LG WF-T7016PP AGITATOR NOT WORKING HOW TO REPAIR
MACHINE TAKES IN WATER AND GOES THROUGH CYCLE BUT AGITATOR DOES NOT WORK
SOURCE: LG WF-764STP
Your problem might be the motor capacitor
Posted on Aug 31, 2007
dididsaythat
  • 291 Answers
SOURCE: everything works but machine won't agitate
The pull at the bottom of transmission should turn both ways.. one way for spin the other way for agitate... if transmission turns both ways means not locked up and probley bad motor..
Posted on Sep 05, 2007
SOURCE: kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Posted on Aug 11, 2008
SOURCE: Dead LG WF-T8016TP washing machine
Well I found the problem - fuse had blown.
There is a circuit diagram on the back of the washer that allowed me to locate the fuse. Take off the rear top plastic panel (behind the folding lid) by removing the two screws on the back. Inside close to the power cord you will find a fuse holder and an in-line ceramic fuse, 125V 12A. I checked mine for continuity and it had blown (as to why, I don't know yet - maybe the motor drew too much current with a large wash load?) - anyways, I replaced the fuse and everything works now!
Posted on Feb 15, 2009
SOURCE: LG WF-T1022TP Fuzzy Logic
Dear Sir¨
The problem with my machine WF-T1022TP is the fallow:
The pump not run correctly, for these reason, I need the manual of operation, please send this document to my e-mail: jmar440@gmail.com
thank you
Regards
Javier
Posted on Oct 04, 2009
LG Top loader WF-T7016PP Won't take in cold water? Help please
turn tap on at the wall
check that the water in solenoid is operational
check that the stop washer in the tap is allowing water in to the machine
check that the water level is set correctly
call a technician does water flow if hot water is selected
Jul 10, 2016 | LG Washing Machines
LG WF-T7016PP. It makes an operational sound, but why doesn't the drum move?
U been had - go back to the vendor regarding that POS.
Mar 22, 2016 | Washing Machines
My LG WF-T7016PP overfill
Oh the wonderment of a LG Washer! (I have one!) You have a water inlet problem...Duh! But LG makes it harder by having about 4-5 different solenoids that control Hot, Warm, Cool, and Cold settings. Easy way is to isolate. shut off the Hot water first (behind the machine) see if the problem persists. If it does then you know it is your Cold Water solenoid. If Not then it is the Hot one.
Dec 13, 2015 | LG Washing Machines
My LG 7.2kg model WF-T7016PP automatic washing machine turns on but doesn't wash, what may be the problem
Check that the magnet that is fitted to the lid of the washer is present or whether it has moved.
Jun 26, 2015 | LG Washing Machines
Lg wf -t7016pp not spinning,why?
You seem to have a broken component in the machine- I would call the LG contact number and inquire there- depending on how old the model, serial number, date of purchase, proof of purchase, you may get replacement parts and a washing machine isnt too complicated to navigate around. Im sure you could fix it :) But wish you the best of luck- If not- Second hand shops that sell these devices are usually very knowledgeable and for a small fee- you could have it working in no time.
Aug 11, 2014 | LG Washing Machines
Wash a sheep skin cover now the machine will not drain water as it usually did...it is an LG WF-T7016PP
The hose from the tub to the pump or from the pump to the drain hose is blocked, remove and clear blockage.
Aug 19, 2013 | LG WFT1071TP Top Load Washer
I have an LG model WF-T7015TP Turbodrum top-loader automatic washing machine. Having problem in that the drum does not agitate to and fro during the washing cucle. It's draining fine and even spin-drying...
check the agitator module unit and the start capacitor both in the back of the control panel One controls the agitation and the other starts the motor. If the start capacitor is failed simply replace it with a new one The agitator module will cost more . Have an appliance electrician check it out.
Aug 16, 2013 | LG WFT1071TP Top Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
