Question about Yamaha P85 88Key Portable Digital Piano
What is the correct reset for Yamaha P 85 Digital Piano?
Power button turns on but will not turn off; will only turn off using the electrical cord. Master volumne button works but all other buttons do not work. Is reset using the highest C while turning on standby button?
  • 3 Answers
Reset Instructions:
1) Try a partial reset by holding down the last white key while turning the unit ON.
2) If you haven't recorded any performance(s), for a full reset, hold down on the last white key AND THE lst three black keys while turning the unit ON.
Posted on Aug 04, 2015
petraman7
  • 1175 Answers
SOURCE: Yamaha clavinova won't play C natural in any octave
Hi ...
There are flexible cables that connect the keys to the main electronics. The connectors for those cables sometimes age poorly..
It is fixable. But dont "get taken" on a repair.
If it's just resoldering a few points,it shouldnt be more than $100.00
to fix
Posted on Jan 12, 2009
  • 1137 Answers
SOURCE: No sound when piano keys are pushed on my Yamaha dgx-620
I'm sorry but it sounds like you will have to have it repaired professionally.
Posted on Apr 28, 2009
  • 12 Answers
SOURCE: Yamaha CVP-401
the back light is maybe to hot and it not good no more well one side it not
Posted on Aug 11, 2009
  • 63 Answers
SOURCE: Yamaha P-200 electric piano does not have any
Plug in your ear phones to see if you can hear the sound that way. If not you are experiencing some internal failure in your integrated amp output.
In that case you will need to get authorised service.
Posted on Oct 06, 2009
  • 5603 Answers
SOURCE: Our Yamaha clavinova CLP-115 is buzzing, even with
Without power to the unit no sound should be generated. Make sure there are no other connections.
MAYBE you have a wall transformer behind it that is buzzing. MANY wall transformers develop buzz.
Another source is flourescent lights and even some of the low voltage halogens have noisy transformers in the base.
Posted on Nov 18, 2009
What is the correct procedure for resetting Yamaha P 85 Digital Pian?
Resetting Instructions:
Jan 03, 2014 | Yamaha P85 88Key Portable Digital Piano
PSR E313 - I can't turn it on. For a while there I could turn on ok with the power button but it wouldn't turn off - I had to disconnect power source. Now the power button doesn't work at all. Tried...
Tom is probably right, the carbon contact on the switch wears out. Open the case and replace the switch.
Part #40
Price £ 3.95 + postage if required
Aug 03, 2013 | Yamaha PSR-E323 Keyboard
Powerpod 820 will not turn on. When connected to power, the lights flick on when the switch is on but immediately turn off. I cannot get the powerpod to power up. I have switched outlets, cords, and even...
There is a "Main L/R" button which most people have pressed to enable
the main speakers. Turn off the button. Then turn the unit on.
Then turn on the button again. Solved this issue for me.
Oct 13, 2011 | Music
The master volume have a sond tha when it inn high become to noise and disturbing my ears
For decent signal to noise ratio your channel faders should be about 75% up. You should set the trims when punching down the PFL button for each channel so that peaks go up the meter to about 80% of max. Your master levels shoulld be from 50 to 80% up. You should be using BALANCED cables (TRS or XLR) everywhere. Your equipment should ALL be powered from a single receptacle or power conditioning module, even if it means running extension cords. Many people try to run unbalnced cables from this to their amps... it doesn't work and noise results. You didn't give us much info on your system so that we could analyze further
Sep 13, 2011 | Behringer XENYX 2442FX Mixer
I am trying to run a monitor using the Aux Send on a Mackie Board but even with the Master Aux Send turned up there is barely any sound coming out when I try to use my microphones. Also, I noticed that...
No there is no special cord. The aux you use for a monitor should be pre fader( that means the signal comes before the volume slider) turn the individual slider all the way down. Talk into the mike at the volume you would be singing at the loudest. Adjust the gain of that chanel up untill the clip light comes on. Now back it down so it dosent come on at your loudest. Now pick the aux you want to use. Turn it up 1/2 way, turn up the master aux send coresponding to the channel aux number 1/2 way you should get sound. If it's too loud turn it down if you need more turn it up. If you have any more questions, give me a call at the shop.
Vito Vacirca Jr.
Pro Line Music
490 Lincoln Highway
Fairless Hills Pa. 19030
215-736-8055
servicedepartmentprolinemusic@comcast.net
www.prolinemusic.com
Jul 15, 2011 | Mackie 1604 VLZ 3 16 channel Analog Mixer
On my yamaha v50 keyboard there is another sound on the keys after the c3 key how do i turn it off to just leave the synth sound?
you must do master reset!
1) Turn on the power.
TIP: All buttons must remain depressed and be pressed in the order mentioned in step #2 for proper execution.
2) Press and hold down the [SEQ] button, then the [CARD] button (located next to the Demo button), and then the [DEMO] button.
3) Continue to hold the buttons down until the dialog box appears in the display. The display will first indicate the V50 Test Program and Main Rom Version then will automatically display the question: 'Test Entry Manual?'
4) Press the [DEMO] button. The screen will display: 'Factory Set?'
5) Press the [+1/YES] button. 'OK' will appear beneath the 'Factory Set?' readout, indicating completion of the Factory Reset, and the V50 will automatically return to Play Mode.
Jan 10, 2011 | Yamaha Music
How do I turn on my europower pmp 2000
The power button (push) is in the back, just next to where you plug power cord.
Aug 06, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
NO power to my Casio CTK 671
First verify with a voltmeter that the adapter IS producing the voltage it is supposed to.
The cords and internals of these often fail.
Anything beyond that will require servicing. One could oppen the unit and look for bad solder or cracked board NEAR the power input jack.
May 14, 2010 | Music
My CASIO ELECTRONIC KEYBOARD CTK 4000 suddenly it stop working. When I press power button lcd window will light up briefly and turn back off. Please I need some help. Thanks
If you have a 12v power cord going to it i would try giving it a gentle wiggle. If you find a sweet spot and the keyboard stays on then you have a broken solder joint on the 12v input.
Apr 09, 2010 | Casio Music
Not working
If it is brand new, it is likely "pilot error" as setting these up if you are unfamiliar with mixers can be frustrating.
There are several things that must be done to have a working system. Correct speaker cables are one and the setting of all the knobs are important...
DO NOT REPLACE FUSE. If any LED's are on, fuse is OK. If fuse blows, service the unit before replacing fuse to avoid further internal damage.
Make sure speaker cables are good.
Set the level control for the channel you are testing up AND you may need to press the "PAD" button to change the input gain. Turn up the master gain.
Depending on the source you are using, line or mic you may need to change the PAD button.
NOTE: This mixer does NOT have Phantom power and cannot be used with CONDENSER microphones requiring phantom power. You will get no audio from a condenser mic without phantom power. You must use dynamic mics with this mixer.
Jun 12, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
Open Questions:
See all Yamaha P85 88Key Portable Digital Piano Questions
Yamaha P85 88Key Portable Digital Piano Logo
359 people viewed this question
Top Yamaha Music Experts
Matthew Spark
Matthew Spark
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
