How do I purchase replacement film holders for epson v500 scanner?
    Sergeant:
  • 279 Answers
4 Suggested Answers
  • 110 Answers
SOURCE: Epson perfection 4990 photo scanner
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Posted on Aug 22, 2008
SOURCE: Epson Perfection V500 photo scanner, carriage unit unable to move
I have had the sam problem on 2 of the same scanners. Open the scanner cover and slide the transparency unit transportation lock to the unlocked position. Then close the scanner cover.Power it on and there you go.Somehow this little switch can get moved and there is the grinding noise and not working.
Posted on Oct 24, 2009
SOURCE: Epson V500 scanner will not scan film
You're problem is Vista, not the v500!
Posted on Jan 01, 2010
The 35mm strips won,t fit in my holder how should I be inserting them in the holder
The holder that takes 35 mm negative strips on one side and 4, 35 mm slides on the other has a plastic frame that holds the 35 mm film in place. To load film you have to first remove that frame by putting your finger in the opening by the large "A" and popping that end up. The frame fits in only one direction and must be clipped back in by first engaging the two small fingers into openings at the end opposite to the "A" and the lowering the retainer down snapping the 3 sets of 3 clips as you work toward the "A".
Oct 11, 2014 | Epson Perfection V500 Flatbed Scanner
Tip
Fix Red Flashing Light on Epson V500 Photo Scanner
Try moving any excess film (if your strip is longer than the holder ie scanning medium format film cut too long to fit the holder) to the other end of the holder so it hangs out of the end where the controls are on the front of the scanner.
on Mar 29, 2010 | Office Equipment & Supplies
I am trying to scan slides with Epson Perfection V500 Photo...I placed the slides in properly and press the scan button on the scanner. It scans the row of slides as they appear on the scanner bed. But...
You have to have the plastic slide holder (positioner) placed perfectly. Look at the "A" and "C" tabs on the plastic holder. If they don't position your slides over the center of the glass, you are using the wrong tab! Slides have to be back-lit, which is what the top cover does. It doesn't light up the sides of the scanner glass, only the middle.
Feb 04, 2011 | Epson Perfection™ V500 Flatbed Scanner
Need an Epson Perfection V500 Photo Scanner USER GUIDE....did not get one w/ purchase of the scanner. Thanks!
You can download a User Manual from the following location by clicking on the blue underlined link: Download Now
You will have to answer 4 simple questions about your printer and you will be able to download the manual for free!
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Kind regards,
BearWeb
Feb 06, 2010 | Epson Perfection™ V500 Flatbed Scanner
Aug 16, 2009 | Epson Perfection V500 Flatbed Scanner
Epson v500 not able to scan negatives! When I open uop the software, they don't even give me the option to scan negatives, just photos!
You probably need to reset (not reload) the scanner software. Start the Epson scan software. Select professional mode from the pull down menu (it lets you choose between auto, home and professional.) On the next screen select at the very bottom select configuration. The next screen should have 4 tabs, select other. The at the bottom (I think) select restore to factory defaults. This will reset your software, now you can use auto mode if you want it to make all your selections or home if you want some control or professional if you want to control everything. Don't forget to use your film holder that came with the unit and remove the white cover that is locked underneath the lid that covers the film illumination bulb.
Jul 07, 2009 | Epson Perfection V500 Flatbed Scanner
194 people viewed this question
jasbo
jasbo
