Question about Ovens
Wiring oven diagram - Ovens
What's the wiring diagram for a GE wall Ovens digital readout
There should be a diagram somewhere on the oven. Usually on the top or back or if not, inside the terminal block cover where the electrical supply wires go into the oven. Make sure its turned OFF before you remove any covers.
Mar 13, 2016 | GE Ovens
Wiring diagram for a Kelvinator DeVille eye level oven Model B305, Serial no 3674
Request the wiring diagram directly from Kelvinator.
Jun 25, 2014 | Ovens
Fitted new mainoven thermostat to Stoves Newhome built-in oven & grill Model No. 444445062 Serial No.41209452 other data on plate EFa900h need a wiring diagram,couple wires can adrift. Every thing...
I can only speak for the 720. If you want a circuit/wiring diagram for this one, then I need an email address. I will then register this on my BT Digital Vault and you can the download the whole manual.
Looking at the diagrams, the neon for the main oven has white and black wires.
The white wire from the main oven neon goes onto the same connector on the thermostat block as the white wire to the oven element. The black wire from the neon goes to a common terminal on the top oven neon, which then goes onto P6 of the top oven switch (still black wire).
If you need any more info, then let me know.
Apr 01, 2010 | Stoves 720EF Electric Double Oven
Oven wiring diagram or help?
I suggest you post this under Inglis to have a better chance of having an answer
Dec 31, 2009 | Stoves 720EF Electric Double Oven
I need a wiring diagram for the replacement ERCU on the JKP27WW1WW oven. Our oven is from 1994 and the new 'clock' module (ERC3) is slightly different where it connects to the 'bake' and 'broil' contacts....
I am not sure if this will help you but I did find a fellow that says he has the adaptable diagram for an updated part on this forum :
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/15496-wiring-diagram-oven-control.html
Oct 30, 2009 | GE JKP27 Electric Double Oven
Wiring diagram for jtp18
Call GE at 1-800-626-2005 to get a wiring diagram
Regards,
Powerman
Oct 26, 2008 | GE Profile JTP18 Electric Single Oven
Ovens Logo
129 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
