Question about Sony KDL Televison & Video
Problem with Sony KDL-46VL160 46 in. HDTV TV TV turns on in the middle of the night and switches input. I read it could be due to the receiver downloading the guide in the middle of the night and causing an automatic reset and turning on the TV, but not sure why the input is changing. It goes to "TV" input from the cable. No timers are set on the TV and there does not appear to be an auto setting for the TV input.
    Sergeant:
  • Sony Expert
  • 330 Answers
The problem in most of the case are:
1. Interference from a defective fluorescent lamp at your room sending signals to the infrared receiver of the TV.
2. Defective infrared receiver itself that sending noisy control signals to the CPU.
3. Defective manual control withes it has leakage.
4. Water damaged control switch PC board.
Posted on Oct 30, 2017
SOURCE: Sony BRAVIA KDL-40W4000
I've been looking into this myself as I've also recently purchased the KDL-40W4000. I was watching a murky old film and was getting a bit of sludgy ghosting but found that by reducing the contrast to 25, setting the backlight on low, colour on neutral and the brightness about 40-60 (and taking ALL advanced noise functions off), this reduced the ghosting considerably.
BUT, this is quite a cool and dark image. If you watch standard TV and films mainly, a variation of the Cinema setting is probably the best overall setting i.e.
backlight: min
contrast: 79
brightness: 50
colour: 53
colour temp: Warm 2 (although Warm 1 is less yellow and still fine)
sharpness: min
noise reduction: off
mpeg nr: off
contrast enhancer: off
colour space: standard
Ben, UK
Posted on Nov 23, 2008
SOURCE: Auto Switch does not work for HDMI inputs
Try this:
http://www.avforums.com/forums/6539544-post3094.html
Posted on May 17, 2009
vinnyq
  • 157 Answers
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Posted on Oct 07, 2009
  • 1768 Answers
SOURCE: sony kdl-40v5100 has handshake problem
1.This issue sounds as though the TV connection circuit has an issue.
2. You have changed the DVR and the HDMI cables and you still have an issue with the video (pink screen) indicates a video circuit issue ( improper voltage or current) at the video section of the circuit.
3. This will require some troubleshooting by a qualified tech.
4. To make sure, try connecting another properly working LCD TV to the cable box or DVR an check.If you get a picture and sound properly it is the TV.
5. Usually a cable box is QA'd (quality assured) by the company and will not be sent unless tested 1st
Posted on Feb 05, 2010
SOURCE: KDL-40V5100 TV HDMI Issue
I have the same problem did you ever find a solution
Posted on Apr 01, 2010
TV turns on in the middle of the night and switches input. I read it could be due to the receiver downloading the guide in the middle of the night and causing an automatic reset and turning on the TV, but...
Have you called your cable company? There may be an issue or setting with the receiver. I have never experienced this problem and have the same set up. But I do know that the tv should not be turning on when the receiver is downloading. What is the name and model number of your tv? This might help in my research of your issue
Sep 03, 2013 | Sony KDL-46VL160 46 in. HDTV TV
My tv wont show a pic or sound. the green light comes on and it clicks but nothing. its a sony bravia kdl-55ex710. its happened before and my husband played around with the home button. it occassionly...
On the remote control to that tv, after the power is turned on, find and push the input button untill you have a picture. The input button switches where you are receiving your signal from, cable, component, video 1, vedeo 2,,etc,,,.
Hope this helps
Apr 19, 2011 | Televison & Video
Jan 07, 2010 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
No picture, blue screen
Use the TV input selector to select the right channel, that should fix it.
Jan 04, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
KDL-32XBR6
Try resetting the TV by holding down the "up" button on the remote (with the TV powered on) and then, while you hold down the up button on the remote, hit the power button on the TV. This should do a "factory reset" which will wipe all settings in the TV. There is no reason why the TV should not "remember the last input it was on when it was ;last turned off. Also be sure that the TV is not plugged into a switched AC outlet, like the outlet on the back of the cable bix. The TV should be plugged into an output that receives power at all times.
Oct 19, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Televison & Video Logo
37 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
