Question about Dryers
Electrolux repair manuals
F1 error code on display?
jumptrout51
  • 3361 Answers
SOURCE: F1-7 error displayed
A shorted membrane key pad or defective wiring harness.
Posted on Mar 10, 2009
SOURCE: F1 Error code on fisher paykel softouch dishwasher
F1 means that water is in your basepan--- you can pull the bottom drawer out and soak up the water with a towel... you will have to use a hair dryer to dry underneath the control sensor in the back left corner.
Posted on Apr 11, 2009
  • 126 Answers
SOURCE: When you turn on the oven, display reads CLN or F1.
that means the oven either needs cleaned or that the oven is stuck in cleaning mode i suggest unplugging it for a few hours or clean the oven
Posted on Sep 30, 2009
  • 132 Answers
SOURCE: f1 error code
check the FixYa website for other solutions for your model, look for one with 29 postings........
Posted on Feb 21, 2010
espressonist
  • 1711 Answers
SOURCE: Oven display goes into F1
F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information.
Posted on Oct 03, 2010
Error code F18 on Electrolux range
Hello, Huntmasterwh -
I hope I am correct in thinking you do not have the owner's manual for your Electrolux range. The information on error codes should be printed in the manual.
Without knowing the model of your Electrolux range, so that I can find and check the proper user manual, I will guess there is a problem with the Electric Oven Control and it may need to be replaced.
First, disconnect the range from the electric power - either unplug it or find the circuit breaker for it and flip it to Off. Wait at least 30 seconds and reconnect the electric power or flip the circuit breaker to On.
If the F18 error code still displays, you will need to arrange for a repair technician.
Note: If you choose Comment and add the model number for the range, I will try to find a user manual (PDF format, most likely) for you.
Best wishes.
May 31, 2018 | Electrolux Kitchen Ranges
I have an Electrolux gas dryer, front loader and while drying bed sheets it gave the error F1
unplug wait a minute plug back in see if it resets.
most electrolux have E error codes followed by 2 numbers.
Press and hold the "Temperature" and "Dryness" buttons simultaneously for 6 seconds to do a factory reset.
hope this helps.
Jan 09, 2018 | Electrolux Dryers
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    What causes error code F1 in my Electrolux convection microwave EI303BM60MS?
    Thank you for your inquiry, Leanne!
    From the information you have provided your Electrolux microwave is displaying an error code of "F1". I am showing that an "F1" error code is not valid. I would recommend resetting your microwave and you can do that by flipping the household circuit breaker off for at least ten minutes. If that does not correct your issue and you continue to experience an "F1" code please reconnect. -Matt
    Apr 27, 2015 | Electrolux Microwave Ovens
    Fix e 15 error code on electrolux induction range model ew 30is6cjs have turned off barker to allow for reset. still get error code
    Good Morning friend, thanks for your post!
    I see your Electrolux range is displaying "E15" error code and you have reset your appliance but continue to receive the message. An "E15" error code stands for ESEC (Electronic Surface Element Control) self-test failed which could be a possible issue with your relay board or UIB (User Interface Board). I suggest seeking assistance from a technician to properly diagnose and repair your appliance to avoid any unnecessary part purchases. -Matt
    Sep 26, 2014 | Electrolux Kitchen Ranges
    How do I access the fault codes on an electrolux 1200
    I see many posts about Error Codes that aren't in the user manual. Here's what I found: Go to Google and type in "Electrolux Error Codes" and you will find the following site. It details an Electrolux Service Flash that helps with error codes that don't appear in your user manual. Good Hunting!
    Customer Error Codes On All Digital Display Frontload Washers - [ Terjemahkan laman ini ]Electrolux Service Flash LN071 02.13.07. NOTE. These customererror codes are not included in the error code chart on the technical data sheet located ...
    www.applianceblog.com/...electrolux/886d1212672468-frigidaire-front-load-washer-doesnt-start-frigidaireerrorcodesonalldigitaldisplayfrontloadwasher...
    Sep 16, 2012 | Electrolux EW1200i Front Load Washer /...
    We have an electrolux Wascator T3530 . It is showing a fault F1 on the display. What does this mean?
    First thing you can try is to unplug the dryer for fifteen minutes or so. If that still bring up the error code then it is your board inside your dryer.
    May 03, 2011 | Electrolux Dryers
    Electric panel on stove displays
    check the sears kenmore site they have info on error codes.
    Aug 22, 2009 | Electrolux Kenmore 30 in. Gas Freestanding...
    Dryers Logo
    124 people viewed this question
    Top Dryers Experts
