Question about Mizco Radio Communications
Bluetooth speaker pairing - Mizco Radio Communications
When I am trying to pair my smart phone with my ISBW2113 speakers I am getting an error: Unable to pair with ISBW2113. Incorrect PIN or password?
default is usually 4 zeros
yep it is. You must only have one entry on your phone for them. Manual is listed, details on page 2.
Pairing the Speakers (This process should be done FIRST before pairing a Bluetooth device. This should only need to be done upon first use.) 1. Power on the speakers by sliding the power switch to the ON position on both units (first make sure both speakers are fully charged). The Bluetooth Indicator and Speaker Connection Indicator will flash slowly in unison. If the Speaker Connection Indicator is not flashing, but is solid white both speakers your speakers are already paired. You can skip to the Pairing a Bluetooth Device section. 2. Press the Connect Speakers button on both speakers simultaneously. The Speaker Connection Indicators will flash quickly. Wait until both Speaker Connection 3. Indicators are solid white, this means the speakers have been successfully paired. Please note that this process can take up to 1 minute. Note : For all future uses please turn on both speakers and wait for them to connect (it may take up to 1 minute for them to pair automatically even after initial use). There should be no need to press Connect Speaker button again. If any pairing issues should occur, please follow the above steps again. Pairing a Bluetooth Device 1. Make sure you have first followed the instructions for Pairing the Speakers
When pairing, the device should remain within 3 feet of the speakers. 2. Press the Pair button on ONLY one of the speakers. The pair indicator will begin flash quickly. Using the native controls on your Bluetooth device, select the "ISBW2113" in your Bluetooth settings to pair. If your device requests a password, enter the default password " 0 0 0 0 ". Refer to the user's manual for your specific device for instructions on pairing and connecting Bluetooth devices. 3. When successfully paired, the pairing indicator will stop flashing and will remain solid. After initial pairing, the unit will stay paired unless unpaired manually by the user or erased due to a reset of the device. If your device should become unpaired, follow the above steps again. If any pairing issues should occur, un-pair the unit on your Bluetooth device and follow the above steps again. Note : If two speakers with the ISBW2113 name appear on the pairing list of your device, please erase one of ISBW2113 listed in your Bluetooth device and repeat the above steps again. Para descargar este Manual del Usuario en ingl?s, espa?ol y franc?s, o para obtener respuestas a preguntas frecuentes, visite la secci?n de apoyo en www.iLiveElectronics. com Playing Audio Wirelessly 1. Follow the instructions for Pairing a Bluetooth Device. 2. Use the native controls on the connected Bluetooth Device to select a track. 3. To play, pause or skip the selected track, use the native controls on the connected Bluetooth Device. 4. Any audio played through the connected Bluetooth device will now be heard through the speakers. Pour t?l?charger ce guide de l'utilisateur en anglais, espagnol ou fran?ais, ou pour obtenir des r?ponses ? des questions fr?quemment pos?es, consultez la rubrique d'assistance sur www.iLiveElectronics.com Customer Service: 1-888-999-4215
ILive ISBW2113B User Manual Page 2
Jul 04, 2016 | iLive ISBW2113B BLACK WIRELESS BLUTOOTH...
I have purchased 2 of these speakers. I want to Bluetooth connect them to my iphone. How do I do this and get music from both speakers?? Thx
If you have purchased Speakers with Bluetooth Connectivity capability you can do this by switching on the speakers and on your iphone use the Bluetooth Pairing Option from Bluetooth settings to establish connectivity and play music to hear from speakers
Jun 15, 2015 | Audio Players & Recorders
Why cant i get my computer to dicover my auvio pbt200 bluetooth speaker?
  1. Try playing other audio files. Ensure that audio can play fine from the same audio device when using a headphone.
  2. If Step 1 is not the case, try listening to audio by connecting the speaker to the Bluetooth device using the Aux-in cable. This will isolate if it's a Bluetooth connection issue or not. Remember to disconnect/un-pair the Bluetooth connection first.
  3. If the issue only happens when connecting via Bluetooth, do the following:
    1. Adjust the distance between the speaker and the Bluetooth device.
    2. Reset the speaker to its factory default settings. For instructions on how to reset your speaker, go to the product's support site to view the relevant knowledgebase article.
    3. Clear the current pairing entry from your Bluetooth device. For instructions on how to clear the pairing entries, consult the user's manual of your Bluetooth device.
    4. Try re-pairing the speaker and the Bluetooth device. For instructions on how to pair the speaker with the Bluetooth device, go to the product's support site to view the relevant knowledgebase article.
    5. To further isolate, try pairing the speaker with other Bluetooth device.
  4. If the issue happens when connecting either on Bluetooth or Aux-in, please contact Creative Customer Support via email.
Note: Creative Bluetooth speakers do not need any driver to operate. You may need to update the Bluetooth driver of your computer's built-in Bluetooth adapter or your USB dongle. To determine whether your computer or USB dongle is updated with the latest Bluetooth driver, please refer to their user's guide or website for information.
http://support.creative.com/kb/ShowArticle.aspx?sid=90429
Jun 05, 2015 | AUVIO Bluetooth Portable Speaker
How do I pair speaker with phone
turn both phone bluetooth and speaker bluetooth off. then turn them back on. the speaker's light should be flashing indicating its searching for a device to pair with. as its flashing make sure your phones bluetooth is visible and searching. they will pair and your phone will tell you and the speakers light should quit flashiing and just remain on.
