Mizco CELLULAR INNOVATIONS HFBLUCK2 Slimline Bluetooth(R) Speakerphone Logo
A
Anonymous Posted on Jan 03, 2014
Directions of how to pair my wireless speaker
1helpful
3answers
My Roku TV has a loose wire keeping me from getting Wi-Fi it was Black and Blue by internal speakers
This will be a very easy fix, the wire you have is going to have a very small gold connector on the one end that will hook to the wi fi board, here is a picture of the board, it goes on the lower left side into the gold looking connector, I sent the picture so you could see where it goes you won't need a new board. https://www.shopjimmy.com/tcl-5959a-n1002-wm03-roku-wireless-wifi-lan-module/
2answers
How can I get the blinking light to turn off on Bluetooth speaker?
Well first you have to get it to flash red & blue then try to get it to pair with your device
I baughth the sylvania sp096 blutooth wireless speakers and when i pair them they work ..But i get a busy tone about every 2 minutes
sylvania sp096 Unsolved Problems - Fixya
www.fixya.com/unsolved_problems/sylvania_sp096
0 Answers. I baughth the sylvania sp096 blutooth wireless speakers and when i pair them they work ..But i get a busy tone about every 2 minutes. Jul 16, 2015 ' ...
NuForce S3-BT - Wireless Bluetooth Repair Questions ...
www.fixya.com/support/p16790384...s3...wireless_bluetooth.../page-9
NuForce S3-BT - Wireless Bluetooth Loudspeaker - Black - Page 9 - Recent Questions, Troubleshooting & ... I baughth the sylvania sp096 blutooth wireless speakers and when i pair them they work ..But i get a busy tone about every 2 minutes.
My hmdx 420 wireless speakers will turn on but when i push the Bluetooth button nothing happens it has new energizer batterys in it
Make sure your pairing with the unit properly and that your blue tooth device shows the speaker under your Bluetooth devices. See the following PDF for directions on how to pair your device to your HMDX 420.
http://goo.gl/4QtfCC
2answers
HOW DO I CONNECT MY ROKU TO MY BLUETOOTH SPEAKER
Does your Roku have Bluetooth capability ?
I have a portable wireless speaker model AWSBT7 will not go into the connect mode when pressing the button to sync up device I do not get the two beeps or the light does not flash faster
Hi Jerry, Are you using this method to pair your device?
Pairing
The Bluetooth-enabled device that you wish to stream audio to your speaker system must
fi rst be paired to the speaker. The process is simple, and in most cases the pairing process
needs to be done only once.
To pair your Bluetooth-enabled device with the speaker:
1. Make sure your device's Bluetooth is turned on. See the wireless and/or network settings
menu on your device to check.
2. If the speaker isn't already on, press the On-Off button to turn it on. You will hear a beep
to indicate the speaker is turned on. The indicator light on the back of the speaker starts
fl ashing blue.
3. Press and hold for 3 seconds the Pair button to enter pairing mode. You will hear 2 beeps
to indicate pairing mode is entered. The indicator on the back of the speaker starts blinking
faster.
4. Open the Bluetooth settings menu on your device. Select "AR SPEAKER" from the list of
devices available (you might have to scan for devices). If your device asks for a password,
enter "0000".
5. A confirmation screen will appear on your device once the speaker and the device are
successfully paired. The blue indicator turns solid blue to indicate successful connection.
The speaker is now ready for you to stream audio from your device.
2answers
Digix BT-100 Portable Bluetooth Wireless Speaker is not recognized by my android MOTO X cell phone.
Is the speaker paired with another device?
You may try turning off the bluetooth on your phone, turning off the speaker, turning back ON the speaker and then turning on the bluetooth on your phone again. This should reset the phone to SEARCH for BT-100.
Once you SEARCH for available devices you should see BT-100 on the list. Select BT-100 and it should pair. If it does not CONNECT be sure to press BT-100 again to connect. The speaker will BEEP, indicating that the speaker and the phone are now connected.
If you continue to have trouble feel free to contact the manufacturer at [email protected] or going to http://www.contelusa.net
Volume stuck on mute for wireless speakers
After pairing it, have you tried to go to your sound settings in Control Panel and selecting the bluetooth device as your standard sound device?
Sony bravia wireless speakers won't pair? ANy answers?
You might try setting the wireless to a different channel. Mine did not work at all on "A" but worked fine on "B".
Top Mizco Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Mizco Cell Phone Expert? Answer questions, earn points and help others
