Question about MSI K7N2 Delta-ILSR (MS-6570-030) Motherboard
New sata hard drive fitted, now says no audio deviec ,so no sound
Had a new sata hard drive fitted, now the computer says no audio device so now no sound
  • 20 Answers
If you just added the sata and reformatted the drive with a new copy of the Operating System you will need to reload the sound drivers located at MSI's web site in there drivers and download section.
Posted on May 22, 2009
  • Steven
    Steven May 22, 2009
After installing a new hard drive in my desktop computer, it still does not work. It says no boot device available. Sata's 0 & 1 installed but 2 & 3 uninstalled
No boot device available means the boot device hard drive on your system has no bootable operating system installed on it, or it is faulty. In the BIOS setup program, does the computer recognize the hard drive you installed, and is it included in the boot device list? If you installed a new hard drive because of a failure of the C: drive, the new hard disk does not come with an operating system. You have to install that on the new hard drive from the manufacturer's system restore disks. SATA channels 1 and 2 are just the connections on the motherboard for devices, and usually have a hard drive on one connection and a cd rom drive on the other. Giving the model and manufacturer of your computer might provide more clues.
Feb 04, 2017 | Hard Computers & Internet
I have western digital external hdd usb 2.0 and i have opened it now i want to connect it as internal hdd, its a sata drive inside when i opened the cover
The specific connection depends on the form factor the hard drive mechanism and the computer in which you want to install it. If it's a 3.5" drive and you want to put it in a laptop, forget it; it won't fit in there.
If you want to put a 3.5" drive in a desktop system, you need a SATA drive power connector from the power supply, a SATA data cable, and a SATA port on the motherboard or an expansion card. (note that you will probably not be able to boot from this drive if it is connected through an expansion card unless your computer's BIOS supports booting from a PCI device). It's also highly desirable to have an empty drive bay in which to to mount the unit.
If the hard drive has a 2.5" form factor (2.5" wide), and it is to go into a laptop, you will need the 2.5" hard drive adapter for your particular laptop (many manufacturers have a special cable or adapter for hard drives, although they should all fit the SATA interface. However, if your laptop is an older model designed for PATA IDE drives, the STAT drive will not be compatible.
To put a 2.5" SATA drive in a desktop computer, you need an adapter kit. This includes a 2.5" - 3.5" drive mounting bracket adapter and a cable adapter connector for 3.5" drive connections as described in the second paragraph above. Many computer parts merchants carry these.
Sep 21, 2014 | Computers & Internet
I dont have a hard drive, can i use any hard drive
I looked up the specs on that device. See below. The specs call for IDE. You will only be able to use an IDE harddrive drive. You can pick IDE drives up pretty cheap from TigerDirect, Amazon, NewEgg or most local tech computer/tech stores.
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/specs.htm
Oct 21, 2012 | Dell Dimension 2400 PC Desktop
How to install sata harddisk
With Serial ATA technology quickly replaince IDE/ATA as the new standard in hard disks, more and more computer users will need to know how to install SATA hard drives. The process of installing a SATA hard drive is similar to installing an IDE hard drive, except a bit simpler. Follow the directions in this article to learn how to install a new SATA hard drive.
1.Detemine whether or not your hard drive supports SATA. SATA technology was not introduced into the market until after 2002, so any consumer PC before that will not support a SATA hard drive. To find out whether or not a SATA hard drive can be installed into your motherboard, you can review the manual that came with your computer, or you can contact your computer's manufacturer. If you have already purchased a SATA hard drive, but have your motherboard does not support SATA technology, you will not be able to use your new hard disk.
2.Power down your computer and remove any peripherals or connections. Ground yourself either by wearing an anti-static wrist strap, or by touching a piece of unpainted metal. Remove your computer's case.
3.Locate your hard drive bay. Your hard drive bay should be located beneath your CD/DVD drive.
4.Locate the SATA data cables on your motherboard. Review the image to the left to get an idea of how your SATA slots may look (not all motherboards look the same). The small, red connections on the bottom-left of the motherboard are your SATA connections.
