Question about Arctic Cooling ARCTIC Sound E221 Black Headset for Mobile Phones and Music Players Headphones
Paired but not connected - Arctic Cooling ARCTIC Sound E221 Black Headset for Mobile Phones and Music Players Headphones
When I am trying to pair my smart phone with my ISBW2113 speakers I am getting an error: Unable to pair with ISBW2113. Incorrect PIN or password?
default is usually 4 zeros
yep it is. You must only have one entry on your phone for them. Manual is listed, details on page 2.
Pairing the Speakers (This process should be done FIRST before pairing a Bluetooth device. This should only need to be done upon first use.) 1. Power on the speakers by sliding the power switch to the ON position on both units (first make sure both speakers are fully charged). The Bluetooth Indicator and Speaker Connection Indicator will flash slowly in unison. If the Speaker Connection Indicator is not flashing, but is solid white both speakers your speakers are already paired. You can skip to the Pairing a Bluetooth Device section. 2. Press the Connect Speakers button on both speakers simultaneously. The Speaker Connection Indicators will flash quickly. Wait until both Speaker Connection 3. Indicators are solid white, this means the speakers have been successfully paired. Please note that this process can take up to 1 minute. Note : For all future uses please turn on both speakers and wait for them to connect (it may take up to 1 minute for them to pair automatically even after initial use). There should be no need to press Connect Speaker button again. If any pairing issues should occur, please follow the above steps again. Pairing a Bluetooth Device 1. Make sure you have first followed the instructions for Pairing the Speakers
When pairing, the device should remain within 3 feet of the speakers. 2. Press the Pair button on ONLY one of the speakers. The pair indicator will begin flash quickly. Using the native controls on your Bluetooth device, select the "ISBW2113" in your Bluetooth settings to pair. If your device requests a password, enter the default password " 0 0 0 0 ". Refer to the user's manual for your specific device for instructions on pairing and connecting Bluetooth devices. 3. When successfully paired, the pairing indicator will stop flashing and will remain solid. After initial pairing, the unit will stay paired unless unpaired manually by the user or erased due to a reset of the device. If your device should become unpaired, follow the above steps again. If any pairing issues should occur, un-pair the unit on your Bluetooth device and follow the above steps again. Note : If two speakers with the ISBW2113 name appear on the pairing list of your device, please erase one of ISBW2113 listed in your Bluetooth device and repeat the above steps again. Para descargar este Manual del Usuario en ingl?s, espa?ol y franc?s, o para obtener respuestas a preguntas frecuentes, visite la secci?n de apoyo en www.iLiveElectronics. com Playing Audio Wirelessly 1. Follow the instructions for Pairing a Bluetooth Device. 2. Use the native controls on the connected Bluetooth Device to select a track. 3. To play, pause or skip the selected track, use the native controls on the connected Bluetooth Device. 4. Any audio played through the connected Bluetooth device will now be heard through the speakers. Pour t?l?charger ce guide de l'utilisateur en anglais, espagnol ou fran?ais, ou pour obtenir des r?ponses ? des questions fr?quemment pos?es, consultez la rubrique d'assistance sur www.iLiveElectronics.com Customer Service: 1-888-999-4215
ILive ISBW2113B User Manual Page 2
Jul 04, 2016 | iLive ISBW2113B BLACK WIRELESS BLUTOOTH...
How to pair it with galaxy tab 4
This is for the 1900, but should be the same. Go to Bluetooth settings on your Galaxy.
Samsung HM 1900 User Manual
Aha, I found this for the 1500
4 Enter the Bluetooth PIN (0000, 4 zeros) to pair and connect the headset to your phone. Your headset supports the Simple Pairing feature which allows the headset to be paired with a phone without requesting a PIN. This feature is available for phones that are compliant with Bluetooth version 2. The headset also can be paired via the Active pairing feature, see page 14. Connecting with two Bluetooth phones
With the Multi-point feature activated, your headset can be connected with two Bluetooth phones at the same time. 1 After connecting with the first Bluetooth phone, press and hold the Talk button until the blue indicator light stays lit. 2 Press and hold the Volume up button to activate the Multi-point feature. 3 Activate the Bluetooth feature on the second Bluetooth phone and search for the headset (see your phone???s user manual). 12
4 Select the headset (HM1500) from the list of devices found by the second Bluetooth phone. 5 Enter the Bluetooth PIN (0000, 4 zeros) to connect the headset to the phone. ??¢??¢ You can set the headset automatically to reconnect to the recently connected phones each time you turn it on. -- To reconnect to the two most recently connected phones, activate the Multi-point feature. Press and hold the Volume up button in Pairing mode until the blue indicator light flashes twice. -- To reconnect to only the most recently connected phone, deactivate the Multi-point feature. Press and hold the Volume down button in Pairing mode until the red indicator light flashes twice. ??¢??¢ When the headset connects to two Bluetooth phones, some phones may not connect to the headset as the second Bluetooth phone. English
Disconnecting the headset
To disconnect the headset from your phone, ??¢??¢ Turn off the headset. 13
Reconnecting the headset
When the headset is paired with a phone, it will attempt to automatically reconnect each time you turn it on. If the headset does not automatically attempt to reconnect, ??¢??¢ Press the Talk button. Pairing via the Active pairing feature
With the Active pairing feature, your headset can automatically search for a Bluetooth phone and try to make a connection with it. 14
3 Press and hold the Talk button until the violet indicator light turns on. The headset will switch to Active Pairing mode, search a Bluetooth phone within range, and attempt to pair with it. [. . . ] ??¢??¢ To switch between the current call and the held call, press and hold the Talk button. 19
http://lastmanuals.com/manual/SAMSUNG/AURICULAR-MONO-BLUETOOTH-HM1500
Oct 30, 2015 | Samsung HM1500 Bluetooth Headset
Is it possible to pair my Plantronics audio 995 with a cell phone? After all it is blue tooth
unlikely as it seems to use blootooth technology but doesnt expose the passcode for the connection. see below.
