Question about Seagate Expansion 2TB USB 3.0 Desktop External Hard Drive
Remove broken screws
Have removed hard drive from case but screw heads damaged and cannot remove them to get inside hard drive :(
First of all, why do you want to open up your Hard Drive? Once you remove the cover, it's ruined. If you are talking about removing the hard drive from another enclosure, then, you are in for trouble. There is not a screw extractor that small. Try to use a fine fine to make a slot in the head deep enough to where you can use a straight driver to get it out. It won't be easy, but I have been able to work the screws out that way.
Posted on Sep 28, 2014
Pegleggedous
  • 15 Answers
SOURCE: The USB plug on the SeaGate Hard Drive 250GB 7200RPM is broken.
Most companies make external HD's as a means to use up their stocks of the obsoleting ATA (IDE) HD's. My bet is that unless they joyously announce (usually on the box) that it has a "SATA" drive inside, then they must have an IDE (which they don't usually announce so readilly).
Unless it voids your warranty I suggest you just pop open the drive and look.
Posted on Mar 17, 2008
SOURCE: USB port dislodged on 1TB Seagate, how do I open the case?
I did open a Seagate FreeAgent Pro 1TB !
The thing was awful, the case is just a nightmare to crack. The base is easy, you have the screws under the tiny rubber feet. The metal over the electric parts is easy to take apart, you just unglue and carefully open. You unscrew then the four flat-headed screws the hold in place the electrics, and the three big ones that hold together the base and the upper part.
Here comes the nasty part.
You unplug all connectors, but the upper case is VERY (I mean VERY) well tightened. It's held in place in 4 points, and the plastic made my fingers bleed. I can surely say it's a very well made case, strong as military, but impossible to open without destroying.
In the upper part the plastic holding points are quite close to the lower edge, but the two lower ones are somewhat 2,5 or 3 inches away from the edge, and this is where you'll get stuck. I couldn't just pry them open, so in the end, even though the unit is safe and sound, the lid (the part with the Seagate logo) was torn an bent.
My problem was at the electrical part, so I don't care much for the case, but I feel bad for having to literally destroy such a good-looking external enclosure.
Hope this is helpful to all of you in trouble with this issue !
Posted on Dec 29, 2008
SOURCE: A piece has broken on the USB connector outlet
go to my computer properties
and select hardware
select update driver
Posted on Aug 12, 2009
  • 4 Answers
SOURCE: How to open case: Seagate ST3160203U2RK External Hard Drive ??
This is one of the mean tricks that the industry uses to discourage people from opening things and then totally ruining them.
What about getting yourself a 5-star-shaped screwdriver? Ask your hardware store guy.
Too expensive? Well - I have a lot of different simple slotted screwdrivers. Normally I find one that fits into 2 corners of these "miracle screws". If you don't have fitting one use a cheap one that is slightly too large to fit and grind it down just to size.
The same trick works with the other kind of "discouragement screws" that have ALMOST a normal slot --- but there's an elevation in the middle of it. A slot screwdriver with a ground-in **** in the middle (Dremel tools work fine) does the trick.
Posted on Sep 24, 2009
SOURCE: FreeAgent 500gig External - How to open case?
I believe Seagate has a 5yr warranty with this drive. Why not have Seagate honor the warranty and have them repair or replace the drive?
Posted on Oct 17, 2009
How do I get the hard drive out of the tower of my crashed PC?What exactly am I looking for? Who do I go to if I want to get data off the hard drive?
look at the back of the computer, look at the edges around the inside of the case your looking for screws or spinners where finger turn them remove them than the side panel should slide back towards the back of the case. look inside the case locate dvd player, follow it down come to square or oblong device ribbon cable, ribbon cable will have 16 pins about 3 inchs wide, if hard drive had sata cables little 1/2 wide with L shape connector, look at the case, look where the hard drive is mounted and find the screws that are holding the hard drive in place., you are going to remove the screws there maybe 2-4 screws holding the drive in place,. remove power connection and hard drive connection than pull out the drive. now getting infomation off the drive is alot of work go on line hard drive removal device, esata or sata with usb connection and power supply to run hard drive software to back up stuff you want. if you need more help email me thru this site.
