Question about Garden
Husqvarna 61 manual
How much is a 20 inch bar and chain for a husqvarna 61chainsaw
  • 211 Answers
SOURCE: husqvarna chain saw, model 455 will not oil properly bar and chai
hi cindilou50
check the oil filter from the oil tank,the oil line ,the worm gear and the oiler under the clutch.Clean the ways where the oil goes with compresed air.(after you fill out the oil tank)Also check the oil hose.
best regards savumihai71
Posted on Dec 01, 2008
dontbother10
  • 2220 Answers
SOURCE: How interchangeable are replacement chain bars for
Your question can't be answered as aked.
If your saw requires an Intenz 14" Bar it's Oregon pns 140SDET041 or 140GPET041. Part number 140SDEA041 if not Intenz.
Plug in your requirements here:
Oregon Bar & Chain Selector
http://www.oregonchain.com/commonpgm/Selguide_Selctmfg.asp?BusId=OCS&SellReg=USA&LangId=ENG&ShowRem=Y&ShowAnsi=Y&ShowQuality=Y&ShowCombo=Y&usertype=OCC
Once you get a part number it can easily be converted to other manufacturers numbers. HTH
Lou
Posted on Nov 03, 2009
dontbother10
  • 2220 Answers
SOURCE: husqvarna rancher... chain tensioner not working
A Husqvarva IPL for a 455 Rancher 2005-01, follows (may not be your saw):
http://weborder.husqvarna.com/order_static/doc/usa/2005/I05000/I0501036.pdf
See print "A" (clutch cover) pn 537 28 64-01 & pn 503 21 70-10, if missing or loose these may cause your problem. If not an inspection of the parts beneath may disclose the defect.
If the bar is what can be moved pn 537 28 65-01 or 537 28 66-01 may be stripped. After I determined what parts need replacement, I would contact a local Husky Dealer. They may have these parts on hand and if not ordering through them should save you shipping and handling fees.
If your saw was not manufactured between Jan 2005 and Mar 2005 you can find your IPL here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 15, 2010
  • 4088 Answers
SOURCE: need to replace chain on
Release the chain brake. Remove the nuts/bolts that hold the right hand cover over the drive end of the bar. With the cover off, the bar will slide back toward the engine and allow the chain to be removed. Note the direction of the cutting teeth! Clean the side of the engine where the bar fits to, and the small oil passages in the bar drive end that run from the large holes out to the chain groove on each edge. Also clean the entire chain groove. Fit the new chain to the sprocket, then insert the bar and work the chain onto it. Pull out on the bar until the chain fits fairly tight, then fit the cleaned cover over the drive. You may have to change the position of the chain adjustment screw a few turns to allow the adjustment 'tang' to drop into one of the large holes in the bar. Make sure the cover is fully seated, then run the fasteners down finger tight. Turn the chain adjuster screw CW until the chain pulls up to the bottom edge of the bar, but not so tight that you can't turn the chain by hand. Tighten the fasteners fully and recheck chain tension. Start the engine and run the tip of the bar near some cardboard at speed for a moment or two--proper oiling is indicated by a thin line of oil thrown onto the cardboard. Be sure to keep the chain teeth sharp and properly adjust chain tension--don't allow it to droop when cutting. Hope this helps!
Posted on Dec 08, 2010
  • 130 Answers
SOURCE: Need to know the degree to set my electric chain
A 20" bar unfortunately does not narrow it down. Fortunately both the .325 pitch chain and the 3/8 pitch chain sharpen at 25 degrees and you should have one of these chains. Hope this helps.
Posted on Mar 02, 2011
My husqvarna 61 will only run if choke is at least half on
Carburetor is gummed up. You can thank Ethanol gas for hat
Jun 17, 2014 | Husqvarna Chain Saw 20" Bar
Filing angle for Husqvarna chainsaw 450 --20 ' bar chain 72 links?
On .325 pitch chain the top plate angle should be 25 degrees, there is normaly a match mark on top of each cutter, the depth gauge should be set at 25 thousands of an inch.
Apr 02, 2013 | Husqvarna 450 Chain Saw 18 Inch Bar...
Can you recommend a replacement 14in. bar & chain that will fit a Husqvarna 61 chainsaw
There is a genuine Husqvarna 15" bar available for the 61, part no 508913156, chain part no 501841456
Jul 15, 2012 | Husqvarna Garden
Need to know the degree to set my electric chain saw sharpener for husqvarna chain. This is a 20 inch chain.
Mar 01, 2011 | Husqvarna Chain Saw 20" Bar
My husqvarna chainsaws bar is 20 inches long, what size chain do i need?
Howdy, that would depend on the model you have. Here is the link to Husqvarna, so you can get the info that pertains to your specific model:
Happy sawing:)
Farmerbear
Aug 30, 2010 | Husqvarna Garden
Hi how to put front spring in to clutch brake
No model 61 listed @ Husqvarna.
How about a 261 here:
HusqvarnaUSA.com
Enter 261 (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
See the Chain Brake Assembly detail. HTH
Lou
Oct 22, 2009 | Husqvarna Chain Saw 20" Bar
What information can you tell me about a Husqvarna chainsaw model 61 with serial number 6136460. Does it indicate the year?
Most of the CDI modules have been superseded to part no# 544018401check with your local dealer to verify.
Apr 13, 2009 | Husqvarna Chain Saw 20" Bar
HUSQVARNA MODEL 50 BAR AND CHAIN UPGRADE
I have a nearly worn out 42 cc Husquvarna that uses a 20 inch bar very successfully. With proper filing of the chain you should be able to run a 22 inch bar very well. Ensure that the roller nose on your new bar matches the pitch of the clutch sprocket that you are using at present. If not, have your chain saw shop change them so they match.
I would advise that you change the bar and sprocket to use a .375 chain as this will be easier to sharpen successfully than the .325 pitch chain you might be presently using.
I am six feet tall and short bars are murder on my back so this is why I use no shorter than 20 inch bars on my saws.
Jan 25, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
50 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