How do I pair my headset to its USB adapter?
Procedure
Your headset and adapter are already factory pre-paired, and should automatically connect with each other. Should your headset and adapter become unpaired, you can initiate pairing manually. To Pair Your Headset and Adapter:
  1. Start with your headset powered off. Press and hold the power button for about 4 seconds, until the status light rapidly flashes blue. Release the button and set the headset aside.
  2. While the USB adapter is plugged into the computer, pinch the connect/pair button for about 4 seconds, until the status light rapidly flashes blue. Release the button.
  3. The headset and adapter will automatically attempt to pair. If the pairing is successful the status lights will glow solid blue; if unsuccessful, both headset and adapter will stay in pairing mode.
If the pairing was unsuccessful and you want to try to pair again, you must first take your headset and adapter out of pairing mode:
  1. Turn your headset off.
  2. Single press the connect/pair button on the adapter.
  3. Repeat the "To Pair Your Headset and Adapter" procedure, above.
If your headset and adapter are separated and lose their connection after being successfully paired, they will automatically reconnect when they come back into range of each other. If they remain out of range for more than 30 seconds, the headset will go into sleep mode, but will reconnect automatically with the adapter once it is back in range. If the headset is out of range for more than 15 minutes, it automatically shuts off.
Jun 11, 2012 | Plantronics AUDIO 995 WIRELESS HEADSET US
I am replacing the single toggle light switch in the bedroom entry (formerly connected to wall outlet) and have a new dual toggle or tandem switch I need one switch to power the ceiling fabn and the...
Joan, In the box where you are placing the switch, you should have three pairs of wires. Each pair should have a black wire and a white wire (plus each pair should have a bare ground wire). One pair of wires goes out to the bedroom entry. Another pair goes out to the closet light. The third pair should be coming from your electric panel and provides the power - this is the hot pair. First determine which pair is the hot pair. If you don't have a meter or tester, you can temporarily connect each pair in turn to a lamp and turn on the power. Repeat until you find the pair coming from the panel. Turn off the power. Now take note of the four screws on the switch. Two of the screws on one side may have a small metal bar connecting the two screws together. With the power off, connect the black hot wire to one of these two screws. If there is no metal bar you will have to use a short jumper wire between two screws on one side of the switch to connect them together. Connect one other black wire to either screw on the other side of the switch. Connect the last black wire to the last screw. (There is also probably a green screw by itself. Connect one of the ground wires to this, and wrap the other two ground wires tightly around the ground wire you connected to the green screw.) Now connect all three white wires together (not to the switch) with a wire nut. Install the switch in the box and turn on the power. Please vote if you found this helpful. Good luck, and be safe, Al K
Feb 22, 2011 | Pass & Seymour #690WGCC6 15A White 2SP UL...
E52 i want pair with my pc i do not know what is the pair password how to do it please clear
Hi, Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Feb 13, 2011 | Nokia BH-104 Bluetooth Headset
How do you connect it to a nokia 6300
To connect a jabra 250 to the Nokia 6300: On the Nokia go to menu > settings > connectivity > bleutooth = select and the next line = visible
On the headset when it is off > push the upper button for ± 8 seconds until the lamp is burning constant and release this button.
Choose on your Nokia on the same bleutooth menu > search audio.... It will be pairing in a few seconds . It will ask if it is ok to make the connection. The password is "0000" and push on "yes"
I hope you cann understand my english, I'am dutch.
Nov 17, 2010 | Jabra BT250 Consumer Headset
How to connect jawbone bluetooth device to htc evo 4g
HOW TO CONNECT BLUETOOTH
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Oct 02, 2010 | HTC EVO 4G Smartphone
Can not transfer songs from my old phone to my new phone via blue tooth the both phone have connected but when i try to send information it comes up not connected
Hi, you will need pair both phones together before you can be able to send .
Take care.
Aug 20, 2010 | HTC Wildfire Cell Phone
How to connect sony ericsion w395 via blue tooth
Take care.
Jul 07, 2010 | Sony Ericsson W395i GSM Quadband Phone ...
Connect kx7630 to dhlc8
A DHLC card is pinned the same as a Panasonic 123211 and TD-1232 system for compatibility. That means that there are 3 pairs for every extension and 3X8=24. In your triple set, the first pair is T&R, which is the ANALOG voice pair. It's used as 1/2 the connection for an Analong Panasonic phone (APITS) or a single line set. The second pair is D1&D2, used for a DIGITAL phone. In theory, if you're only setting a 76xx phone, a single pair from this pair to the second pair of the RJ-11 jack (orange pair of the cable or black/yellow wires) would make the digital phone work. We use 2-pair jumper just as a marker to know it's a DHLC block. The 3rd pair is used for OHVA on a 7130(!) and any other analog phone that had that feature. Which means, it's obsolete today, but you could take that TD-1232 system cable, plug it inot a TDA/TDE DHLC-8 card and move on to the next job.
On the back of the 7630 phone there's another jack marked TO TEL. Just for fun, plug your 7630 into another 7630. HAH! That's what a DXDP port does.
Carl
Oct 07, 2008 | Panasonic KX-T7630 Corded Phone
Arctic Cooling ARCTIC Sound E221 Black Headset for Mobile Phones and Music Players Headphones Logo
165 people viewed this question
Top Arctic Cooling Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Arctic Cooling Audio Player and Recorder Expert? Answer questions, earn points and help others