Feb 28, 2015 | Dell Computers & Internet
How do i safely remove the cable that attaches to the motherboard on my toshiba laptop
Toshiba satellite motherboard removal.
A motherboard is usually replaced for one of two reasons. You either replace a motherboard because it has gone bad, or you replace an older motherboard with a new or upgraded motherboard. In either case you will have to completely disassemble your laptop to even gain access to your motherboard. Fortunately, the Toshiba Satellite laptop can be completely disassembled even if you don't have a lot of technical knowledge.
Turn off the laptop, disconnect the power cable, remove the battery pack and disconnect any miscellaneous cables and peripheral devices. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Attach an antistatic wrist bracelet to prevent shock from static electricity. Static electricity can harm your computer's internal parts. Place the laptop face down, and remove the single Phillips-head screw attached to the hard drive cover. Remove the hard drive cover, then set it aside. Remove the single Phillips-head screw attached to the wireless card/memory cover. Remove the cover and set it aside. Slide the hard drive out of its compartment. This will disconnect the hard drive from the computer. Set the hard drive aside very carefully. Push on the ejector tabs on either side of each RAM module. Slide the RAM modules out of their compartments at a 45-degree angle. Remove them from the laptop and set them carefully aside. Disconnect the antenna cable from the wireless card, and then lift the wireless card out of the laptop. Remove the four retaining screws from the modem card. Lift the modem card slightly out of the laptop, and then disconnect the modem cable from the motherboard. Set the modem card aside. Remove the single Phillips-head screw securing the DVD/optical drive. Slide the DVD drive out of the laptop's frame and set it aside. Remove all marked screws from the bottom casing of the laptop, and then place the laptop face up. Open the laptop as far as it will go. Use a small flathead screwdriver to pry up the keyboard bezel. The keyboard bezel is a small plastic strip sitting between the keyboard and the LCD display. Remove the two Phillips-head screws securing the keyboard in place. Lift up on the keyboard and disconnect the keyboard's ribbon connector from the motherboard. Remove the keyboard from the laptop and set it aside very carefully. Close the laptop. Place the laptop vertically so the LCD display hinges are face up. Remove the two Phillips-head screws from the hinges. Set the laptop down and open the laptop as far as it will go. Remove the four Phillips-head screws securing the LCD display. Lift up on the LCD display, and then disconnect the video cable from the motherboard. Remove the LCD display from the laptop and set it aside carefully. Disconnect the DVD control board cable, the touchpad cables and speaker cables from the motherboard. Disengage the plastic latches on the rear of the laptop casing near the hinges, and then remove the top casing from the laptop's base and set it aside. Remove the two Phillips-head screws securing the CPU fan and heat sink in place. Disconnect the fan cable from the motherboard. Remove the fan and heat sink from the motherboard and set it aside. Remove the single Phillips-head screw securing the motherboard to the bottom laptop casing. Disconnect the USB port connector from the motherboard and remove the jack from its housing. Lift the motherboard from the bottom laptop casing and very carefully set it aside.
Hope this helps.
Dec 13, 2012 | Computers & Internet
HOw Do I Take Apart a Dell Inspiron1764
LOL, just get some paper cups and label them with the screws you take off so that you will know how to put them back. It would take too long to go into details on how to tear a laptop down, but basically you remove the power cord, remove the battery, remove screws from the bottom case, remove the disk drive, remove the memory, remove the cd drive, remove the wifi card, remove the dvd drive, remove screws inside battery case, remove screws inside the hard drive case, remove screws inside the cd case, turn the laptop over, open the lid, remove the strip above the keyboard, remove screws holding the keyboard, remove the keyboard, remove screws holding the palmrest, remove the palmrest, remove the lcd hinges, remove the wires coming from the lcd going down thru the palmrest. Lift the motherboard out.
