Tv wont turn on
My projection tv was working fine one day, then next day I go to turn it on, and it clicks like its going to come on, the little red light in front of tv, will sometimes come on for about 1/4 of a sec, then nothing..... I am guessing its has something to do with the power supply board, but not positive. Its an old tv, like 11 years old, but I would still like to try and fix it if at all possible.  does anyone have any ideas what I can check to see if it is the pwer supply?  I have a digital multimeter, and have some some sodering before, but its been awhile.. thanks. any help appreciated.
I had the same problem. I went to and bought TV-KIT-003. Easy instructions to follow.
Posted on Nov 24, 2009
Why does my DLP 60 inch Mitsubishi TV keep turning off and flashing a red light?
Your repair tech hinted correct. Although the bad connection will likely be in the power supply, it actualy can sit everywhere the power goes. Can be anordinary plug / connector with a little oxidatin, or a dab soldering point. Or perhaps a electrolitic cap, slowely dying.
Let the tech do his job. He has the tools, education and skills to keep your beloved TV alive.
Apr 01, 2015 | Mitsubishi WD-60C9 60" DLP HDTV
My samsung 32'' lcd tv
poke it open, you'll find bloated capacitors at power supply board. biggest one, with power cord pluged into. replace with thesame value(s).
you good to go!
don't lie, next time! your set has been acting up fpr a while, before it quit. Remembering: few attempts to turn it on, then it works!
good luck.
Apr 04, 2010 | Samsung LE32R41BD 32 in. HD-Ready LCD...
2002 akai 54in. rear projection tv wont turn on
Unplug,replug the tv back an hour later.The tv should reset itself.More problems repost,see if i can help u.
Feb 20, 2010 | Akai PT5492S 54" Rear Projection...
KDS R60XBR1 Red Light blinks 3 times when turning
on my xbr tv there is a little *** that sticks out on the lamp cover. the wrapped and it wont work light flashed 3 time with a new cover it worked fine. there was a t. s. b. for an over heat problem new fan and sensor and door. go to its there
Mar 22, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Tv is now in faded black and white
Your HT Tansfer is giving low votage to the picture tube. Replace the HT Transformer(don't touch or go near it, it carries 11000 Volts!)....sodeep
Mar 22, 2009 | Samsung HLN5065W 50" Rear Projection...
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
Toshiba TP50H95 TV Won't turn on - Pete
You will need to trouble shoot the start up and shutdown circuits. Often this is a minor component failing causing the set to not power up or go into protective shutdown. Do you have the service manual for this TV?
Mar 01, 2008 | Toshiba TP50H95 50" Rear Projection...
Powers on but just clicks
This is an old post, but sounds like the ray tubes are out of whack and need to be adjusted. Mark each RGB dial and turn each one little by little until you get it to come one and fine tune it after it's going. This is described in more detail here:
Mar 01, 2008 | Sony KP-48V80 48" Rear Projection...
Working fine next day red light on solid
Shorted hori output transistor and bad 1200pf 2k volt capacitor.
Sep 15, 2007 | Sony KP-53V80 53" Rear Projection...
Televison & Video Logo
721 people viewed this question
Top Televison & Video Experts
