Question about Intellinet Active Networking (520638) Router
Wireless connection We are no longer able to access the internet from our laptop through the router. We have a speedstream ss2624 router. I can still access it through the LAN, but none of the other computers in the house can. The message is "Limited or no connectivity" with a strong signal. Also when trying to repair the connection it returns and indicates "unable to aquire new ip address"Thanks in advance for your help.
Re: Wireless connection
I finally hit it. I tried dial up and LAN and same fault. Turned out that somehow, through our protection software, internet traffic was halted. Just needed to open it back up.
Thank you all for your suggestions.
Posted on Oct 22, 2007
  • 110 Answers
Was there any power outages, or anything that would make the modem and router turn off and then back on?
Try this:
Do this:
(in this order)
  1. Turn off the router.
  2. Turn off the modem.
  3. take out all the Ethernet cords from the router, EXCEPT the one coming from the modem
  4. Now turn the modem on.
  5. Wait for the lights, then wait about another minute for it to settle.
  6. Turn on the router, make sure the Internet,Lan,Wlan,etc lights are on and functional if it doesn't display a light let me know.
  7. Now depending on what your wireless network (SSID) is called try to connect to it. Go to Start>Network>Click Network And Sharing Center at the top>on the left select Manage Wireless Networks>now click add, if your network is already on the list shown select it and click remove otherwise click "Add" click "add network in reange of this computer" select your network name and click connect.
Posted on Oct 19, 2007
0 characters
3 Points
I have a speedstream 6520 router forgot my password and i want to connect my laptop to wireless. How do i get the password
On the back of the wireless router will be a little black button some can be hard to see but they all have one somewhere pressing this button for 5 seconds will force the wireless router to reset and remove all password and configurations that was set by the user of yourself after this has been reset you will need to log into your wireless router by either looking at the faint writting or something similar to this or by the ip "internet Protocols" and re-setting up the encryptions and security along with the passphrase for the wireless
Jun 27, 2011 | Siemens SpeedStream 2624 (SS2624) Wireless...
Will there be any problem with a Speedstream 2624 router if I upgrade to Windows 7? My two computers now use XP/3 and Vista with no problems of access. Thanks.
Hi! There will be a problem with the wireless connection. I suggest before you go to windows 7, check at your router website if there is a new update for the firmware for windows 7.
Nov 21, 2009 | Siemens SpeedStream 2624 (SS2624) Wireless...
How do I connect the SS2624 to HughesNet
Are you trying to set up the router for the first time.
Make sure that the computer is able to go online when connected directly to the modem.
Click Here for more info about router set up. YOU can follow the direction for the DSL connection
Oct 08, 2009 | Siemens SpeedStream 2624 (SS2624) Wireless...
Missing usename/password for siemens speedstream ss2624 router
press the small reset button on the back of the unit. It will remove any security settings and allow you to use it
Aug 30, 2009 | Siemens SpeedStream 2624 (SS2624) Wireless...
Connected but cannot access internet
If you have a good IP address, re-boot the router. If your address starts with 169., then you don't have a good IP address.
Jun 03, 2009 | Siemens SpeedStream 2624 (SS2624) Wireless...
Router Help
Either get the person you got the router from to give you the pass phrase or try accessing the link on this site to get a manual
The instructions to reset the router will probably set the entire router back to the factory default configuration. After which you will need to configure any changes required by the ISP into your router.
Dougerus -- you might be able to help Robbyn by telling her what your manual says about resetting the router. In your case are you following the instructions to reset the router completely? CHECK THE MANUAL you may need to hold the reset button for several seconds for a reset. A short push might only reboot and not reset the router.
Dec 05, 2007 | Siemens SpeedStream 2624 (SS2624) Wireless...
Problem with msn live
100% free, but 100% qualfied experts to help you.
Oct 28, 2007 | Siemens SpeedStream 2624 (SS2624) Wireless...
please contact us for help we can walk you thru this
Sep 18, 2007 | Siemens SpeedStream 2624 (SS2624) Wireless...
Routers Logo
145 people viewed this question
Top Intellinet Active Networking Routers Experts
 C. Dante
C. Dante
Are you an Intellinet Active Networking Router Expert? Answer questions, earn points and help others