Apr 01, 2012 | Computers & Internet
How do I open the housing to rplace the drive? Many thanks.
If you don't see any screw holes, look around for some rubber feet, chances are the rubber feet are hiding some screws. If you remove those carefully enough, you can easily put them back in. Once all the the screws are removed carefully pry open the case and remove/replace the hard drive inside.
May 08, 2011 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
How do you take a cover off a hard drive
Remove the screws from the case there are usally four one on each side and then there will be Another screw underneath the manufacturers label. Feel around on the sticker for the head of the screw and sut around the screw head pull off sticker from top of head and remove the screw. Be carefull not to touch the discs inside the hard drive. The oild from you finger can render it unreadable.
Hope this helps.
Zeppelinx12
Mar 11, 2011 | Computers & Internet
How do you remove the hard drive from a acer aspire tower T135
If you are looking at the front of the computer case, you will need to remove the cover on the left hand side of the computer case. There should be two screws holding it in place, located on the back of the tower. Once you have remove the screws and cover, the hard drive will be accessible. Simply disconnect the cables to the hard drive and remove the screws holding it in place.
Mar 05, 2011 | Acer Aspire T135 PC Desktop
How to take the outer casing off a maxtor one touch external hard drive
  • Feel along the back and bottom side of your Maxtor external hard drive. Depending on the specific model of hard drive you have the unit may have screws or plastic latches inside the case. Pull of the warranty sticker and check to see if the screws are located underneath it if you don't see any screws anywhere else. Pull out the rubber stoppers at the bottom of the external hard drive case and check if the screws are located underneath. Remove the screws if your model of Maxtor external hard drive has them. Insert a thin and flat object such as a flat head screwdriver between the seams of the two sides of the case if there are no visible screws. Run the flat object around the length of the external hard drive case until it hits a plastic latch. Wiggle the object up and down until the latch disengages. Continue sliding the screwdriver along the sides until all the latches are disengaged. Pull the two sides of the Maxtor external hard drive case apart to reveal the actual hard drive enclosure inside. Remove the screws holding the hard drive into its metal cage. Pull the existing hard drive unit out the metal cage and replace it with the new hard drive. Reassemble the unit and plug it back into your computer.
Oct 27, 2010 | Computers & Internet
Want to remove my hard disc... but.. I can get to and remove the 2 screws on the "inside" of the drive.. but.. the two screws next to the case are so close to the case I can't get to them. Am I missing...
The hard drive is secured to the frame and this frame needs to be removed to get access to all the screws holding the hard drive to the frame. The frame may have screws holding it to the case or accessed from the front of the computer after you remove the front faceplate panel.
Sep 25, 2010 | Gateway 510 X PC Desktop
Jan 16, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Hard drive removal
  1. Loosen the two Phillips-head screws that secure the hard drive cover to the bottom of the notebook.
  2. Use your finger or a flat-bladed tool to lift the inside edge of the hard drive cover and remove it.
  3. Loosen the spring-loaded Phillips-head screw that secures the hard drive.
  4. Hold the Mylar tab and pull the hard drive toward the outside edge of the base enclosure to disconnect the hard drive from the system board connector.
  5. Lift the hard drive out of the bay and remove.
  6. Place the hard drive in a static dissipative bag.
Replace the hard drive
  1. Remove the hard drive from the static dissipative bag.
  2. Place the hard drive into the hard drive bay.
  3. Push the hard drive toward the inside of the base enclosure until the connector is seated.
  4. Tighten the spring-loaded Phillips-head screw that secures the hard drive.
  5. Insert the hard drive cover into the enclosure.
  6. Tighten the two Phillips-head screws.
Nov 16, 2007 | HP Pavilion Ze4805us Notebook
Seagate Expansion 2TB USB 3.0 Desktop External Hard Drive Logo
53 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
terminalcon
John Anderson
John Anderson
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
