Question about Kenmore Washing Machines
Ge stylemaster 622866a
Keep bang and bang its noisy
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
Why won't my Whirlpool Washer Stylemaster #907675 fully drain?
The pump may be failing. That's where the leak is coming from.
Jul 28, 2014 | Whirlpool Washing Machines
This washer has always been extra noisy, but now there is a banging while washing and rinsing. The tub ends up off to the left side when I open the lid and sometimes it even walks it self out of place.....
Depending on the make. GE you look for two screws front bottom and take the front pannel off. Please specify make in the furture for better help.
Jan 23, 2011 | Washing Machines
Water all over floor
Sounds like the drain hose inside the machine got disconnected. Has your machine been noisy? Like banging around walkin?
Dec 26, 2010 | GE Washing Machines
Fan is noisy -loud wheezing sound.No dust. Banging on case sometimes stops the noise.
The fan has a noisy/worn bearing, I recommend replace the fan.
Banging the laptop base is not recommended, you could damage the hard disk.
Oct 16, 2010 | HP Mini 1000 Netbook
We heard a large BANG and now it is so noisy
The rear bearing in most front loaders lasts an average of 5 years under normal usage. Spin the drum manually with your hand and seee if it is nice and smooth and quiet. If the bearing is ok it is probable that 1 of the shocks is broken on the bottom.
Mar 18, 2010 | Washing Machines
Dryer very loud while tumbling. even empty
There are two rollers that the back of the drum ride on. At times, these rollers wear out and fall off and the drum rides on the back housing or the stem of the roller. You need to pull the front of the dryer off and carefully slide the drum forward (keep the drive belt in place) just enough to expose the rollers... replace if needed.
May 08, 2009 | Dryers
Noisy Fridge!
you need a new compresor that type of work will run you like 4 to 5 G'S you are better off buying a new one. i repl compressors everyday i work for one of the major companys that go to your home to repair refrigerators
Oct 15, 2008 | Refrigerators
Re; hotpoint refrigerator
probably the blades are hitting something , slide the fridge out and inspect, as far as it running all the time, many fridges run a lot more often than you think. the fan being noisy is drawing your attention to it more now.
Mar 24, 2008 | GE Hotpoint Top-Freezer Refrigerator
Washing Machines Logo
13 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
