Question about GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket
Touch panel not working - GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket
Lights are blinking when trying to start frigidaire dishwasher
First, confirm that the display is working. If the display is still working, try pressing some of the touch-pad buttons. If some of the buttons respond correctly but others don't, it is likely that the touch-pad is at fault. (Some manufacturers sell the touch-pad separately from the control panel. Other manufacturers require that you purchase the touch-pad and control panel together. If you cannot replace the touch-pad individually, replace the touch-pad and control panel.) Frigidaire Dishwasher Lights Flashing or Blinking
Oct 28, 2017 | Frigidaire Dishwashers
My microwave LG MB-2341BR is not functioning as the touch panel not working. The start touch is not working. Do we get touch panel replacement now?
I being an experienced technician all I do is get micro buttons such as used in television set .I carefully apply minimal hot air from a hair dyer to the touch panel in a clean environment then strip the adhesive touch panel to check the wire ring that tress back to the pcb that is just beneath the touch panel. yo have to locate common and the wire responsible for touch, then drill a small hole where the micro button will sit solder to wires on the button then carefully solder them on the board.now make sure the button is on the same level with the surface before you return the adhesive touch panel make sure the button sits well then from beneath apply hot glue please don't use super glue if you don't understand I will send you pictures.
Jun 16, 2016 | LG Microwave Ovens
Touch Panel Broken
there is a guy on ebay that fixed mine Trbilea1999
he repaired my touch screen and updated all the software
Jan 29, 2014 | Kenwood DNX7120 Car GPS Receiver
My entire touch is not workingOnly a portion of my touch screen works..especially when trying to send texts, certain letters and symbols would not register or display
Hi Likhitha,
maybe loose contact of touch panel connecting cable with internally with PCB or your touch panel is damaged,
go for repair,
regards,
nuwan
Jan 16, 2014 | Dell Aero Smartphone Cell Phone
Bizhub 350all key working touch screen not working
Touch panel of the machine is expired.It will not work any more.Replace the touch panel.It is available in the market.
Nov 04, 2013 | Konica Minolta bizhub Office Equipment &...
Vgn-cs26g touch sensor not working
my vaio VGN-CS26G' touch sensor panel doesn't work after install Windows 7
please help the basic is Windows Vista after i change it in to Windows 7 touch sensor panel doesn't work
Aug 10, 2012 | Computers & Internet
Korg Triton Studio LCD malfunction! Please need help badly! :(
Where can i purchasea lcd for my korg triton studio
May 28, 2012 | Music
Kenmore Elite drying doesn't work sometimes..
Touch pad is failing.Try not to get any moisture around this touch pad.Biggest mistake for all appliances is the touch pad and water dont mix well.
May 21, 2008 | Kenmore Dryers
GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket Logo
18 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
