Question about Canon Office Equipment & Supplies
Check toner 1H CHECK TONER CONNECT
  • 77 Answers
SOURCE: B8300 toner error
From Oki's site: Symptom: The toner counter did not clear after installing a new toner cartridge. Cause: The printer was not powered off when the new toner cartridge was installed, Therefore the counter did not cleared. Resolution: 1. Enter the PCU Diagnostic Mode, By turning off the printer and holding down the MENU and OK buttons on power up. (Release the buttons once you're in the PCU DIAG MODE) 2. Press the MENU button 14 times until the operator panel reads " Counter Display " 3. Press the MENU button and the BACK/C button at the same time, This will put the printer into the Feed Counter Clear Mode (Release the buttons once you're in the Feed Counter Clear Mode) 4. Press the up arrow 5 times until the operator reads " Toner Counter Clear " 5. Press the OK button, The operator panel will now display " Toner no " 6. Press the up arrow once and the operator panel will display " Toner yes". Now press the OK button and the green data light will flash to indicate that the clear process is complete 7. To exit the PCU Diagnostic Mode, By turn the printer off and then back on this will allow you to exit the PCU Diagnostic Mode Hope that helps. If it does not please let me know Ed
Posted on Jun 13, 2007
leroyal
  • 2120 Answers
SOURCE: Check Waste Toner Box message
Clean the neck of the bottle and the black sensor the neck sits in.
Posted on Feb 05, 2009
SOURCE: Brother MFC-9840CDW - checking toner level
On my APPLE the MAC OS driver depicts the toner levels when I check the printer status under the settings and preferences - printers icon - supply levels is an optional choice. I have not found a way to check the levels on an XP system.
Posted on May 07, 2009
LizBux820
SOURCE: Have an OKI Printing Solution
Found this at Fixyourownprinter.com
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
Worked for me when I had the same error. Hope it helps.
Posted on May 26, 2009
rylee_smith
  • 8619 Answers
SOURCE: I have a C3530 MFP and it won't print because it
Hi
Thanks for using FixYa. Toner sensor error is related to the agitator inside the toner cartridge, it occasionally falls out of its housing so it does not move the toner sensor which is the white plastic piece that moves up and down on the coloured handle, the toner sensors themselves see this white flag if it doesn’t move then the printer thinks the sensor is broken so toner sensor error is flagged and if the flag moves too quickly the machine thinks the toner is empty. To resolve the issue your printer is facing with please check that toner lock lever is in position and follow the following procedure---
Press the cover release and open the printer’s top cover fully. Make sure the Toner Cartridge in question is correctly positioned and the right hand clip is pushed back. While holding it by its top centre, lift the image drum, complete with its toner cartridge, up and out of the printer. On the Right hand side of the toner look for a sensor patch, make sure this is not dirty. If it is dirty clean it with a soft object such as cotton wool. Now look inside the printer opposite to where the sensor patch would sit. There is a black square with a sensor located inside and check that this is not dirty. Now replace the drum and toner, and close the printer cover. Try to print a test page and it will start printing normally.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jul 30, 2009
Sharp AR5516 Printer Error F2 40 Pls Provide Solution
Detail:
ATC sensor value abnormality
Cause:
Connector connection trouble
Toner cartridge installation trouble
Sensor breakdown
Check and remedy:
Connect the connector again.
Install the developing unit again.
Replace the developing unit with a normal one.
Thats what the Manual says, your toner is not replenishing , could be your toner motor , or your toner is empty , or your developer sensor
Feb 24, 2015 | Sharp Office Equipment & Supplies
Why Ricoh aficio 2016 asking for toner when toner is full
please check that the toner unit is not choke with toner,
again, check if the toner motor is rotating,
also check if the buttom of the toner unit is designed to fit the toner motor.
finally check the td sensor .
this may be the major cuase of this problem.
good luck.
Jul 16, 2014 | Ricoh Aficio 2016 Black and White Copier
Bizhub 550 error c2204
Waste toner motor. Remove the Waste toner box and transfer belt ensure the waste toner box is not jammed up and check the transfer belt toner removal section is OK. Also check the gears on the left side of the waste toner box is ok and the machine gears ok not jammed. could also have a jam in the internal tube that runs the old toner to waste toner box get a tech out to check
May 29, 2014 | Konica Minolta Office Equipment & Supplies
The problem is about error 000002 0000 for my ir6000
General condition
1) Is the developing assembly locking plate mounted correctly?
