Question about Landice L7 LTD Executive Trainer Treadmill
E 3 error on carl lewis fitness motc99
Keeps cutting out
The sound on my TV keeps cutting out. It cuts out for 1-2 seconds. It does this approx. every 30 seconds. I have changed cables and cable box....no change. Any suggestions?
Sounds like the final audio amp MOSFETs are overheating.
After set has been off and unplugged check for dirt and dust clogging cooling fins and parts. Air must circulate for cooling. Remove dust with a gentle blast of air or an upholstery brush attachment on your vacuum cleaner.
If this doesn't work the parts usually cost more than a modern set is worth and I suggest purchase a new set.
Nov 26, 2015 | Televison & Video
Cricut expression 2
Cricket is hung up on the first small cut and keeps repeating that same cut over and over
Aug 09, 2012 | Toys
Fusion amp keeps cutting out
hi loose wires id check for first, but if it keeps playing up its an internal prob
Apr 08, 2012 | Car Audio & Video
My tv keep cutting itself off. I will have to
It could be going into power saving mode. Check your settings.
Hope this helps.
Iain
Oct 14, 2009 | Computers & Internet
The air keeps cutting on & off by itself
Sounds like th climate control bix is faulty.
Jul 08, 2009 | 2000 BMW 3 Series
Front speakers keep cutting out
If they cut out when they are turned up they are busted, get new ones. If they are cutting out when you hit a bump or something, then you have a loose wire somewhere between the player and the speaker, maybe check the doors and see if one might be crimped.
Jul 07, 2009 | 1988 Saab 900
I have a 1994 buick lesabre that keeps stalling out
try replacing the fuel filter, and check your air filter. replace that if it's dirty. good luck
Dec 10, 2008 | 1994 Buick LeSabre
Keeps cutting out!
hi!
My golf (2000) was doing the same to me. it occured to be the faulty EGR valve (it was closing and cutting the engin off) needed to have it replaced
Oct 20, 2008 | 2001 Volkswagen Golf
Landice L7 LTD Executive Trainer Treadmill Logo
Top Landice Exercise & Fitness Experts
Howard
Howard
lloyd cole
Dave
Are you a Landice Exercise and Fitnes Expert? Answer questions, earn points and help others
