Question about Toys
John deere 5820 relay K08/4 come home what does it do?
The tractor would not select any gear an when i removed this K08/4 relay i was able to drive. what does this relay do?
SOURCE: gas tamk removal john deere 115
I had the same thing happen. I got the tank out, but it wasn't easy. Take out the bolts out that hold the rear end on. Take off the two springs that support the seat. Take out the battery and the battery tray. Take out the 6 bolts that hold the black cowling and the front of the green platform to the frame. This will allow you to lift the seat platform far enough off the rear end to allow the tank to be pulled out through the side. You also have to remove the metal bracket which holds the front of the tank and has caused the tank to leak in the first place. New tank is $56.00 not installed. I used a soldering gun and melted the plastic back together. I think it will hold quit a while. I know this is a little sketchy, but It worked for me.
Posted on Jun 02, 2009
  • 19 Answers
SOURCE: UNABLE TO FIND RECHARGING OUTLET ON KIDS RIDING TRACTOR
The peg perego battery for the gator is located under the front behind the black gril.
If you have any additional help I would contact http://www.shopjandl.com/
They always help me with my ride on toys.
Posted on Jun 09, 2009
SOURCE: john deere runs then stops
I fixed my mower stalling issues on the L111 by loosening the gas cap. I ultimately drilled a hole in the gas cap and screened the hole. Sounds ridiculous but without that venting the engine would run approximately 20 mins and die. It was also much more difficult to start the next time. Something else to pass along to whomever might view this... I replaced the cranking battery with a battery that had allot more cranking amps and I no longer had hard start issues ( this was after I vented the gas cap). Hope this helps.
Posted on Aug 11, 2009
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
SOURCE: Belt change on a hydrostatic 265 John Deere
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
Posted on Aug 28, 2009
Gears
remove the black hub caps, then pull off the metal push nuts, then pull the wheels off, this will give you access to the motors and gear boxes, you'll then have to remove the two screws that hold the gearbox in, then you should be able to finagle the gearboxes out
Jul 25, 2013 | Peg Perego John Deere Turf Tractor
John deere 160 jerks when driving
check for play in the drive pulley the gear might be striped
May 29, 2012 | John Deere Garden
My john deer won't go in to gear. It starts and
the drive and the mower deck use different belts
Apr 12, 2012 | John Deere Garden
The dash in the 7400 john deere tractor no work i need wiring diagram to find the short
remove horizon.and vertical fuse panel covers so as to gain access to relays or coil contactors. the lowest relay on vertical board powers up dash and on board computer. If yours like my dads simply pull it out and put right back in and dash lights back up and or relay bad...
Oct 02, 2011 | John Deere 420,1020,2010,2020,2510,2520...
It is a 1993 john deere 6100. there are 3 forwards and 1 reverse on one gear stick- 1, 2 ,3, r and the other is a, b ,c ,d ,e. the 1, 2,3, r gear stick has becoe loose and u cannot select gears 2 and 3. I...
The shifters do run cables to the transmission but you likely only need to remove the panel from the right side that covers the shift rods and then you can tighten the 13mm nut that brings the linkage rods together,the nut is on the shift lever not the range lever,Let me know how you make out and if i am wrong also let me know and i will dig deeper.
Sep 28, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John deere 300 garden tractor hydrostatic drive will not work
check two things, make sure the by-pass rod is pushed all the way in and the drive belt from the engine to the rear end (tranaxle). If both check out ok do not attempt to service the tranaxle at home. have thet serviced by a dealer.
Jun 02, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Toys Logo
32 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
