Question about Compaq Pesario S4120WM (DK216AR#ABA) PC Desktop
Front sound jack is not working with the sound driver only the back jack is working
  • 53 Answers
Open the comp tower and check the cables to the front audio jack and reseat the cables
Posted on May 22, 2009
Mic not working from front jack and speaker not working from rear jack of dell dimension e520 pc desktop. however drivers are installed. plz guide
verify your sound settings. make sure you have it set to the front audio jack in sound settings via control panel
Apr 12, 2012 | Dell Dimension E520 PC Desktop
Koss SB45 Professional Headset front jack doesnt work
Sounds like the jack on the front of your device is not working properly. Do other headsets work in that jack or no?
Mar 25, 2012 | Koss SB45 Professional Headset
Hp compaq dc7600 front panel 3.5 mm jacks not working so no mic and headset and my os in win 7 x32
That can either be a software or hardware problem. Please check BIOS and Sound card drivers to see if the front Headphone and mic jack are enabled. (right click computer ->properties-> device manager) or start programs -> realtek (depending on sound card)
Was it ever working before and do the plug in the back work for your computer?
May 06, 2011 | HP Compaq dc7600 Convertible Minitower PC...
My computer has not sound when i connect the speaker from back
Do they work if you connect to the front? If they dont it could be a Driver issue, download Drivers from Dell Website and reinstall. If this doesnt solve your probelm then check jack and wires for damage, if sound works from the front jack port then maybe back jack port is damaged.
Aug 09, 2010 | Dell Dimension 3000 PC Desktop
I am not getting any sound from desktop speakers..i have sony driver installed
Onboard audio is disabled in the BIOS
The BIOS Setup program is accessed by pressing the <F2> key after the Power-On Self-Test (POST) memory test begins and before the operating system boot begins. Go to the Advanced > Peripheral Configuration menu to make sure onboard audio is enabled.
Audio settings in the sound mixer are incorrect
Check your audio mixer software to ensure audio is not muted or the volume level is not turned too low.
The speakers or headphones may be connected to the wrong jacks
Make sure you connect all speakers to the correct jacks. If you connect them to line-in or microphone jacks, they won't work.
Audio drivers are not properly installed
Check Device Manager under the Sound, video and game controllers section for any errors associated with the audio driver. Reinstall the audio driver if necessary.
Audio to back panel is muted if front panel is connected
Check your audio mixer software for a setting that mutes back panel audio if you have plugged headphones into a front panel audio solution. Uncheck this setting to allow audio to both the back and front.
Sound Playback is set to wrong device
In Control Panel > Sounds and Audio Devices, go to the Audio tab. Check the default device for sound playback; there may be multiple selections. Select the desired device, either rear panel or front panel.
Mar 06, 2010 | Office Equipment & Supplies
I have no sound from the jacks on the back but sound from the front mini jack on the front
Reinstall the drivers from the disk that came with the motherboard then go to the manufacturers site and download the updates for the sound card.
Sep 24, 2009 | ASUS P4B533-VM Motherboard
Realtek HD Audio Driver Installation
It has a autodetection for when jacks are plugged into the audio port. Maybe the connection isn't just perfect, or there is corrosion/debree on it causing it not to make perfect contact. If that isn't it it may be the wrong driver.
Jul 28, 2009 | Intel Motherboard
Soundcard problem on D530 SFF
Sounds like the audio return wires aren't connected. On the motherboard, there is a sound jack on the back left side of the mobo. The jacks from the front audio panel connects to it. Both the Left and Right channel have an out and an in connector. These send the signal to the headphone jack on the front panel and return the signal to the rear output jack if a headphone is not connected. Look for looe or broken wires. The other spot to check is the front headphone jack. If a headphone plug was pulled out or pulled sideways, it could break the solder joint on the PCB panel or break the shunt feeding the singal to the rear jacks. Hope this helps.
Ron
Apr 13, 2008 | HP Compaq Business d530 PC Desktop
Compaq Pesario S4120WM (DK216AR#ABA) PC Desktop Logo
48 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
