Question about Philips CDR775 2-Disc CD Recorder
Clean laser lens - Philips CDR775 2-Disc CD Recorder
Do i need a new laser or just clean the laser?
You can try cleaning the laser lens first. The lens can be cleaned with alcohol and qtips. If cleaning the lens doesn't work, then you may have a bad laser.
Apr 24, 2012 | BOSS AUDIO SYSTEMS BV8966B Car Video...
My CH - DVD 300 sticks a lot when playing. Otherwise it is fine. Do you think this is just the disk that needs cleaning or should we buy a DVD cleaner disk?
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.
Aug 11, 2011 | Cyberhome CH-DVD 300 DVD Player
How do you use a NEXXTECH Laser Lens Cleaner?
The NexxTech Laser Lens Cleaner uses six super-soft brushes to ensure thorough and reliable cleaning, without harming the delicate optical components of your disks. Enjoy your DVDs more and improve your music archive by cleaning your optics in your CD or DVD ROM. The easy-to-use audio instructions walk you through the cleaning process from start to finish. This laser lens cleaner process will prolong the life of your disc player, improve visual clarity and sound quality. Features
  • Works on CD, DVD, Blu-ray - all optical drives
  • The six brush system cleans off the entire laser lens
  • Will not damage sensitive optical components
  • Includes easy-to-use audio instructions
How to Clean the Laser Pickup Lens on your DVD Player X missing_author_image.png eHow Electronics Editor This article was created by a professional writer and edited by experienced copy editors, both qualified members of the Demand Media Studios community. All articles go through an editorial process that includes subject matter guidelines, plagiarism review, fact-checking, and other steps in an effort to provide reliable information. By an eHow Contributor
Is your DVD player malfunctioning? If you're getting a no-disc error, you may need to clean the DVD player's laser pickup. The laser pickup is what reads DVD's and allows you to view them on your TV. If you need to clean the laser pickup lens on a DVD player, follow these simple steps.
Difficulty: Moderate Instructions things you'll need:
  • Isopropyl alcohol
  • DVD lens cleaner
    • 1 Make sure the laser pickup lens is actually the problem. There are a wide variety of reasons that a DVD player might not read a disc efficiently. The disc could be scratched or dirty, for example. Test the DVD player with a disc that you know works before trying to clean the lens.
    • 2 Purchase or borrow a lens cleaner disc and try it first. You can find these things really cheap at any large department store. They usually get the job done well. However, you may need to clean the lens manually if the store-bought cleaner fails.
    • 3 Remove the outer casing of the DVD player. Remove the screws that mount the top casing onto the bottom of the DVD player and slide the top casing off. This will expose the DVD deck, which houses the laser pickup lens.
    • 4 Find the lens. The lens will be glass and under the DVD clamp. The lens will probably have a blue tint to it. If you are having trouble finding the lens, you could shine a light on the components and watch for the reflection.
    • 5 Use a cotton swab and some isopropyl alcohol to gently wipe the lens. Just a quick scrub will do. Dry the laser pickup lens with the other end of the swab.
    • 6 Give the lens a few seconds to dry and replace the covering of the DVD player. Test the efficiency of the player. If necessary, repeat the process.
May 05, 2011 | Televison & Video
Keeps repeating unknown disk
Good luck.
Apr 09, 2011 | Televison & Video
Invalid disc error message
Take care.
Mar 18, 2011 | Televison & Video
Noread
Take care.
Feb 15, 2011 | Panasonic DMR-EH55 DVD Recorder/HDD...
Disc error after loading
Take care.
Feb 14, 2011 | Sanyo Televison & Video
Dvds not playing at all or stopping after a few minutes
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it is stopping.
Good luck.
Jan 14, 2011 | Televison & Video
Mustek mp-85a works fine for period of time then stops and tries to re-load dvd. occurs in unpredictable time. have tried ac and battery only power, clean dvd, used previously working dvds, cleaned...
Good luck.
Jan 12, 2011 | Mustek MP85A Player
Disc error
It is possible that there is some dirt on the laser lens. With great care the laser lens can be cleaned.
eHow, Clean Laser lens:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
If cleaning the laser lens does not fix it, there is the possibility that the laser unit and or its assembly, or the related electronics has a fault.
Jerry G.
May 24, 2008 | Sylvania SSD803 DVD Player/VCR
Philips CDR775 2-Disc CD Recorder Logo
23 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
