Question about Tuttnauer "2540Elvc, 220V 50/60Hz, Ea"
TUTTNAUER 3870 ELVC - Tuttnauer "2540Elvc, 220V 50/60Hz, Ea"
WHY IS MY EZ 10 GIVING A LOW HEAT CODE
Message is displayed and sterilization does not start if the autoclave has not reached sterilization temp. after heating for 50 mins. while in wrapped or unwrapped programs (80 mins in the Glassware program).
1) Clogged air jet, clean air jet.
2) no pwer to the heating elements.
3) Low line voltage delaying heat up. Not enough power to supply unit.
May 06, 2014 | Tuttnauer EZ10 Automatic...
QUE ES LO QUE LE FALLA
https://www.uis.edu...
www.tuttnauer.com/support/technical-services
May 03, 2014 | Science & Laboratory
Blue residue
If so it would be copper sulphate. This could happen if there were any sulphates or sulphites in the chamber, on the items you put in. The high temp could promote a reaction. For example sulphates and sulphites are commonly found in dried fruit, wine, and preserved meats.
Mar 17, 2014 | Tuttnauer "Autoclave, 2340Ea,120V, Ea"
I can't find air finger configuration for Blodgett MT-3870
Go here find what you seek. Great Co.BLODGETT
44 Lakeside Avenue, Burlington, VT USA 05401
Toll Free: (800) 331-5842 Phone: (802) 860-3700 Fax: (802) 864-0183
Mar 18, 2009 | Blodgett MT1828G Oven
Need to set the head gap on a Genicom 3870. Lost my manual.
If it has a manual adjust, open the top cover and on the right side will be a slide for different head adjustments, it wll be numbered 1-6, 6 being right against the paper which causes smears. Move to around 3. If it has auto adjust (you can tell this when you power up the display will show "adjusting gap" then press off line, the press program, move to head adjust, press enter, press enter again then use the arrows up and down to move to your type of printing, 2part, 3 part ect.
Mar 13, 2009 | Tally Genicom 3810S Printer
My ATI RADEON HD 3870 over-clocked edition wont work. Plz help.
if your original graphic card was intecrated then u most first disable it in bios then u can use the new one
Dec 26, 2008 | VisionTek RADEON HD 3870 X2 Video Card -...
Compaq Ipaq not Charging
As I understand it, the basic cradle that comes with the Compaq Ipaq 3870 does not charge. If I were you, I'd either seek out a charging cradle or google the instructions for modifying your cradle to charge. Good luck...
Dec 02, 2008 | Compaq iPAQ H3760 Pocket PC
Video card issues: Artifacting
Make sure the drivers have been updated as well.
Here is a link to get them
See if your video game software needs to be upgraded.
Make sure no programs are running in the background.
How much memory does your computer have?
Jul 15, 2008 | HIS H387X2F1GNP RADEON HD 3870 X2 HDMI 1GB...
Stacking Cable / SuperStack3 3870
Found this on 3Com website: The SuperStack 3 Switch 3870 family (3870-24 and 3870-48) can stack up to 8 units high. Stacks can be formed with any combination of 24-port and 48-port units, with a maximum of 384 (8 x 48) front panel ports supported. When connected together, a stack of units is managed as a single entity. All units in the stack need to run the same release of the operational version code (firmware). When units are stacked together, they operate in a master-slave relationship. One unit acts as a Master and the other units act as slaves. When looking at a stack of units, the master can be identified by looking at the Stack Master LED on the left side of the switch. The Stack Master LED is green for the Master. If the unit numbers are out of sync, go to the CLI command that allows users to re-number their units- system / control / renumber. This will re-number the units in the stack. It will take about a minute or two. The master is the only unit that has a visible command line interface (CLI) when a console cable is connected to it. If you connect the console cable to a slave unit, you will not see the CLI menu, but instead see slave status messages being displayed. The Master unit may not be unit 1. http://knowledgebase.3com.com/consumer/esupport.asp?id=GUIDbfa9caa4%5F138f%5F4681%5Fbaaf%5F5c99ec5b7ff4&resource=&number=0&isExternal=0&nShowFacts=&nShowCause=&nShowChange=&nShowAddInfo=&activepage=statement.asp&bForceMatch=True&strCurrentSymptom=3C17462&searchtype=normal&searchclass=&bnewsession=false&selecttype=match
Nov 21, 2006 | 3Com (3c17462)
Tuttnauer "2540Elvc, 220V 50/60Hz, Ea" Logo
Top Tuttnauer Science & Laboratory Experts
William McMath
ray gallant
Are you a Tuttnauer Science and Laboratory Expert? Answer questions, earn points and help others
