Question about Brother HL-2040 Laser Printer
Brother HL 2141 toner - Brother HL-2040 Laser Printer
  • 12 Answers
SOURCE: Brother Hl 5240 printer- toner light on
1) Turn off printer
2)Turn back on
3) Remove Drum and Toner.
4)Press Go for 1 second(it appears to do nothing)
5)Put Drum and Toner back in.
6)Press Go for 1 second(it appears to do nothing)
7)Close door.
Try that
Posted on Jul 05, 2008
SOURCE: brother HL 5250 red light flashing
I found this solution on the web-- Hope it helps.
The HL-2070N gets stuck in a toner end-of-life error condition. Perform the following to clear :
With paper loaded, new toner in,
Open front door
Turn off printer
While holding down the GO button, turn printer back on
When all four LEDs light up release GO button. All LEDs will turn off
Press the GO button 2 times. The 3 LEDs (toner, drum, paper) will light up solid
Press the GO button 5 times
Paper light will be blinking
At this point the toner end-of-life condition has been reset. Close front door.
BTW, I got this from Brother Support. Also, just a reminder, timing is important here so don't pause between button presses.
Posted on Feb 01, 2009
  • 10 Answers
SOURCE: Brother HL-5140, Status light is red and toner
It is very hard to find the reset instructions on the Brother Solutions site.
  1. Turn the printer off.
  2. Press and hold the Go button on the front of the printer, at the same time turn the printer power on.
  3. When the Toner light is on by itself, release the Go button.
  4. Push and hold the Go button again, release the Go button when the Paper light is on by itself.
Posted on Apr 21, 2009
SOURCE: Brother HL-2040 toner light stays on
I found this and it worked great.
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
Posted on Nov 27, 2009
Testimonial: "Thanks!"
SOURCE: Brother HL-6050dn Toner Life End
I just got through this problem, The customer had a "refilled cartridge.
The Flag on the left side near the gearset of the Toner cartridge was not
brought back to the proper position, just undo the three srews and reset the flag.
works like a champ,. your welcome.
Posted on Jan 21, 2011
Where is the cartridge on a brother laser printer HL-1400
I don't see a Brother HL-1400 on their site. However, there is an HL-1440 which uses the TN-430 (regular) or TN-460 (high yield) toner cartridges. This printer also takes the DR-400 drum unit.
This toner cartridge works with several models in the HL-1400 series, including the HL-1435, HL-1440, HL-1450 and HL-1470N.
I hope this helps.
Aug 25, 2016 | Brother HL Office Equipment & Supplies
Tip
Brother HL 5170DN Printer Toner error
Trick Brother HL 5170DN printer into think there is toner left. Rather than run out for a new toner cartridge use a small (.5 x .5 in.) piece of black electrical tape to cover the sensor hole on the non-gear side of the cartridge. By covering the hole the printer is fooled into thinking the hopper is full of toner.
on Feb 01, 2010 | Brother HL 5170DN Laser Printer
Brother HL-5250 printer toner Light on but Cartridge has Toner it
Try this....
1: Turn off power and remove toner/drum
2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
4: Turn off printer, remove tape from lever, replace drum and turn back on.
Mar 08, 2010 | Brother HL 5250DN Laser Printer
How do i add toner to my hl 2030 brother printer ?
You don't "add" toner, you have to replace the cartridge. You can see it by clicking on this link:
HL-2030 Toner
You can refer to the User Guide for instructions. here is a link to it:
HL-2000 Series User Guide
Replacing the toner is covered in Chapter 5.
Thanks for using Fixya.
Jan 09, 2010 | Brother HL-2030 Laser Printer
Please describe your Brother HL-2040 Laser Printer problem
Yep this will always happen if your just using a replacement toner. They will be depleted faster compared to the original Brother toner.
Make sure you replace your toner with the original Brother toner.
Aug 24, 2009 | Brother HL-2040 Laser Printer
Brother Laser HL-5240 has a status light and toner light. Fuser was replaced but no help.
that error usually indicates that the toner has reached its end of life
or the drum is not properly installed.
i had one person who put the toner in but threw the drum cartridge away.
Jun 25, 2009 | Brother HL 5040 Laser Printer
Replaced toner cartridge and light stays on the printer will not
how do i set the toner reset lever on a brother hl 5250 printer
Mar 31, 2009 | Brother HL 5250DN Laser Printer
Brother HL-1440
(blinking every 5 seconds) Toner Low Indicates that the toner cartridge is nearly empty. Purchase a new toner and have it ready for when Toner Empty is indicated. (solid) Toner Empty Replace the toner cartridge with a new one. User's Manual is available at the following location: http://www.brother-usa.com/Data/Documentation/Printer/User/UM_HL1440_1450_1470N.pdf Hope this helps.
Aug 22, 2007 | Brother HL 1440 Laser Printer
Brother HL-2040 Laser Printer Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
