player. There are 2 types DVD -R and DVD + R the + R work better on a wider range of players.
Nov 25, 2010 | Philips DVDR880 DVD Recorder
My DEH-1950 IS SHOWING ERROR 17 WHATS THE CAUSE? WHEN I PLAY A CD SOMETIMES IT PLAYS AND SOMRTIMES IT SHOWS THIS ERROR 17 WHAT COULD REALY BE THE CAUSE OF THIS.
Typical Error Messages from this head unit:
  • ERROR: 11,12,17,30 / Cause: Dirty Disc /Action: Clean Disc
  • ERROR: 11,12,17,30 / Cause: Scatched Disc / Action: Repace Disc
  • ERROR: 10,11,12,15,17,30 / Cause: Electical or mechanical / Action: Turn the ignition ON and OFF, or switch to a different source, then back to the CD player
Try a CD Head cleaner, that should resolve this error.
Nov 11, 2010 | Pioneer DEH-P2900MP CD Receiver...
I had the dvd player/radio /cd player replaced in my 2007 Yukon, the cd player would not read discs, the dealership ordered a new radio & now the dvd player reads disc region error & will not play...
If your using copies then some dvds wont read them even if the old one did, sometimes its a gamble if it reads or not, if your using a master then i would have them check it out, it may be bad or need programing, it funny because sometimes it will play a copy and sometimes not, thats what i've run into. hope this helps.
Aug 31, 2010 | GMC Yukon Cars & Trucks
Co.clare eurovox chorus channels gone
The "Unplayable Disc" error has also been heavily reported. The error appears to be limited to the Hitachi CD/DVD ROM drives that replaced the earlier Toshiba drives. The error message is preceded by a loud series of grinding noises and the system returning to the dashboard. From that point forward, any disc that is put in the unit will result in the "Unplayable Disc" error (although if the user was to eject and close the disc tray in quick succession the disc may sometimes play).
Dec 21, 2008 | StarTech.com StarView SV211K 2-port KVM...
Disk error message
In the manual there is a list of discs the unit wil play. On the last pages there is a quick reference. There are also region codes that need to be set. Maybe a power outage reset your settings. Also it would be good to know if this unit played disc previously, plays other disks? Or the discs play on other players. It could just be a dirt problem as well.
Manual is available here;
http://www.funai-corp.com/6pdf/om/MWR20V6.pdf
Sep 29, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
CD changer problem
According to the manual, error 11 means the disc is inserted upside down.
Oct 11, 2007 | Pioneer CDX-FM1289 12-Disc CD Changer
Samsung HT-X200 Theater System Logo
27 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
