Question about LG HBS-700 Bluetooth Headset
Where to get the little clips?
I've lost one of the little clips that manage the wires of the LG-do you know where I can get some?
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 41 Answers
Home Depot plumbing isle, size #36 O-ring will work better than original clip. Simply stretch out the o-ring with a pair of needle nose pliars and roll it over the earpiece onto the neck band. It doesn't look like it will fit but trust me, it will once you stretch it out. The inner diameter of the o-ring is 3/16" i believe and will shrink back to its original size shortly after you put it on the earpiece.
Posted on Jul 10, 2014
I've lost my Craig CHT936 power cord. Is it a polarized 2 pin universal ac Type D cord?
Did you re-install the clips on each end of the new filter? Mine came without clips, but instructed that I carefully remove the old ones and re-use them. I went to my full service fuel station and had them install the one that I bought. Took 10 minutes, cost $15 and no muss-no fuss-job done right. I DO know when I am incompetent or don't want to get too dirty. :)
Sep 29, 2014 | Televison & Video
Hi I keep having the same problem with my land rover discovery series I, for some reason a little piece of plastic inside the door handle keeps breaking I've already replaced it once and now its broken...
I am guessing that the plastic bit is what holds the wire /rod in the hole of the lock lever It is a common connection piece in lock manufacture. If that is the case the piece that breaks is the bit that clips around the rod section(the clip fingers break off). Two fixes spring to mind is to use a piece of small wire (paper clip ) reposition the clip and tie to rod ( small zip tie may be easier) or 2 there are metal clips that do the same job( Mazda early models use these) but you could possible get them from a panel repair shop
Jun 20, 2013 | Cars & Trucks
My bass makes no sound.
check the jack wiring, or the battery clip integrity- sometimes the clip wires break but they look fine.
Dec 16, 2012 | Schecter Omen EXtreme-4 BCH
Crack bios password on my lg x110 - forgot bios password - can not get factory reset - help please
A password is required for access to the BIOS and I do not know the password. I have had this problem for quite some time now but luckily I've managed to get access to the BIOS now. I used lots of different programs to crack the password but I failed in vain. I removed the little battery that sat on the motherboard but nothing happened, I ran Hirens bootcd 15.1 and it did not help either. Eventually I got hold of a new system BIOS for my LG X110 and then flashed my BIOS. No password is needed now :) Download LG Notebook (X110/XD110) System BIOS here -> http://download.notebook-driver.com/driver/LG/X110/BIOS_Setup_X110.zip and run the program. That should solve your problem, because it did for me :)
Jun 19, 2012 | LG Computers & Internet
THE LITTLE THREDDED SCEW THAT HOLDS THE BLADE IN WHEN TIGHTENED HAS BEEN LOST, CAME LOOSE WHEN WORKING ABOVE HEAD, LOST IT WHERE CAN I GET A NEW ONE.
If you haven't already got one, these folks should be able to fix you up with what you need.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 21, 2011 | Bosch 52314 144volt Jig Saw Jigsaw Tool
WHERE DO I DOWNLOAD FREE DRIVER FOR MY LG DARE V CAST CELL PHONE
I am glad to HELP YOU!
I really don't know what driver are you looking for, but I've found FOR YOU just THIS ONE [V CAST Media Manager driver]. Click the provided link and get it!
And I've also found some other extra-explanations HERE and HERE. Just read them thoroughly and see if they are useful for you.
GOOD LUCK!
... and don't forget to RATE, please...
Apr 20, 2011 | LG Dare VX9700 Cell Phone
Sansa clip v 01.01.11a
this is a problem but i know how to fix this
the sansa clip wire is the same as a motorola phone wire
you can easily by one from a rogers store
i know this because i lost my wire and ended up using my dad's.
hope this helps :)
Jul 09, 2008 | SanDisk Sansa Clip MP3 Player
Lg phone manager
Go the lg's web site and download it from therehttp://www.lge.com/products/sidemenu/detail/u8120_PRD|SW_sw.jhtml
there you go, just select country and region there and you'll be able to download the software.
Jul 01, 2008 | Cell Phones
Replacing the headlight bulbs on 2005 Ranger
Having just purchased a 2002 Ford Focus I found that the passenger side headlight had gone. Stumbled accross this thread and thought "looks like a pain".
Popped to Halfords and picked up a H1 bulb, went home and had a look under the bonnet.
Armed with just a screwdriver I managed to change the bulb within 10 mins. Flicked the headlight cover off using the screwdriver for a bit of leverage. Unpluged the headlight and flicked off the retaining clip. Removed the bulb.
Fitting was even easier - Put bulb in place, clip the retaining clip in place, plug in and replace cover.
Job done within 10 minutes with no prior experience of Fords.
Hope it helps
IMPORTANT!!! The retaining clip does NOT just flick off. Tried that and broke the plastic stop that holds the retainer clip and allows it to apply tension to the bulb! The retainer wire is held in place on the bottom by a screw and clip on the bottom and is locked into a plastic clip on top. To remove the wire, push the wire down and towards the passenger side of the car, it will dislodge and you can then lower it to remove the bulb. Once the bulb has been changed, you want to replace the wire the same way to protect the plastic clip. I don't know what I will do about the plastic clip now, the retaining wire has no tension and I'm afraid the bulb will not remain seated properly. However, knowing what I know now, I agree with the above answer: Done in 10 minutes without prior experience with Fords.
=== Just finished doing this. A small mirror and a flashlight make this job simple. It's very easy to do once you can see the top of the clip.
small mirror and flashlight are essential, look at the way the retaining wire seats before you unclip it. flat side of the bulb houseing sits at the bottom of the access hole. retaining wire clips bottom to top. I had a hard time with seating the new bulb and had to figure out the retaining wire clipped from bottom to top because I didn't look at it before I unclipped it. obviously fords designed this for ease of manufacter with very little regard to the average layman who would do the replacing.
Jun 24, 2008 | 2005 Ford Ranger
LG HBS-700 Bluetooth Headset Logo
91 people viewed this question
Top LG Radio Communications Experts
iPhone Technicians
iPhone Technicians
Level 1 Expert
Mohamed Ismail
Mohamed Ismail
Computer Repairing
Computer Repairing
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