5.Take your SATA data cables (the red, smaller cable pictured left) and plug the one end into the motherboard. Insert the data cable into the lowest numbered slot (i.e. 0, 1).
6.Next, you will want to locate your computer's power cable. Some computers will already have a SATA-compatible power cable available, but others may not. If your computer does not have a SATA-compatible power cable, you will need to buy an adapter. As in the picture above, it will have one white end and one black end. Plug the white end of the adapter into the white end of the power cable in your computer. It should look identical to the one in the picture.
7.Connect the data and power cables to the back of your hard drive. The larger cable goes in the larger slot, whereas the smaller cable goes in the smaller slot. If they do not fit at first, simply turn them around and try again.
8.Slide your hard drive into the drive bay. You will want to make sure that the part of your hard drive with the connections on the back is facing outwards. Then, taking a screwdriver, line up the holes in the bay with the holes in your hard drive and screw the SATA hard disk into place.
9.Power on the computer. If you have installed two SATA drives, unlike with IDE, you should not have to designate them as master or slave (both will be independent drives). If your computer is not reading your new hard drive, power down the computer and check all connections, making sure they are secure.
Sep 08, 2011 | Computers & Internet
I bought a Hitachi z5k320 hard drive trying to install it, and windows, but my computer won't recognize hard drive. how can i get it to recognize the new drive. can't do anything until that happens.
As long as you are sure the hard drive is connected properly with SATA cables to the motherboard and has power from the power supply unit, and that the drive is working, you can enter the BIOS on computer startup and modify the "boot device" look in "primary boot device" for a name matching that of your hard drive (probably "HITACHI .....) If it is there select it as the primary device and hopefully it will boot and ask you to install windows. If it is not there the drive may not be connected or it may need to be replaced. Hope this helps!
Mar 15, 2011 | Hitachi 160GB Travelstar Z5K320 SATA 3Gbs...
My XP does not appear when connected through the USB port. When connecting it beeps. The USB controllers and hubs are all reporting they are working properly from the Deviece Manager. My printer works...
shouldn't need a driver if you got windows xp or higher. it should automatically install as a USB storage device.
is this new? if so you will need to format the hard drive if its not formatted already.
you can also check manager and go to storage device and see if the volume is getting a proper device letter.
do this by right clicking on my computer and choose manage. go to storage device and look for the hard drive. right click on it assign drive letter.
Mar 06, 2011 | LaCie Hard Disk 500GB with Hi-Speed USB2.0...
Says no hard drive devices found
Is it a "new" drive, or a drive that you have been using for a long time, i.e., it could have failed.
Turn the computer off.
Disconnect the AC power-cord.
Check that the "data" cable between the SATA drive and the motherboard is tightly connected at both ends.
Check that the "power" cable into the SATA drive is tightly connected.
Restart your computer, and enter BIOS SETUP.
Be sure that the BIOS-search for SATA devices is "enabled".
Note that Western Digital has a "Customer Loyalty" program; if you buy a new W.D. drive through their web-site, you qualify for a discount on the purchase.
Oct 31, 2010 | Western Digital Caviar SE WD1600AAJS 160...
500gb hard disk supported by intel D101GGC
Hey ROY_GV,
This D101GGC Motherboard supports both IDE and SATA.
Regards,
InfDev
Mar 05, 2010 | Intel D101GGC Motherboard
Additional hard drive needed
Just buy a new SATA HD of what ever capacity fits your budget. Keep the old one as it works with your setup. There is no point causing extra work for yourself.
Power off the computer. Conenct Power to the drive and a SATA cable to the new drive (should be supplied with it) and the motherboard. Power on the computer and then format the new drive. The drive letter will be assigned by the Operating System. Once completed you have a new drive to use.
Sep 10, 2009 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
No sound
Here is the link to the acer sound driver ... install this and let me know if this corrects the issue ..click the link below
audio driver
larry@contratek.ca
Mar 30, 2009 | Acer Aspire 4315 Notebook
MSI K7N2 Delta-ILSR (MS-6570-030) Motherboard Logo
180 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
