Question about Canon PIXMA™ MP510 All-In-One InkJet Printer
Makes a horrible noise
I was printing on A5, got to page 10 and then it made a horrible noise and printing error 5100 came up. We turned it off and tried again but it is still the same.
    Sergeant:
  • 199 Answers
The printer gears are fail, find a canon service center
Posted on May 22, 2009
How do I print on A5 paper on my TX300F?
A5 measures 148 × 210 millimeters or 5.83 × 8.27 inches. In PostScript, its dimensions are rounded off to 420 × 595 points.
You should be able to select A5 size in the Epson software, but above is a small idea of the sizes in case you have to setup manually, once you get it setup correctly then save it as a profile in the Epson software.If you are printing A5 then you need to make sure it is in landscape mode (if you are printing more than 1 page) if it is actual A5 sized paper or Photo paper then make sure gauge is moved on printer to the size of the medium being used.
Feb 25, 2015 | Epson TX300F Series
Canon MX7600 error 5100, 5C20
Yes, 5100 means the carriage is not moving back and forth properly or there is grease on the encoder strip behind the carriage assembly. Grease spots make it lose count and slam into the side and grind gears. You need to clean the strip with a Q-tip moist with alcohol, but very carefully, not too much pressure on the strip.
Dec 13, 2009 | Canon MX7600 Office All-In-One Printer
Black Toner Supply Error
you can refix this toner after shaking.
Sep 02, 2009 | Samsung CLX 3160fn All-In-One Printer
Regarding service error 5100 in canon ip1880 printer
1. Try to reset the ink counter by iptool software (sometimes it help)
2. Unplug the usb cable and then turn off and on your printer for a few times.
service error 5100 seems like indicating of mecanism exhausted or out of buffer ram in the printer. You should reduce the amount of pages to print at one time.
Good luck.
Jan 25, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Error 5100
5100 = a carriage error
*** ALWAYS DISCONNECT POWER FROM WALL BEFORE WORKING ON MACHINE***
Check the timing strip for contamination(plastic strip about 1/4" in width). The unit is not homing, check for obstructions.
Clean the inside, check your ink cartridges and make sure they are properly installed ( if not they may stop the carriage from moving properly) and then turn off and back on.
Jan 21, 2009 | Office Equipment & Supplies
CANON ip 4300 - 5100 error & prints skew onto DVD
I had this eror. It was caused by indexing error left to right.Would print some then cancel after starting to make clunking and left to right error gets to large.(white edge up the side of full page print).
There is a toothed print head carriage drive belt and a clear indexing strip above the heavily white greased bar behind print head carriage.
If this clear indexing strip gets grease or anything else on it the print head cannot index.
With print head at full right position,power off, I carefully wiped the clear strip by pinching between clean dry fingers and wiping up and down the strip a few times,maybe use cotton wool buds and IPA or methalated spirit if you can't get your fingers in there without breaking the strip. then with power on print head in change cartridge position,push carriage to far left and wipe right side of clear strip.I pushed carriage full left to right a few times,Then ran print head alignment.Fixed without taking apart.
Jun 23, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Error code 5100
Error code 5100 /this error is an error within the printer. This error means that there is
something obstructing the printing process. Check inside your printer through the gears that
you can see under the lid. There should be something obstructing the gears such as dirt or
in my case popcorn. Check VERY thoroughly.
Mar 23, 2008 | Canon Pixma MP500 All-In-One InkJet...
Printing Both Sides with LBP5100
my Cannon lpb 5100 colours are out of allignment (black OK) - error is "out of Register colours correction"
NOt sure how to solve this problem - calibration does not work?
Oct 12, 2007 | Canon LBP 1120 Laser Printer
Card making
This machine will only print certain sizes as borderless. A5 is not one of them. You can use the following media with this feature: Matte Paper - Heavyweight: A4, Letter Premium Glossy Photo Paper:A4, Letter, 5 x 7", 10 x 15 cm/4 x 6", 8 x 10" Photo Paper:A4 Premium Semigloss Photo Paper:A4, Letter, 10 x 15 cm/4 x 6" Glossy Photo Paper:Letter, 10 x 15 cm/4 x 6" As you can see A5 is not in the list, therefor you will not be able to print A5 borderless via the normal means.
Aug 21, 2007 | Epson RX620 All-In-One InkJet Photo...
Canon PIXMA™ MP510 All-In-One InkJet Printer Logo
149 people viewed this question
old marine
old marine
