Question about Samsung LE37R72B 37 in. HD-Ready LCD Television
Colour is not normal, sometimes the picture is too dark, football pitches bright green, peoples faces very orange.
Started noticing the colour looking strange. Most obvious when watching sky sports, the picture is very dark at times, if presentors wearing dark suit jacket it looks completely black. Watching football the pitch is very bright green. Also I have noticed an imprint in the screen from SKY TV guide ie I go into TV Guide and select a channel, when the channel is now full screen I can still see the imprint(faintly) from the SKY TV Guide.
  • Samsung Master
  • 3,462 Answers
That would be a failing tcon board on the back of the screen.you would need to replace this part but they are available on ebay the part number is on the tcon board. match the numbers a version number to get the matching board for the screen. tcon board is the board were the main wire cluster goes to the screen board this is the tcon board.
Posted on Jul 03, 2017
  • 179 Answers
SOURCE: picture distortion esp. during movemnt breaksdown and looks like impressionism art even watching sports on HD
if you are on a cable or a satelite box try setting the boxes output to 720p instead of 1080i..it should be clearer
Posted on Nov 29, 2007
  • 579 Answers
SOURCE: Samsung LE26T73BD
The amplifiers driving that portion of the screen have partially failed.
Sorry, this is a pretty common LCD problem.
If it is under warranty, call them.
If not, plan on replacing the main control module.
Posted on Jan 24, 2008
  • 29 Answers
SOURCE: Samsung LE32R7 Vertical lines problem
Plug the TV into a wall socket by itself, have seen this when TV was plugged into a power strip.
Posted on Mar 15, 2008
SOURCE: Picture Flashing
I had this problem too, fortunately I have a sky engineer friend who told me it is a known compatibility issue, all you need to force the latest firmware upgrade down to your sky box and hey presto, it will fix it. It depends on the type of box you have as to how to force the firmware download, but just google it and you'll find the combination of keys to press that will put the sky box into receiving a new firmware upgrade from sky.
Hope it helps you, it did me cos it was driving me crazy
Posted on Jun 10, 2008
  • 191 Answers
SOURCE: Bad picture/colours on Samsung LCD TV
loretta change your power pack
entwined  try another cable
Posted on Nov 10, 2008
The picture colour of my set is a mixture of blue,red & green. how do i set the color ? please help
try to adjust in color set up menu, if can not get with manual adjustment the problem it could be the convergence ic is defective or an open resistor.
Aug 03, 2012 | Televison & Video
Colors not matching computer
It is possible your colour cartridge has cross contaminated the ink reservoirs. To check this take the colour cartridge out and turn it over to see the coloured pads. They should look red, dark blue, and orange ( the colours are actually Magenta, Cyan, and Yellow, but are concentrated). If any of the pads are pale or particularly green - change the cartridge.
If the colours look alright, your issue is probably that your monitor makes colour by emitting light frequencies so is bright, printed images make colour by absorbing light frequencies so will always be darker. There is always the issue of course that your monitor also has a colour "temperature" bias. Photo pros calibrate their monitors and printers to match.
Mar 25, 2012 | Canon PIXMA iP90v Printer
I find the colour contrast is very dark could you send me ideal colour settings for perfect clarity thanks
Hello
Adjust the contrast to 55 to 70%; brightness to 45 to 55% and colour to your viewing taste. Now the brightness will be very low I thinks. Advance the brightness and contrast after setiing the colour to Zero. Adjust for a well defined B/W picture first. The advance the coulour. Take reference of the face colour of a news reader at studio. The picture will be perfect. OK.
Jul 07, 2011 | LG 42LB1D 42 in. HD-Ready LCD TV
Blue transperant colour spread over the screen from the left.
IN THE MENU CHECK FOR A COLOR CONVERSION OPTION ,,USE IT ,,TO REALIGN THE COLORS
May 11, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Too much ink
Hi, sounds like the colours are mixing because of the overfill. You can try this , but may take a while.
Get some tissues (around 6) fold them in half and put on the table. Keep dabbing your ink cartridge on the tissues in different places until you can see the 3 different colours clearly. This can take a while, but generally does work...
Dec 15, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Aug 21, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Need settings because of rubbish picture
There is no right or wrong setting for the TV, but I find the following give about the best results:
  • Contrast - 65 maximum
  • Sharpness - 2 maximum
If these are set any higher, the picture becomes very grainy, particularly around defined shapes.
  • Contrast + - OFF
  • NR - ON (If applicable)
These settings will need to be changed for each of the following:
HDMI 1& 2
  • EXT 1, 2 & 3
  • Analogue tuner
  • Digital tuner
The problem you describe, is usually with a satellite or cable box.
Unfortunately, there's nothing much you can do about the dead pixels, but the settings may make them less obvious.
May 01, 2008 | Philips 42PF5521D 42 in. HD-Ready Plasma...
Green colour flashes
I have a42hds52a and someone threw something at the screen and broke it. so I am looking for someone who is willing to get rid of thier tv1.gif or looking to buy one for parts.
call Richard At916-308-9272
raystockett@inbox.com
Oct 29, 2007 | Hitachi 42HDT52 42 in. Plasma HDTV
Colour problem
I have default settings I normally use for most sets before I begin any kind of alingment. Contrast: 90% Brightness: 45% Color: 45% Tint: 50% If the brightness is to high or the contrast to low the color is off. Check your connections, there probably OK, but, it never hurts. If the settings don't help call a local authorized servicer in your area. Hope this helps.
Jun 23, 2007 | LG 42PX3DCV 42 in. Plasma EDTV
Samsung LE37R72B 37 in. HD-Ready LCD Television Logo
32 people viewed this question
Henry  Thomas
Henry Thomas
