Bush washing machine e01 code error - Washing Machines
SOURCE: E01 error in onix washing machine
i use a spatula to stick between the door and machine to push the lever open.....
Posted on Mar 03, 2010
  • 6277 Answers
SOURCE: Can you please tell me
If water is going in OK and there is some sort of action from the washer this is only a possible solution!
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Feb 21, 2011
SOURCE: I have a BUSH WM
i have removed the transport brackets cant findthe rubber ones machine shake around checked level
Posted on May 28, 2011
ginko
  • 19396 Answers
SOURCE: Error code 8 bush washing
Hi.
Bush Error code 8 is overflow.
First try disconnecting power alone for five minutes. Trip the circuit breaker or unplug power cord.
If no luck, disconnect power and check the drain filter. On most models the drain filter is accessed removing the panel at the base of the appliance, in front at the right hand side. Keep a container ready to collect the water from drain line. Make sure no water is remaining in the machine before reconnecting power.
If the error comes back after re-connecting power and running a cycle, check the drain hose at the back. Make sure that the hose is not kinked and check height and setting of the hose. Height and settings must correspond to specifications on user/installation manual, or you get siphoning with water flowing back from drain hose. Siphoning triggers overflow error.
If the drain hose is OK and the above is not fixing the problem, then there is an internal fault. Usually a defective pressure switch or a leaking inlet valve can trigger overflow error. At this point the machine will need proper repair. Call the number listed on the user manual to verify warranty status and to get in touch with an authorized technician.
First try the complete troubleshooting above. Sometimes even a power reset can do the job.
Regards.
Ginko
Posted on Sep 12, 2011
  • 316 Answers
SOURCE: how to get rid of error 88 on my bush washing machine
Washing Machine Fault Codes ' Tips, Tricks & Recipes
this should help,,
Posted on Feb 21, 2012
What do error codes e06 and e01 mean?
E01 and e06 codes - Fixya
www.fixya.com/support/t14040885-e01_e06_codes
Aug 19, 2012 - e01 and e06 codes washer will not do anything other than lock the door. - Whirlpool Duet: WFW94HEXW Laundry : question. ... Error message E06 onWhirlpool. Unplug the machine and wait 10 minutes before restarting it.
Aug 24, 2015 | Maytag Washing Machines
What does error code E01 mean?
On what? Call the manufacturer number on user manual.
Mar 08, 2015 | Washing Machines
Washer error F06 E01
The error codes F6 E1 for Maytag Maxima 6000 front load washer means that the MCU AND CCU are not communicating. You need to check the wiring and plugs to make sure they have a good connection.
Feb 10, 2015 | Maytag Washing Machines
Bosch vision error code E01 on washer
error code e01 means the computer thinks the door is open even when it's closed you can repair this using this guide:
Bosch Front Load Washer Error E01
Aug 23, 2013 | Bosch WFVC5440UC Washer
Bosch Nexxt Washer Error Code E01
means that the computer is seeing the door as opened even though it may be closed, you can fix this by following this guide:
Dec 01, 2012 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
94 people viewed this question
Top Washing Machines Experts