Oct 20, 2014 | Audio Players & Recorders
How to pair ny mini bluetooth craig speaker to my
Turn on the bluetooth of your phone first: Go to settings>Wireless and Networks>Enable Bluetooth and disable discovery limit in bluetooth settings. After that make sure the bluetooth in your speaker is on and let your phone search the speaker and let it pair with it after that go into your phone's music player and look for its play options and if you see via bluetooth click it. Just let me know if you need further instructions or you could watch this video showing how he pairs his bluetooth speaker from his phone DBEST London Bluetooth Mini Speaker Review
Oct 16, 2014 | Cell Phones
How to get bluetooth speaker to connect already apired and is showing but wont connect
Hello, I have already met this issue: after pairing a bluetooth speaker on a first host (computer or iPad), then pairing it on a second device (as another computer for example), when I try to pair it again to its original host device, it doesn't work.
The solution consist in
1) on the host computer, in the list of the Bluetooth devices, delete the line of the bluetooth speaker and forget this bluetooth device,
2) push on the Bluetooth detect button on Bluetooth speaker,
3) scan the bluetooth devices on your computer host, and when you see the bluetooth speaker in the list, select it.
Jul 28, 2014 | Toshiba Satellite Laptop with AMD Athlon...
My iPhone don't work with my Bluetooth speaker system
Paired is not connected. Connecting is the next step after pairing. Then make sure that the ilive speaker is set as the dudio output device.
Dec 22, 2013 | iLive Bluetooth Speaker System
Blue tooth speaker wont turn back on.
Unable to connect to a device?
Before attempting any of the following steps, make sure that you are running the latest software version on your SoundLink Wireless Mobile speaker. Click here to visit the software update center and update your speaker. If you are still having difficulty connecting to a device after updating the software, continue to the troubleshooting steps.
Unable to connect with a previously paired device?
Please try the following to resolve this issue:
Perform a product resetTo perform a SoundLink speaker reset, following these steps:
  1. On the speaker, press and hold Mute for 10 seconds, the LEDs will flash briefly
  2. Press Power to turn the SoundLink speaker back on
Clear the pairing list on both the SoundLink Wireless Mobile speaker and the source
  1. On the SoundLink speaker, press and hold the Bluetooth button for approximately 10 seconds until you hear a tone. The SoundLink speaker clears all Bluetooth devices from its memory and becomes discoverable
  2. Clear the list on your Bluetooth device. For more information, please refer to the manufacturer of the device
  3. Perform a product reset. On the speaker, press and hold Mute for 10 seconds, the LEDs will flash briefly. Press Power to turn the SoundLink speaker back on
  4. Try pairing the device again by following these steps:
    1. With the Bluetooth device and the SoundLink speaker both turned on, press and hold the Bluetooth button on the speaker for three seconds to make the speaker discoverable. The Bluetooth indicator will slowly fade on and off approximately once every second to show the speaker is in discoverable mode
    2. Set your Bluetooth device to "Discoverable." This will allow your device to discover the SoundLink speaker
    3. On your device, locate the Bluetooth device list. Select "Bose SoundLink" from the list
    4. If your device asks for a passkey, enter digits 0000 and press OK. Some devices also ask you to accept the connection. Your Bluetooth device indicates when pairing is complete. The SoundLink speaker indicates pairing is complete when the Bluetooth indicator stops fading on and off and remains on
Be sure the SoundLink speaker is within 30 feet of the Bluetooth deviceThe system is designed to operate at a range of 30 feet. However, performance can be diminished by obstacles such as walls or metal, and may also be affected by other Bluetooth devices. Try moving the SoundLink speaker closer to the Bluetooth device.
Be sure the source's Bluetooth function is OnMany Bluetooth enabled devices have an option where the Bluetooth feature can be turned On or Off. This option may be set to Off to save the battery life of the device. Be sure this option is set to On. If the Bose product is paired to the Bluetooth enabled device, it should automatically reconnect when its Bluetooth function is turned on. If the Bose product doesn't automatically reconnect, manually select the Bose product within the Bluetooth list on the device.
Manually connect the SoundLink speaker in the device listSome devices will pair to a device but not automatically connect. Go to the pairing list of the device and check if this is the case. If it is, try connecting to the SoundLink speaker.
Oct 20, 2013 | Just Wireless Bluetooth Headset Wireless...
Why I can't bluetooth pair with veho VSS-006-360
Hope it helps.
Power off your N8.
Remove battery from your N8 and reinsert again and then power it back on.
Activate Bluetooth settings and program it to become discoverable
Power off your bluetooth speaker
Remove battery from your Bluetooth speaker and reinsert.
Power it on again
Allow the pairing to proceed for both devices. Check and confirm/test whether operational
Oct 17, 2017 | Veho Audio Players & Recorders
How to setup bluetooth external speaker on Dell Studio 17 laptop
Ensure Bluetooth is installed and on in the notebook, then turn on the Bluetooth speakers, they should be detected by the system, then pair the devices in bluetooth manager.
Sep 13, 2009 | Dell Studio 17 Laptop
Radio Communications Logo
266 people viewed this question
Top Mizco Radio Communications Experts
eradiostore
eradiostore
Are you a Mizco Radio Communication Expert? Answer questions, earn points and help others
