Question about Hoover Washing Machines
Hoover wdyn 9666pg E03
My washing machine washes the clothes but no spin cycle. The machine pumps out water but then it seem that it continues to pump till the error message E03.
  • 209 Answers
SOURCE: my washing machine is full of water!!!
check pump for open circuit electrically, if that is fine and the pump works but just doesn't drain then its a blockage somewhere between the drum and the waste outlet, strip the pipes and clean out, taking care to note original position of any parts and wires etc
Posted on Oct 14, 2007
SOURCE: Hoover CA230 1300 Special Edition Washing Machine
Should you have to use un due force to get the filter undone on the Hoover 1300 special deition washing machine
Posted on Feb 02, 2008
SOURCE: GE Front Loading Washing Machine seems to be holding water....
manual
Posted on Mar 21, 2008
  • 36 Answers
SOURCE: does not pump water out or spin after first wash
Dear Customer
Please perform the following
The first thing to check is the lid switch. Open the lid and you'll see a recessed spot that a tab on the lid fits into. Put a screwdriver into the spot, press down and see if you hear a click. If you don't, the switch is bad. That's if you're lucky.
It could also be something as serious as the transmission. Try this: In the search box at the top of the page, type in repair (brand, like ur Whirlpool or anyother etc) washer. A list of sites will come up with a bunch of troubleshooting tips and repair instructions. I used this to fix my washer a couple of weeks ago. Good luck.
Please rate this,Thank u
Posted on Dec 17, 2008
  • 21 Answers
SOURCE: wet clothes at end of spin cycle
sounds like your transmission is not working properly. check your warranty information. (should be in your owners manual) many of the whirlpool made top loaders came with a 5 year warranty on the transmission/gear case
Posted on Dec 29, 2008
Hoover wdyn 9666pg-80 error code E11
I fixed ours! here is a video of how i did it, it shows where the wire snaps and what part the wire connects to:
May 11, 2012 | Hoover Washing Machines
Hoover 500mb washing machine failing to spin.
my does everything but it just wont spin drye
Mar 25, 2012 | Hoover HTC243 Top Load Washer
Hi, My Hoover 600MB top loading washing machine is approx 8 years old. Recently it has occassionally not fully spun out - clothes still wet at end of cycle. Now it also often doesn't agitate - just...
Have a look for coins etc stuck in the drain pump or the tub outlet hoses especially where they fit onto the tub. If a coin or other foreign material blocks the water flow when draining , these machines wont spin properly.
Jul 26, 2011 | Hoover Washing Machines
Hello I have a Maytag Washer Model A512 The machine goes through a regular cycle OK - However, it DOES drains the water out during the rinse cycle, but does NOT drain the water out during the spin...
The timer will always advance to the next program if the machine does not fully drain. There is ALWAYS a spin when draining the water out, there is only one pump and one motor. The waterlogged laundry maybe telling the timer that there is still water in the tub. Put the machine on "Spin" and cheat the lid switch into thinking that the lid is closed. Use a clothes peg or wide ended screwdriver and see if there really is a spin....
Apr 07, 2017 | Maytag Neptune MAH5500B Front Load Washer
Hoover hpe 236. water not draining, stops mid cycle, lights flash
Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Hope this is of some help to you.
Jan 16, 2010 | Hoover Washing Machines
How to change the belt on 5kg hoover washing
you have to re alliegn tha motor
Jul 12, 2009 | Washing Machines
Ca230 w. machine not spinning leaving clothe wet, no water in drm
It is possible that the belt at the back of the machine is slipping. try running the spin cycle without any load in the machine. I assume this is a front loading machine and you are in UK. the Belt is available on line for about 15 pounds.
If it is running the washing cycles normally, it can't be the motor.
Dec 06, 2017 | GE S8000E
HOOVER 500MB WASHING MACHINE
the pump hose has to be above tub level or the water will run out
the dial control unit is faulty and if the parts are are available will cost up to $150.00 aud approx to buy
the leak under the machine could be from a tub to pump hose or water level hose up to sensor
how new is almost new as it seems you have inherited a lemon and not a working machine
Jul 17, 2017 | Washing Machines
Hoover Commander 7kg (about 9 years old) not working. It does not spin in any wash cycle, although it can be done manually with ease in the 'spin dry' cycle. There was a strong rubber smell before. Any...
I have a Hoover Commander Model 2045LOAUS. The machine washes OK but will not spin (ie pump the water out). Could it be a burnnt out spin solenoid or motor??
Apr 26, 2008 | Hoover Washing Machines
Washing Machine Hoover H100M fills too much water in the drum.
this is 1 of 2 solutions  2 this problem the first thing to check is the vacuum system or it is a split in the pressure switch hose
Mar 05, 2008 | Hoover AAA140 Front Load Washer
Washing Machines Logo
88 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
