Question about Epson Aculaser C1100 Printer
EPSON C1100 I have 2 problems with my printer, the first is a white line down the side of all colour documents, the second is that it is telling me it has paper jam e but there is nothing jammed, i now cant print anything. Is it just time to throw away and get a new one or is there an easy solution to fix the problem.
Your problem isn't too hard to fix. If you have a vertical line down the page chances are that your heat unit roller is either scratched and so can't fuse the image in that section or has something on it. This is a bit tricky to fix yourself as your supposed to have a tech guy take the heat fuser unit out. You can do it yourself but have to be confident that you can put it back together. Take care it's usually very hot.
This printer often reports a jam in the back paper loaders if a page doesn't grab properly (or you quickly remove a sheet just before it grabs to print). Simply open the back door and shut again. If this doesn't solve it chances are there is something stuck in there. Hope this helps
Posted on Jun 06, 2009
My cyan colour is finished, i have to print a black colour documents, printer is not allowing to print, please help
switch to black and white on the printer settings.make sure ignore colour warnings are turned off
if that doesnt work youll need to replace the cyan,get it refilled for less or order online to reduce cost
Mar 07, 2011 | Epson Office Equipment & Supplies
White lines running through printed line
The white lines occur when the print-heads do *NOT* output coloured-ink when they should be.
Run the Epson printer-software to "clean-the-print-heads".
May 29, 2010 | Epson Stylus DX4450 All-In-One InkJet...
I have an epson DX4050. I currently have a full blank ink cartridge but have one empty colour catridge and 2 other colour catridges which are running low. I want to photocopy a peice of document in black...
First, using B & W to copy a photo will cause large black blotches.
B & W are actually made up of shades of Black. To get the best quality for a B & W photo, switch to "Grayscale"
Next, is the black cartridge full? Are you using any type of refilled (absolutely worst possible choice) or a third party cartridge (second worst possible choice).
Feb 27, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Epson cx3200 wrong colour
It is possible that when the printer senses not enough black ink it will swap to using the colour tanks to try and make a BLACK.
It is also possible that you have mistakenly adjusted a setting in the epson printer program to use the colour tanks to print black and white photographs.
Either of those would certainly cause the problem you describe
Check ALL your printer settings both the windows ones AND your epson ones
If you found this information useful pleas click below
Aug 12, 2009 | Epson Office Equipment & Supplies
HOW TO TAKE PHOTOCOPY IN EPSON STYLUS CX 2800
place the document in side, by the left hand top you will see copy, with two different buttons one is coloured and the other, click on the coloured to get coloured document and click on the black to give you black and white, just once and make sure there is paper in the feeder, thanks
Jul 13, 2009 | Epson STYLUS CX3900 All-In-One InkJet...
Inks
Hi, Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing. Unless you have selected "print in black & white only" your printer will "mix" the coloured inks with the black, also check the printer options to ensure you are not using the photographic quality as this will use inks very rapidly. You need to consider a couple of things, firstly the official line: Epson (and all other inkjet manufacturers) do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. The 2nd unofficial line is that it is a win-win situation for manufacturers. Firstly they get to cut down on costly warranty call outs for blocked heads (replacement printers, technician manhours, etc) and secondly they get to sell lots more inks (Ka-ching!). If you really want to print black text only (and save cash on price per-print) then a mono-laser printer is the best way as they can now be bought at inkjet prices.
Jul 09, 2009 | Epson Office Equipment & Supplies
Scanning slides produces black images. Slide
Make sure the white document matt from uner the lid has been removed. Also in Epson scan make sure you have changed the document type from reflective to Film and Colour positive.
Jul 03, 2009 | Epson Perfection V350 Flatbed Scanner
I replaced the black ink cartridge but I can't print
Hi, this is not a solution because I don't think there is one apart from buying new inks. You need to consider 2 things, firstly the official line: Epson (and all other inkjet manufacturers) do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing. It is also why the "print in Black only" option (available on some printers) only works when the coloured inks are OK.
Apr 08, 2009 | Epson Stylus Photo R260 InkJet Printer
Epson RX560 problems photo printing
RX 560 a printer error has occured see documentation
Sep 03, 2008 | Epson Printer
White lines when printing
Open the front door
On the right side you will notice a handle that you can pull OUTWARDS
On the Outside Right half way down towards the back you will see a removable plastic plate - remove it
Behind plastic plate is a handle, pull it in and out several times. This will wipe any toner off the laser glass
Chances are the white band will now have gone.
If you need further help, please let me know so I can help you fix the machine.
May 18, 2008 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 Printer Logo
314 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
