Question about Microsoft Surface RT
Bluetooth not working
Bluetooth wont work between devices
Bodyglove samsung galaxy tab3 bluetooth keyboard does not work.the lights are on.The tab recognises the pairing & connects via bluetooth,however,I cannot type. Is there a way to "restart" the keyboard
I believe that you need to set the deafult keyboard on your device sertings. As you know your device keyboard is set to google or samsung keyboard. Unpair the device with the keyboard and re -pair them again, once they are paired go to device settings, language and data tap default keyboard and select bluetooth keyboard and set it as default.
Hope this helps.
Good luck.
Jul 11, 2016 | Samsung Tablets & eReaders
My asus memo pad 7 wont send, receive or pair with devices through Bluetooth
hai there, as i analyze, you have to pair manually to other device, cannot straight send file to the others by bluetooth.
before send file and other thing, first make sure some one or other device you want to send have to be recognized by your device by pairing manually.
you have to go to bluetooth setting, for pairing manually you can choose by search or by listening device, don't forget the other device must do the same. after your device completed pairing to the others you can transfer all files you want.
cheers. hope its helps
Nov 07, 2015 | ASUS 8GB ME170C MeMO Pad 7" Wi-Fi Tablet...
My wireless Toshiba keyboard won't connect to my tablet
1. It connects via Bluetooth and not all devices are compatible with Tablet design. It does not connect via Wi-Fi.
2. Bluetooth devices require a PIN number to be put in the tablet for it to work.
See this web page for details.
Toshiba Wireless Keyboard Android Optimized
Mar 06, 2015 | Tablets & eReaders
Where do i find an app to upload an external bluetooth keyboard to my trio stealth g2 tablet?
I have not seen this model listed with built in Bluetooth. You could add a USB bluetooth device and it should work. Usb keyboards and mice will work for sure.
Jun 09, 2014 | Mach Speed Trio Stealth G2 8 inch Tablet...
I can't now can't get my bluetooth to work on my asus memo pad hd7
What bluetooth are you trying to pair?
Make sure bluetooth is enabled on both devices.
Apr 18, 2014 | ASUS MeMO Pad HD 7
Bluetooth won't connect
The bluetooth device drivers of your laptop may not be updates. Browse Dell's website and download and install the latest drivers for you specific model. Also try to connect witout authentication and see if it works that way.
Sep 24, 2013 | Dell Latitude Xt3 Business Tablet...
Bluetooth and wireless not work on windows 7
Your bluetooth and Wireless Lan is not working because Windows 7 is not compatible with this devices. And unfortunately, you cannot find any drivers for your tablet PC that is compatible with windows 7.
Go to this site to know what Operating Systems is compatible with your Tablet PC . CLICK ME
So I suggest that you change your Operating System so that your Bluetooth and Wireless Lan will work perfectly..
If you need drivers for your device. Just click the link above, and click on the Operating System you are using. (Except windows 7)
Goodluck, Hope my solution helped. Thank you for using Fixya.
Jul 07, 2011 | Compaq tc4200 Tablet PC
Is the m275 bluetooth headset capable? & how would i pair it?
Standard spec doesn't show bluetoooth but if you have a bluetooth dongle yes it is possible but the Windows standard bluetooth driver doesn't do it. There is a better bluetooth driver available on the Toshiba website which works with many hardware devices.
Jun 26, 2009 | Gateway M275 Tablet PC
CF19 How is Bluetooth started when message is Bluetooth not ready
- Yup, once the unit detecting other bluetooth enabled device around the area it is indicated the unit is working great.
Mar 11, 2009 | Panasonic Toughbook-18 Tablet PC
Problem with my tablet pc
Hi
The Satellite R10-S802TD doesn't have built in bluetooth device, however it's bluetooth compatible. any external bluetooth adapter will work. Toshiba recommends
PA3370U-1BTM Toshiba Bluetooth SD Card V1.2 or
PA3405U-1BTM Toshiba Bluetooth USB adapter as indicated you product's spec sheet.
Please post if you need further assistance.
Good Luck
Feb 06, 2008 | Toshiba Satellite R10-S802TD Tablet PC
Microsoft Surface RT Logo
87 people viewed this question
Top Microsoft Tablets & eReaders Experts
thetraveler
Level 1 Expert
Les Morrison
Les Morrison
Ruben Caraballo
Ruben Caraballo
Level 1 Expert
Are you a Microsoft Tablet and eReader Expert? Answer questions, earn points and help others