NO: Mount the plate correctly.
General condition
2) Is the shutter releasing member of the hopper mouth mounted correctly
to the developing assembly locking plate?
NO: It is likely that the inside of the hopper is clogged with toner. Remove
and then mount back the shutter releasing member to remove
the clog, or replace the hopper unit.
General condition, Developing assembly toner sensor (TS1)
3) Is the developing assembly adequately provided with toner?
YES: Check the developing assembly toner sensor.
General condition, Hopper toner sensor (TS2)
4) Is the hopper adequately provided with toner?
NO: Check the hopper toner sensor.
Hopper connector, Hopper supply motor (M10)
5) Is the connection of the hopper connector normal?
NO: Connect the connector securely.
YES: Check the hopper supply motor.
Feb 14, 2013 | Canon imageRUNNER 7200 Copier
ERROR E0024 FOR CANNON IR2270
check the toner hopper .toner is not being fed into the developer module at set rate.clean the hopper by blowing the toner and check the toner screw motor for rotation and do check when u install toner by service mode does the toner bottle rotate.
Aug 13, 2011 | Canon ImageRunner 2020i Copier
Como soluciono el error 7000 que me sale en la kyocera
Code 7000
Contents: Toner motor lock error A motor over-current signal is detected
continuously for 5 seconds since the toner motor is activated.
Causes: Lump of toner inside toner container.
Check procedures/corrective measures: Replace the toner container.
Causes: Defective toner replenishment drive system.
Check procedures/corrective measures: Replace the developer unit
Causes: Defective toner motor.
Causes: Defective engine PWB.
Check procedures/corrective measures: Replace the engine PWB
Jan 21, 2011 | Kyocera FS-2000D Laser Printer
Add toner ricoh aficio 2045
Toner supply is controlled with readings from TD sensor on the developing unit and the I.D sensor above the drum by default.
These are low cost parts and easy to change.
(The TD sensor on this model have been known to fluctuate back and forth by a fair margin so is a good place to start).
You could also try stripping down and cleaning out the toner hopper.
Check the four mylars are present and the grabber is opening wide enough to grab the toner bottle nozzle successfully.
Check the toner hopper exit slider is opening fully when the PCU is inserted.
I had one of these 'add toner' faults today and it was the toner hopper all clogged up inside.
The side bit where the toner drops down had hardened clumps of toner stuck around the side entrance mylar and the exit hole.
Check also the toner motor. I have seen these fail. Run simulation output check for toner motor. I would remove the toner supply unit and hold the motor when you run this simulation. Sometimes the motor turns but does not have enough torgue to turn the toner supply unit.
Mar 05, 2010 | Ricoh Aficio 2035 Copier
Error code e000020 in ir6000
E020
General condition
General condition
Oct 25, 2009 | Canon imageRUNNER 7200 Copier
Ir 3570 error e000024-0000
E024 The developing assembly connector is disconnected/Disconnection of Toner sensor.
0000 The connection detection signal is absent
continuously for 100 msec. Replace the developing assembly toner sensor. Connect the connector. Replace the DC controller
PCB.
0001 Disconnection of the wire used for detecting the
connection of the toner level sensor is found.
When the disconnection of the wire used for
detecting the connection of the toner level sensor
has been detected for 7.5 min without
interruption (12.5 min in the manual /envelop
cassette feeding).
has been detected for 12.5 min without
interruption.
-iR4570/3570/3530
cassette feeding).
-iR2870/2270/2230
interruption.
Correct the cable. Replace the sensor.
TRY THIS:
Remove toner and check for broken parts on tube, check the connection of toner assy, reconect all connectors on dc controller pcb.
If you removed the toner assy before the error occcured check if all connectors are properly inserted.
Jun 15, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Toner Light on
please check the following:-1-toner stiring roller in toner box is stucked and did not move to mix and supply toner-get toner box out and empty it from toner and clean it with air blower and check the condition of roller clean and lubricat the bearing carrying the roller-check toner motor is pluged firmly in its socket-go to rear frame and check toner selonid is working and in good condition-check gears that drive toner roller in good condition.
Apr 18, 2008 | Office Equipment & Supplies
old marine
old marine
